Rebel on floats
Legeorgen
Rebel on floats
Post by Legeorgen » Fri Feb 17, 2012 10:28 pm
All you guys with a rebel on floats,
I'm building a hanger right now and want to know the height of the tail for a Rebel on floats. If I chose to later install amphibious floats, how high must the door be to clear the tail? Would 11.5 feet be sufficient? MAM is out on vacation for Thanks Giving (Canadian style) and was not available for an answer. Thanks
Bruce 357R
Rebel on floats
Post by Wayne G. O'Shea » Fri Feb 17, 2012 10:28 pm
Bruce, here is my answer to that about a year and a half ago! Yes it's Thanksgiving today and the Turkey was great!!
Steve, the Rebel when mounted per MAM's instructions, as to height, has an
under wing clearance of 7'6" at the aileron horn and 7'8" at the wing tip.
The one I have on 1500's is maybe an inch lower. The tail fin will go
through a 10 foot opening with a bit of clearance and is the highest point
UNLESS you have roof mounted antennas, and then these become the highest
point that should still squeeze through a 10 foot door.
Take care,
Sent: Monday, October 14, 2002 7:36 PM
Subject: Re: Rebel on floats
Bruce 357R
Legeorgen
Rebel on floats
Post by Legeorgen » Fri Feb 17, 2012 10:29 pm
Thanks Wayne,
That was quick. We will set the post for the hanger tomorrow and this information is timely.
I'm glad you enjoyed your holiday. Us yanks have another 5 weeks before it's our turn to eat turkey.
I flew the 912 Kitfox for the first time in a 5 weeks this weekend (been having to much fun flying the Rebel) and had forgotten how smooth the engine was, or I've just gotten used to the vibration from the 0320. I think when I get the time flown off the Rebel so I'm legal to land at our towered controlled Felts Field, I'll have to stop in and make an appointment to have my prop dynamically balanced. I don't know what else it could be but and I think it should not have as much vibration as it does. What I really need is to fly in another 0320 so I have something to compare.
Bruce 357R
Rebel on floats
Post by Wayne G. O'Shea » Fri Feb 17, 2012 10:29 pm
Bruce, when you shut down does your prop stop in the handswing postion?? If it doesn't why not pull it off and move it by one hole or what ever it takes to put it in the hand swing postion. Maybe this is all it needs to smooth things out. Then again I probably asked you this before!!!
Sent: Monday, October 14, 2002 8:24 PM
Thanks Wayne,
Bruce 357R
Rebel on floats
Post by Walter Klatt » Fri Feb 17, 2012 10:29 pm
Too bad I didn't see this note earlier in the weekend, as I was out to my hangar several times and could have taken some measurements. However, I do know that my door height is 11 feet and I have plenty of clearance. I have a word doc from MAM that shows all the float dimensions for the 1800 amphibs and standard Rebel installation which I can email you off list. Let me know if you want it. It shows the tail height at 10 feet.
From: murphy-rebel@dcsol.com [mailto:murphy-rebel@dcsol.com]On Behalf Of Legeorgen@aol.com
Sent: Monday, October 14, 2002 4:37 PM
Bruce 357R
Legeorgen
Rebel on floats
Wayne,
No, my prop stops in the 4:00 position, much to my chagrin. I was sure I clocked it right but have been to lazy to change it.
If it is the prop/spinner that's out of balance, what effect would re-clocking it have? It would still be out of balance wouldn't it?
Bruce 357R
Rebel on floats
Might not do anything, but I was thinking that the prop location vs crank positon might be causing a slight vibration. Your prop was new so I suspect Sensenich would have balanced it before shipment, so maybe your engine has a rod or piston assembly that is a little heavier than the others. If you move the prop a hole to get it up in the hand swing position you might just be lucky enough to counter this small balance problem in the engine. If nothing else at least your prop will stop where it should, so it's ready to swing if you are stuck somewhere with a dead battery and the weathers closing in. Nothing worse than trying to hand swing when the compression happens with the propellor in the bottom half of the arc. Also it's much more dangerous as you end up bent down to swing it through.
Sent: Tuesday, October 15, 2002 7:54 PM
Wayne,
Bruce 357R
Rebel on floats
Post by Drew Dalgleish » Fri Feb 17, 2012 10:29 pm
Bruce
If it stops in the 4:00 position maybe you could swing it by the other
blade :)
Seriously changing the position of the prop can make a difference because
of the way the total mass interacts.Even moving the prop 180 degrees can
make a difference. When I had my prop balanced all the weight needed was an
AN3 bolt, nut and washer on the flywheel it made a noticable difference.
Legeorgen
Rebel on floats
Wayne and Drew,
I will re-clock my prop this weekend. If it makes any difference I'll let you know. Like you said, it can't hurt anything. Maybe I'll get lucky. Thanks.
Bruce 357R
Rebel on Floats
Post by Walter Klatt » Fri Feb 17, 2012 10:52 pm
10 feet should do it. Mine is less than that. It
depends on how you mount your floats with respect to
angle of incidence of the floats to the fuse. More
angle and your tail goes down.
Sent: Thursday, March 20, 2003 6:11 PM
Subject: Re: Rebel on Floats
I went through that exercise when Steve
Sloan was mounting his! I will look
and see where I posted that and get back to
you. Short of that I'll head for
the hanger and measure Howard's but it's on
blocks so not a true indication.
If you have 10 feet clearance you're fine!!
If not I know it's 9' +
something and I'll look for it. If you have
antenna's on the cabin roof they
will be the high point and if not the fin will be.
<rjohnson18@cogeco.ca>
Sent: Thursday, March 20, 2003 9:05 PM
Subject: Rebel on Floats
I was trying to search the "archives" for
Info on Rebel on floats, but I
can
not seem to get it to work. Maybe I am
having a "blonde" moment. What I
need
to know is height over fin when mounted
on 1800 amphibs.-When sitting on
the ground that is. Can anybody answer
this as I need to check my hanger
clearance. Thanks much.-Bob Rebel "652"
http://www.dcsol.com:81/public/code/html-subs
cribe.wcx
Archives located at
To contact the list admin, e-mail
Archives located at
Robert and Olga Johnson
Rebel on Floats
Post by Robert and Olga Johnson » Fri Feb 17, 2012 10:52 pm
I was trying to search the "archives" for Info on Rebel on floats, but I can
not seem to get it to work. Maybe I am having a "blonde" moment. What I need
to know is height over fin when mounted on 1800 amphibs.-When sitting on
the ground that is. Can anybody answer this as I need to check my hanger
Rebel on Floats
Post by Wayne G. O'Shea » Fri Feb 17, 2012 10:52 pm
I went through that exercise when Steve Sloan was mounting his! I will look
and see where I posted that and get back to you. Short of that I'll head for
the hanger and measure Howard's but it's on blocks so not a true indication.
If you have 10 feet clearance you're fine!! If not I know it's 9' +
something and I'll look for it. If you have antenna's on the cabin roof they
From: "Robert and Olga Johnson" <rjohnson18@cogeco.ca>
can
need
Rebel on Floats
Bob, looked through 5 years of my posts and only found the one when Steve
was trying to see if the underside of the wing was going to clear his
interior shops roof. I told him then that 10 feet was plenty if the Antennas
were on the fuselage tailcone and it would still squeeze through 10' with
roof mounted antennas. I believe the actual height when rolling is 9' 7" to
the fin but could be off by an inch or so.
Sent: Thursday, March 20, 2003 9:11 PM
look
for
indication.
they
can
need
on
Rebel on Floats
Post by Drew Dalgleish » Fri Feb 17, 2012 10:52 pm
Colleen told me 10' when I ordered mine.
Terry Dazey
Rebel on Floats
Post by Terry Dazey » Fri Feb 17, 2012 10:52 pm
can
need
on
Hello Brian:
I have uploaded a Rebel side view line drawing with mention of dimensions on
amphib floats to the group. I received this from MAM on July 28 2000. If you
wish to take a peek, look under 36-R Miscellaneous -
"dimensionswithfloats.jpeg".
With conversations with Steve Sloan concerning reducing the length of the
struts, mine may end up being about 3 inches lower.
For what it is worth.
Have fun! Good Luck!
Your Pilot Pal,
Terry Dazey
Rebel 662
