[rebel-builders] RE: Tail pipe sport
Post by Walter Klatt » Sun Feb 19, 2012 8:43 pm
On my first engine, the 320, the tail pipes were smaller with no ball
joints, so had them attached directly to the engine. On my new 360, I have
larger tail pipes with ball joints, so have them attached to the bottom edge
of the firewall with flexible supports.
schaumr@dcsol.com
Sent: Wednesday, April 20, 2011 8:39 AM
Subject: [rebel-builders] RE: Tail pipe sport
Charlie,
Others with 'hands-on' experience will chime in, I'm sure, but everything
I've
read suggests the most significant vibrations occur during engine start-up,
where the engine significantly rocks around on it's mount. Thus, it would
make the most sense to me to tie the exhaust stack to the engine if at all
possible. In fact, I was also under the impression that they are better off
unsupported than incorrectly supported by a structure in isolation from the
engine (unless, of course, you have included spring-loaded spherical ball
joint
(s) in the exhaust system).
Interested in other's views on this...
Rob
Rebel 786
are On 4/19/2011 6:06 PM, charlie@troyairpark.com wrote to rebel-builders:
-> Hello All
-> I have a Lyc. O-235 installed in my Rebel with a crossover exhaust
system. I
-> would like to hear some pros/cons on supporting the tail pipes from the
-> engine as opposed to the firewall.
-> Charlie E. 802R
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 8:43 pm
I did both:) I have supports from sump bolts to the pipes that are Vans style stainless tubing with rubber hose, and also from the engine mount structure to the pipes that are a loop of 1/8 cable attached with adel clamps. Is working well now for 45 hours.
Subject: RE: [rebel-builders] RE: Tail pipe sport
Date: Wed, 20 Apr 2011 08:46:20 -0700
schaumr@dcsol.com
Charlie,
I've
joint
Rob
Rebel 786
-> Hello All
system. I
-> Charlie E. 802R
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 8:43 pm
Mike ,Rob, Jesse & Walter
Thanks for all of your comments on the "Tail Pipe Support". I neglected to
mention I do have the spherical ball joints on my exhaust system and had
originally planed to support them from the lower edge of the firewall.
Yesterday I looked at Vetterman's web site hoping to see his engine too tail
pipe support design but was unsuccessful. If anyone has a photo or can point
me to a source I would appreciate it. Walter I would also be interested in
seeing your "Flexible Supports" if you have a photo. Thanks again for the
help.
Charlie E. 802R
Sent: Wednesday, April 20, 2011 10:46 AM
edge
schaumr@dcsol.com
Charlie,
I've
start-up,
off
joint
Rob
Rebel 786
-> Hello All
system. I
-> Charlie E. 802R
Jesse Jenks
I got my support kit from Vetterman. If you search around on the van's forum you will find lots of pics and info. The way he designed it it's supposed to have a horizontal support that ties the two pipes together but the vans pipes are much closer together than the Murphy and at least on mine it would have been tricky to make that work so that's why I added the supports to the engine mount.
Subject: Re: [rebel-builders] RE: Tail pipe sport
Date: Thu, 21 Apr 2011 09:56:48 -0500
help.
Charlie E. 802R
edge
schaumr@dcsol.com
Charlie,
I've
start-up,
off
joint
Rob
Rebel 786
-> Hello All
system. I
-> Charlie E. 802R
Jesse Jenks
I should add that I have had some slippage where the rubber hose clamps onto the stainless tubes. I would recommend double hose clamps or flaring the end of the tubes slightly.
Date: Thu, 21 Apr 2011 08:14:13 -0700
help.
Charlie E. 802R
edge
schaumr@dcsol.com
Charlie,
I've
start-up,
off
joint
Rob
Rebel 786
-> Hello All
system. I
-> Charlie E. 802R
rick greenwood
Post by rick greenwood » Sun Feb 19, 2012 8:43 pm
Hello Charlie:
I am forwarding pictures of how I made my tail pipe supports. I haven't flown it yet but I had a couple of engine start ups and had no problems so far.
I used an eye bolt for the top throught the firewall through a bracket for support. Used 3/8 steel tubing. Used torches to heat ends and flattened them then drilled.
I used 3/8 fuel line with a 1/2 inch space between the tubings in the fuel line and tubing flared slightly for extra grip. I also have the spherical ball joint like you.
I just come up with this idea and I hope it helps
Rick 233R
help.
Charlie E. 802R
edge
schaumr@dcsol.com
Charlie,
I've
start-up,
off
joint
Rob
Rebel 786
-> Hello All
system. I
-> Charlie E. 802R
Sorry, couldn't find any photo. Will try to remember to take a pic next time
I have the cowl off. But it is just a hose piece, similar to what others
have described.
Charlie Eubanks
Sent: Thursday, April 21, 2011 7:57 AM
help.
Charlie E. 802R
edge
schaumr@dcsol.com
Charlie,
I've
start-up,
off
joint
Rob
Rebel 786
-> Hello All
system. I
-> Charlie E. 802R
craig
Post by craig » Sun Feb 19, 2012 8:43 pm
Rick,
Where are you located? I used to know a guy with the same name in NV.
Craig
Sent: Thursday, April 21, 2011 9:52 AM
Hello Charlie:
far.
them then drilled.
Rick 233R
tail
point
in
help.
Charlie E. 802R
have
edge
schaumr@dcsol.com
Charlie,
everything
I've
start-up,
would
all
off
ball
joint
Rob
Rebel 786
rebel-builders:
-> Hello All
system. I
-> Charlie E. 802R
rick greenwood
Craig,
White River,Ont.between the soo and Thunder Bay,never been to NV.
Rick
Date: Thu, 21 Apr 2011 20:23:16 -0800
Rick,
Craig
Hello Charlie:
far.
them then drilled.
Rick 233R
tail
point
in
help.
Charlie E. 802R
Charlie Eubanks
Rich
Great photos Rich gives me some ideas. I have already installed attachment
points on my firewall just have to create some type of flexible connections.
Thanks for the help.
Charlie E. 802R
Sent: Friday, April 22, 2011 7:02 AM
Craig,
Rick
Rick,
Craig
Hello Charlie:
so
far.
for
them then drilled.
fuel
spherical
Rick 233R
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:43 pm
You want the exhaust shaking with the engine or it will die an early death.
I thought I made mention or uploaded pics of the nice easy hangers on the
rebuild I did last spring. They are attached to the lower engine mount bolts
to suspend the exhaust pipes. I'll find them and fwd them to you Charlie.
Sent: Friday, April 22, 2011 8:38 AM
Rich
connections.
Charlie E. 802R
Craig,
Rick
Rick,
Craig
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:50 pm
Fwd'd it to you Charlie.. note to everyone else that I did indeed upload it
last year to Rebel - Engines. File "exhausthanger".
Sent: Friday, April 22, 2011 10:42 AM
death.
bolts
Rich
connections.
Charlie E. 802R
Craig,
Rick
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 8:50 pm
Hello Wayne
Thanks for the photo of your exhaust hangers. Mike Holloway advised me the
other day of your photo posting. I found it on the Rebel net but the photo I
down loaded was not as clear as the one you just sent. I will assume the
tubing can be 3/8 aluminum or steel and 303 med pressure hose? I could not
make out any cross bracing between the two supports tubes (one for each tail
pipe) but assume (again) that they must exist. With only 4" between the
carburetor and the firewall, space may be a little limited for the cross
brace but we will see. Thanks again for the help.
Charlie E. 802R
Sent: Friday, April 22, 2011 10:21 AM
it
death.
bolts
Rich
connections.
Charlie E. 802R
Yes, side to side joiner.. same deal.. 3/8th tubes with a crimped end
clamped to the exhaust pipes with worm clamps and a rubber joiner. I'll find
a picture! Hose.. any you have handy.. it's just to make up for misalignment
and expansion.
I don't think the the joiner is absolutely necessary.. the supports hang
darn near straight down to pick up each exhaust pipe to stop the usual
crack/breakage at each exhaust stack from vibration/g loading... but if you
can get them in, why not!
As for alum or steel. My preference would be steel for easy of flattening an
end for the exhaust end and welding a tab for the mmount end.
Sent: Friday, April 22, 2011 3:31 PM
Hello Wayne
tail
Charlie E. 802R
it
death.
bolts
Charlie.
Charlie Eubanks
I think I got it now. Thanks again for your knowledge and taking the time.
Maybe some day I can return the favor.
Charlie E.
Sent: Friday, April 22, 2011 2:59 PM
find
misalignment
and expansion.
you
an
Hello Wayne
not
tail
Charlie E. 802R
it
