server in gbay plastics) when he gets back from holidays.
Sent: Wednesday, August 17, 2011 11:34 AM
Subject: [rebel-builders] Repeat email
Wayne,
Spent some time going through the server logs this morning, and there are
4
addresses that my system keeps attempting to send/resend messages to...
oifa@irishfield.on.ca
doshea@georgianbayplastics.com
So here are yours... and Daryl's I assume. Anyway, both of yours being on
the same server I am seeing exactly the same thing... which is what's
strange. The log shows that the message was delivered and accepted, but
then the system attempts to resend the same message an hour later. I've
copied these log entries and sent them in to the developer for review.
schmidt@mtaonline.net
dazey@turbousa.com
Now these two at least make sense, since the message is not being accepted
correctly by their server, so they should be queued to resend. But...
they
are also both on the same server (not same as you, but same as each
other),
and they are the only list members on this server... so I would think
there
must be a problem with their server.
Sent: Tuesday, August 16, 2011 6:40 PM
Subject: Re: [rebel-builders] Re: [rebel-builders] Rebel tail strut fork
ends - IMPORTANT !!!
Okay.. so skip my last message Mike.. here is Jesse's coming for the
third
time from his smartphone
Sent: Tuesday, August 16, 2011 9:29 PM
Subject: [rebel-builders] Re: [rebel-builders] Rebel tail strut fork
ends -
IMPORTANT !!!
I had an interference issue there and had to take out some additional
material from the angle. I can see how that could be a common occurance
since it is up to the builder to make that part and I have also noticed
that side to side rocking of the fuselage will cause that whole assembly
flex laterally. If the angle was in contact with the inner surface of the
strut fork, that might cause a failure. I'm not sure how to stop that
lateral flex. I was considering remaking the fittings that bolt to the
side
of the fin post (ts 3?) Out of steel.
Sent from my Verizon Wireless 4GLTE smartphone
----- Reply message -----
Subject: [rebel-builders] Rebel tail strut fork ends - IMPORTANT !!!
Date: Tue, Aug 16, 2011 3:39 pm
Okay.. so attachement at the "man made" end (vs factory made stab
attach).
Maybe they have an interference issue.. the attachment angle hasn't been
relieved enough and is bottoming in the fork just as the bolt makes the
hole. Or a bad tail spring set up with a lot of movement working the
angle/fork fitting. Maybe I should jump on a pressurized can and come
check
it out in person. I could use a pint of 6X from a good UK pub !!
Sent: Tuesday, August 16, 2011 12:50 PM
Subject: RE: [rebel-builders] Rebel tail strut fork ends - IMPORTANT !!!
