[rebel-builders] carburator bits
walter.klatt
Garry, this is probably not your problem, but thought I would mention a situation I had once with my 320 carb. It is possible to install the bowl and have the mixture cut off out of position. I did that a long time when doing some troubleshooting, with the result being unable to properly shut off the fuel at the carb. Solution was simply to reinstall the bowl taking care to make sure the mixture goes into the right hole.
Date: Fri, 04 Jun 2010 10:39:29
Subject: [rebel-builders] carburator bits
I've got a Marvel-Schebler MA-4SPA part# 10-3678-12 on my O-320. I'm
having a bit of trouble with idle cutoff and it seems to be leak-by
associated with the mixture barrel/window-sleeve/window components. I
can't find the part numbers on this part - anyone know how to find same?
Reference EAA article by Richard Koehler "It Won't Shut Down".
Garry
C-FOKM
Garry
C-FOKM
wright.garry30
Interesting but weird. Bowl was not removed since I got it and mixture wrkd correctly so tt's likely not it. Tnx anyway.
G
Date: Fri, 4 Jun 2010 17:11:54
Subject: Re: [rebel-builders] carburator bits
Garry
C-FOKM
G
Garry
C-FOKM
Charlie Eubanks
Have you checked to see if your primer check valve is seated? It will
continue to run but rough after shutdown if leaking
Charlie E..
Sent: Friday, June 04, 2010 11:39 AM
Charlie E..
Garry
C-FOKM
walter.klatt
Or if there is some dirt in there not allowing it to seat properly. I had that problem once, too. It was actually Wayne here on this list that correctly diagnosed that one. My symptoms had to do with a rough running engine, though, not a problem shutting down.
Date: Fri, 04 Jun 2010 17:05:02
Charlie E..
Charlie E..
Garry
C-FOKM
Simon Smith
Gary,
The part # for the MA4SPA 10-3678-12 Mixture control metering valve assy. is
242-514 hope this helps.
Si
Checked by AVG - www.avg.com
Version: 8.5.437 / Virus Database: 271.1.1/2917 - Release Date: 06/04/10
06:25:00
Si
--------------------------------------------------------------------------------I've got a Marvel-Schebler MA-4SPA part# 10-3678-12 on my O-320. I'm
Garry
C-FOKM
06:25:00
Garry Wright
Thanks Si. That could help a lot. Where did you find that and who is a
good supplier?
Garry
On 10-06-04 06:40 PM, Simon Smith wrote:
Garry Wright
Skepticism is the highest duty and blind faith the one unpardonable sin.
-- Thomas Huxley, (attributed: source unknown)
good supplier?
Garry
--Gary,
Si
To:<rebel-builders@dcsol.com>
Garry
C-FOKM
06:25:00
Garry Wright
Garry Wright
Thanks Charlie. If I don't get anywhere with the thread I'm following I
will chase that one. The article below suggests that would cause plug
fouling and other problems before this cutoff issue so I'll keep it in mind.
Garry
On 10-06-04 04:05 PM, Charlie Eubanks wrote:
Garry Wright
Garry
--Have you checked to see if your primer check valve is seated? It will
Charlie E..
Garry
C-FOKM
Garry Wright
Simon Smith
Gary,
The information came from my Precision Carburetors Manual. I don't know of a
source right now but you might try A.E.R.O. 1-800-362-3044 or El Reno
Aviation 405-262-2387.
Si
Sent: Saturday, June 05, 2010 6:39 AM
Version: 8.5.437 / Virus Database: 271.1.1/2918 - Release Date: 06/04/10
18:25:00
Si
--------------------------------------------------------------------------------Thanks Si. That could help a lot. Where did you find that and who is a
good supplier?
Garry
On 10-06-04 06:40 PM, Simon Smith wrote:--Gary,
is
Si
Garry
C-FOKM
06:25:00
Garry Wright
18:25:00
Garry Wright
Thanks Si. Thats very helpful. This is not a normally replaced part and
does not appear in any of the lists I've found.
Garry
On 10-06-05 06:51 AM, Simon Smith wrote:
Garry Wright
Garry
--Gary,
Si
good supplier?
Garry
--Gary,
is
Si
06:25:00
Garry Wright
18:25:00
Garry Wright
Garry Wright
I take that back. ACS has it for $79.85 but no info on it at all so I
was initially unable to find it.
G
Garry Wright
G
--Gary,
Si
good supplier?
Garry
--Gary,
is
Si
06:25:00
Garry Wright
18:25:00
Garry Wright
