[rebel-builders] rudder cable exit
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 8:49 pm
My cables are pertty much the standard Rebel route. I am trying to locate
them through the fuselage as we speak. Any help or tip would be very
welcome.
Charlie E. 802R
To: "Builders list" <rebel-builders@dcsol.com>
Sent: Thursday, December 03, 2009 12:36 PM
Subject: [rebel-builders] rudder cable exit
Miraculously (well, with the help of a laser and some string, and a lot of
staring) I managed to bullseye my holes through the fuselage skin for the
rudder cables. What I have is 2 neat 1/4 x 1 1/4 slots in the .032 fus-30.
My question to the oracle is; do I need doublers around these slots? I was
planning on having to hog out some ugly holes to get them where I wanted
and then put doublers on the outside to neaten things up, but now I have
the option to put the doublers on the inside, or leave them out.
My cable exits are way back on the fus-30s because of a highly modified
cable routing down the center of the fuselage. I can give details if
anyone is interested.
I plan to use 1/4 nylon tube glued in the slots with Sikaflex for the
fairlead.
Thanks.
Chat with Messenger straight from your Hotmail inbox.
http://www.microsoft.com/windows/window ... M_4:092009
Post by Ken » Sun Feb 19, 2012 8:49 pm
I would put the doubler in. You effectively have a 1.25" hole in a
highly stressed area. Perhaps use the same piece of metal as the doubler
around the elevator push rod openings if convenient.
lot of staring) I managed to bullseye my holes through the fuselage
skin for the rudder cables. What I have is 2 neat 1/4 x 1 1/4 slots
in the .032 fus-30. My question to the oracle is; do I need doublers
around these slots? I was planning on having to hog out some ugly
holes to get them where I wanted and then put doublers on the outside
to neaten things up, but now I have the option to put the doublers on
the inside, or leave them out. My cable exits are way back on the
fus-30s because of a highly modified cable routing down the center of
the fuselage. I can give details if anyone is interested. I plan to
use 1/4 nylon tube glued in the slots with Sikaflex for the fairlead.
Thanks. Jesse
_
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 8:49 pm
Roger Hoffman wrote an interesting piece about locating the rudder cable
holes on his Rebel. See http://tinyurl.com/yf5hrfz
254R
http://n254mr.com
On Thu, Dec 3, 2009 at 11:10 AM, Charlie Eubanks <charlie@troyairpark.com>wrote:
welcome.
Charlie E. 802R
Charlie Eubanks
Thanks Ron that will help. Wish me luck.
Charlie
Sent: Thursday, December 03, 2009 2:14 PM
Subject: Re: [rebel-builders] rudder cable exit
254R
http://n254mr.com
welcome.
Charlie E. 802R
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 8:49 pm
Thanks Ken. Charlie, I agree that Roger Hoffman's website is great if you haven't already gone there. Other than that, my general technique was to run string along the bottom outside of the skin, spaced away from the skin enough so it can run in a straight line. This lets you take measurements and translate them to the inside, using rivet lines and the skin itself for reference points. Once I had a couple bulkheads drilled, I shined a laser through the holes and that gave me the exit point through the skin. Don't forget to stare at it for a long, long time before you drill any holes.
Date: Thu, 3 Dec 2009 13:10:54 -0600
welcome.
Charlie E. 802R
fairlead.
Thanks.
Windows Live Hotmail gives you a free,exclusive gift.
http://www.microsoft.com/windows/window ... M_7:092009
