I just discovered a 2 inch crack in my exhaust system. I have the old, old
Murphy cross-over exhaust system, from about 8 years or so back. These are
the non stainless steel ones, and I seem to recall others many years ago
having similar problems. The crack is on the right side on the inside of the
Y joint. I have always had the rear tail pipes supported and never clamped
the cross-over joint. There are only 121 hours on it.
Hopefully some of you long-timers (I didn't say old), still remember this
problem. My question to you is, should I try to weld these, or throw them
out, and get new ones? If I reweld the crack at this Y joint, will that hold
it, or are they going to then fall apart elsewhere? Thanks.
Good thing it didn't happen a week or two ago, as I just got back from some
great flying around Vanouver Island, and then the BC Interior with my wife.
She would not have been happy if we had got stuck somewhere.
I need to get it fixed quickly, though, as I am planning another long trip
in about a week from now.
Exhaust system cracks on 0320
Walter, the only place I have seen the old system crack is at the exhaust
flange area on the front left cylinder. Haven't seen it at the "Y". I would
suspect that you can weld it up properly with TIG and add a reinforcement
overtop to be sure. Then make sure all your slip joints are coated with
anti-seize and reassemble. You say the rear of the pipes are supported. Are
they attached to the firewall or back up to the engine?? Have seen some
attached to the firewall like an automotive exhaust would be done. In my
opinion this can make things worse as you are holding the rear of the
exhaust while the engine moves around in relation to it. I like to strap the
exhaust back up to the engine so everything moves together.
Sent: Thursday, August 29, 2002 7:46 PM
Subject: Exhaust system cracks on 0320
theI just discovered a 2 inch crack in my exhaust system. I have the old, old
holdY joint. I have always had the rear tail pipes supported and never clamped
someit, or are they going to then fall apart elsewhere? Thanks.
wife.great flying around Vanouver Island, and then the BC Interior with my
*-------------------------------------------------------------------------*She would not have been happy if we had got stuck somewhere.
I have the pipes supported by the old red rubber hose material hanging from
the motor mounts, not the engine. Not sure where I could attach them to the
engine, because they are so far back, but I'll have another look.
Thanks for the info.
Sent: Thursday, August 29, 2002 7:43 PM
Subject: Re: Exhaust system cracks on 0320
On Howard's the left side (which is the worst for the cantilever effect) is
supported by a steel strap that goes from a clamp on the exit pipe to a
clamp on the rear cylinder pipe. The auto style muffler clamp is attached
about 3" down on the rear stack with the bolts facing out so the strap could
be attached and double nut'd and then similar on the exit pipe to tie them
together. The strap is almost straight up and down. His right side is not
strapped, as it is more balanced (teeter-totter wise) with the cross over
being more rearward on the right side exit set. We haven't seen any cracking
since this strap was installed. His original exhausts (same as yours but he
sent it out for hard chrome plating) front left pipe broke around it's
perimeter through the EGT probe hole about 3" down from the flange. He then
had a shop duplicate the exhaust exactly from stainless (except he had them
make it 1 " tighter to the engine so the muffler shrouds didn't drag the
cowl bottom). It then cracked a couple times around the front left flange.
The second time I welded it up I added the brace strap and it has been fine
now for 4+ years.
You could also possibly attach your straps to the sump pan bolts. Just use
heavier material than the stainless gear clamp material I used, trying to
throw some quick ones together for Bob P to get him off on the Ramble to
B.C.with!! They didn't last very long before they broke! Bob's has the nice
Foslington? (not right but close) stainless exhaust on it. The slip joints
have nice pegs and mating holes to go into, at each stack, so they can
expand and contract without building up stresses.
Sent: Friday, August 30, 2002 12:09 AM
Subject: RE: Exhaust system cracks on 0320
now for 4+ years.
fromI have the pipes supported by the old red rubber hose material hanging
thethe motor mounts, not the engine. Not sure where I could attach them to
wouldengine, because they are so far back, but I'll have another look.
Aresuspect that you can weld it up properly with TIG and add a reinforcement
thethey attached to the firewall or back up to the engine?? Have seen some
oldexhaust back up to the engine so everything moves together.
areMurphy cross-over exhaust system, from about 8 years or so back. These
clampedthethe non stainless steel ones, and I seem to recall others many years ago
having similar problems. The crack is on the right side on the inside ofY joint. I have always had the rear tail pipes supported and never
thisthe cross-over joint. There are only 121 hours on it.
themproblem. My question to you is, should I try to weld these, or throw
tripholdout, and get new ones? If I reweld the crack at this Y joint, will thatsomeit, or are they going to then fall apart elsewhere? Thanks.
Good thing it didn't happen a week or two ago, as I just got back fromwife.great flying around Vanouver Island, and then the BC Interior with myShe would not have been happy if we had got stuck somewhere.
*-------------------------------------------------------------------------*in about a week from now.
Walter On my homebrew crossover exhaust I used the lower magneto clamp
stud for a support 210hrs. and no problems yet.
-----------------------------------------------------I have the pipes supported by the old red rubber hose material hanging from
having similar problems. The crack is on the right side on the inside ofholdY joint. I have always had the rear tail pipes supported and never clamped
Good thing it didn't happen a week or two ago, as I just got back fromwife.great flying around Vanouver Island, and then the BC Interior with my*-------------------------------------------------------------------------*She would not have been happy if we had got stuck somewhere.
Thanks Wayne, and Drew for the info. I will get them welded with a doubler
support over the Y, and try and find a better attach point for the supports.
Sent: Thursday, August 29, 2002 9:31 PM
now for 4+ years.
now for 4+ years.
I have the old cross over exhaust system and it cracked at the Y join, I
welded it then supported the tail pipes from the motor and braced them
apart. I have not had any problem since.
I have built slip joints into the tailpipes though.
Alister
Sent: Friday, August 30, 2002 11:46 AM
Alister
