Your following message has been delivered to the 165 members of
the list murphy-rebel@dcsol.com at 09:11:30 on 13 Nov 2000.
In regards to Warp Drive / 160 H.P. Engine combinations apparently needing
something to stop blade cracking I am forwarding this to the list.
Wayne G.O'Shea
To: <raa@bconnex.net>
Sent: Sunday, November 12, 2000 11:02 PM
Subject: Re: Prop Damper
onMark Landoll (405-392-3847 )sells a damper for Lycoming engines. It bolts
theto the back of the starter ring gear. It has a ring inside which floats in
some form of silicone to dampen out the power pulses and it adds about 12
pounds. I have not got one for my 0-320 yet but am planning to add it in
*-----------------------------------------------------------------------------------*future as the ones I have seen do make the engine run somewhat smoother.
Marc DeGirolamo
Phone: (306)934-4434
Fax: (306)934-4551
email(H): mdee@dlcwest.com
email(W): marc.degirolamo@city.saskatoon.sk.ca
