Set up a 5 inch ramp that your front wheels would roll over just as the tail
reaches the edge of the door. The weight on the front gear is pretty light,
so should be easy to just pull them over the little ramp. That would be
enough to lower your tail to fit under the door.
I should measure my tail height again. It got lowered last year when I
increased the float angle. I think it is pretty close to 9' 7" now.
snowyrvr@mtaonline.net
Sent: Thursday, January 13, 2011 12:31 PM
Subject: [rebel-builders] Amphib Height
A hangar I'm looking at has a door height of 9'7". Wayne and others, are
there techniques that would let me use this with my rebel on amphibs?
Wayne, you've mentioned ramps in the past; would they handle a 5-6"
difference? I guess if worst comes to worst, a guy could pump the wheels up
and roll it in on dollies or something. Craig
Just came back from my hangar, and my tail height is now 9'3".
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Walter
Klatt
Sent: Thursday, January 13, 2011 12:58 PM
Subject: RE: [rebel-builders] Amphib Height
Klatt
Thanks, Walter. Sounds like it might be a non-issue. BTW, how much did you change the float angle?
--- Walter.Klatt@shaw.ca wrote:
Date: Thu, 13 Jan 2011 13:52:39 -0800
Klatt
Klatt
I went from 2.5 to 3.5 degrees just before I installed Wayne's Canoe Loader.
Sent: Thursday, January 13, 2011 3:22 PM
Klatt
Klatt
