[rebel-builders] skylight doublers
Keith Leitch
Post by Keith Leitch » Sun Feb 19, 2012 8:16 pm
LOL!
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:16 pm
YES.... but hold onto your maps !
From: "Kevin & Nancy Mayville" <knmay@sympatico.ca>
Sent: Wednesday, February 25, 2009 5:12 PM
Subject: Re: [rebel-builders] skylight doublers
Has any one flown with out the doors installed ?
Kevin
C-FRFP
Keith Leitch
Gary,
I have noticed the same percentage of Rebels with skylights.....more have than have not. More light is nice to have...sometimes. The main issue I can think of is on those bright days I even have trouble with reflections on my GPS just through the windows already in the plane. I was trying to imagine how bad it could get with skylights. Just me thinking again...and that gets me into enough trouble already!! :)
Keith
--- On Wed, 2/25/09, Gary Gustafson <gargus@comcast.net> wrote:
Subject: RE: [rebel-builders] skylight doublers
Date: Wednesday, February 25, 2009, 9:20 AM
I bought my Rebel partially completed by two older men (that is a
relative word) who had a flying Rebel without skylights. The one
they were building had eight skylights as they said it was too dark
and they wanted more light. So their preference was to have shylights.
Quite a few pictures of Rebels posted on websites (from the 62 pictures
that I have I would say about 70%) have skylights.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Keith
Leitch
Sent: Wednesday, February 25, 2009 10:10 AM
I am just curious as to how many guys have/have not intalled the sky lights?
Is there any issues if I don't install any? Neither my Champ or my 172 has
them and I don't remember any airplane I have flown that did have them.
What
are the pros of having them other than letting light in and an added view
when turning?
Keith Leitch
Ted,
The ones right above your head come in real handy when cranking a hard tight
corner.. look up and see where you're headed. The ones behind that burn the
back of your neck flying North in the afternoon and the last set at the back
allow you to look back down the runway/lake when taxing on wheels and
floats. The small set forward of the carrythru have pros and cons... they
let you see traffic but they also let the sun right into your eyes and many
days they see a nav map stuff up between them and the windshield to work as
a visor.
Gary... I keep reading your messages and the way it reads it sounds like you
want to put lexan in those front holes. They get left wide open... if you
are installing the moulded windshield.
Sent: Wednesday, February 25, 2009 10:31 AM
Ted,
We think along the same lines. I may only do a couple of small ones close
to the windshield.
Keith
I my opinion, the only three situations that warrant use/install of
skylights:
- See some low-wing plane that is about to try to land on top of you in
pattern!
- See mtn tops while doing a steep turn in a narrow valley (found such
useful in Idaho backcountry)
- Let some sun in on those cold winter days.
All in all, I only installed the two small skylights in my Moose. I felt
the other larger skylights were just not worth it given the limited
situations in which I might want them.
Ted
Keith
Leitch
Sent: Wednesday, February 25, 2009 8:10 AM
lights?
What
when turning?
Keith
Gary Gustafson
Post by Gary Gustafson » Sun Feb 19, 2012 8:16 pm
Wayne... Yes my plane came with Lexan installed in the forward oval
openings adjacent to the flap handle. Today I drilled both of them out
and made doublers for each of them. The holes thru the Lexan are now
oversize holes and have a aluminum backing frame around them as I
understood the directions. Yes, they are like a double pain glass
up there with the molded windshield. I thought that was a bit of
redundancy and were probably made that way so as not to weaken that
part of the fuselage. They came that way and I re-made them and
reinstalled them today. Based on the emails today I now figure that
it is good insurance in case a bird strikes that area of the plane. LOL
Thanks to you all for the comments and discussion as to need of the
skylights in the first place. I am moving on.
G. O'Shea
Sent: Wednesday, February 25, 2009 10:37 AM
a visor.
Ted,
to the windshield.
Keith
skylights:
pattern!
Ted
Keith
Leitch
lights?
What
when turning?
Keith
rebflyer
Post by rebflyer » Sun Feb 19, 2012 8:16 pm
Hi Keith,
?I chose not to install the skylights on 97MR. I did however cut the ones in?under the windshield. They don't leak:) and so far my bald head has not gotten a sunburn. Seems like when ever I do see the skylights they are used to store charts/block out the sun. I never had them but I have never wished I put them in either.
???????? IMHO
?????????? Curt Martin
?????????? N97MR
Sent: Wed, 25 Feb 2009 10:09 am
I am just curious as to how many guys have/have not intalled the sky lights? Is
there any issues if I don't install any? Neither my Champ or my 172 has them and
I don't remember any airplane I have flown that did have them. What are the pros
of having them other than letting light in and an added view when turning?
Keith
bransom
Post by bransom » Sun Feb 19, 2012 8:16 pm
I was going to post that I've never much used the overhead lexan window in
my ultralight. But then I remembered seeing uncomfortably close traffic
there one time. That made it worth having! I can't speak for the Rebel
other than to remind that the Sport Aviation article (Budd Davisson,
November, 1994) said the cabin needed all possible skylights. Part of this
was based on the fact that the factory Rebel was with the firewall 3"
further back and, according to the article, pilot and passenger back even
more --- so in that configuration forward/upward vis was reduced, as was
general cabin light.
-Ben
On 2/25/2009 6:20 AM, tedwaltman@i1ci.com wrote to rebel-builders:
[quote]I my opinion, the only three situations that warrant use/install of
skylights:
- See some low-wing plane that is about to try to land on top of you in the
pattern!
Ted
Leitch
them and I don't remember any airplane I have flown that did have them. What
when turning?
snowyrvr@mtaonline.net
[rebel-builders] Skylight Doublers
Post by snowyrvr@mtaonline.net » Sun Feb 19, 2012 8:25 pm
Seems like they need to hold the "glass" in. :)
Original Message:
Date: Sat, 01 Aug 2009 16:26:05 -0400
Subject: [rebel-builders] Skylight Doublers
Howdy,
Which side have you all been installing the window doublers on? Inside
or outside? Looks like they could go either way and the manual doesn't
say. What do you think looks best? Thanks..
Joel Jacobs
Rebel S/N416R
mail2web.com
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 8:25 pm
They mount inside, on the underside of the roof.
254R
On Sat, Aug 1, 2009 at 1:26 PM, Joel Jacobs <jj7499@gmail.com> wrote:
Howdy,
Joel Jacobs
Rebel S/N416R
Joel Jacobs
Post by Joel Jacobs » Sun Feb 19, 2012 8:25 pm
Thanks Ron, I got them cut in yesterday and they look great.
Joel Jacobs
Rebel 416R
254R
Howdy,
Joel Jacobs
Rebel S/N416R
