[rebel-builders] Elite Heat
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 7:51 pm
John, when you mention directing air through a scat hose to your filter, do you mean cooler? Even 3 inches is too small if it is your cooler. Most people that I know using a remote cooler have had to go to 4 inches.
I have my cooler on the rear baffle, as does Dennis with the 360, and no problems cooling in the hottest days (+30 C) and during long climbs. Anything less than 20 C OAT, and I have to partially block mine to get it up to 180 F.
CHT's have always been my challenge. With the new engine, I can keep them to below 435 on a hot day long climb, and below 400 in cruise. As it is getting broken in, I think it is running even cooler now too. One thing I noticed, is that if I put it in flaperon reflex, my CHT's cool down about 20 degrees. What is weird about this engine is that the front CHT's are running hotter than my rear ones. With the 320, the rear ones were the hottest, mostly #3. Anybody else experience this?
What are your CHT's running at?
My bottom cowl outlet is much larger, probably 2X the inlets which I have not enlarged on this one. The other thing that I haven't done yet, is ramp my upper inlets, to see if that helps further. With my old 320, I finally resorted to bigger inlets after doing everything else, but I think I can get away without that with this one. One other thing, I am allowing some air around my carb inlet to flow past. Was told that helps, but haven't tried it sealed, so can't confirm that.
Date: Wednesday, August 20, 2008 10:05 am
Subject: [rebel-builders] Elite Heat
To: bobp@prosumers.ca
Cc: rebel-builders@dcsol.com
Hi Bob,
Any suggestions on how to get the oil temp down on my Elite ?
Running at 22o on an 85 degree day.
I have enlarged the lower cowl bottom cutout to 1.25 the inlet
in sq inches- increased the scat hose cooling hose from the
baffle from 1 inch to 3 inches and redirecting it onto the oil
filter ,swapped out the Positec 7 row for as Niagra 8 row
and have as of yet not achieved much reduction (5-7
degrees)in oil temp.
Have a Stuart Warner filter but am resisting the firewall
retrofit until I am out of options?
Tks
John W
steve whitenect
Post by steve whitenect » Sun Feb 19, 2012 7:51 pm
Hi John
Isn't the rule of thumb for outlet to be 1.5 times the inlet? Also try a bottom cowl lip in front of the cutout. I have a large outlet with the standard nose cowl and see high temp of 340 in 30* in climb and 310 in cruise. A friend of mine had good cyl temps and extremely high oil temp. After enlargening the outlet, his oil temps tropped over 25*. Had the cooler mounted on the firewall. Van's rule for proper cooling is no more than 2 square inches total of leakage around your baffling.
Steve W
Date: Wed, 20 Aug 2008 10:04:57 -0700> From: chileman88@yahoo.com> Subject: [rebel-builders] Elite Heat> To: bobp@prosumers.ca> CC: rebel-builders@dcsol.com> > Hi Bob,> > Any suggestions on how to get the oil temp down on my Elite ?> Running at 22o on an 85 degree day. > > I have enlarged the lower cowl bottom cutout to 1.25 the inlet in sq inches- increased the scat hose cooling hose from the baffle from 1 inch to 3 inches and redirecting it onto the oil filter ,swapped out the Positec 7 row for as Niagra 8 row and have as of yet not achieved much reduction (5-7 degrees)in oil temp.> > Have a Stuart Warner filter but am resisting the firewall retrofit until I am out of options?> > Tks > > John W > > > > > > > > > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com> -----------------
Find hidden words, unscramble celebrity names, or try the ultimate crossword puzzle with Live Search Games. Play now!
http://g.msn.ca/ca55/212
chileman88
Post by chileman88 » Sun Feb 19, 2012 7:51 pm
Just got back from a test flite
My cooler is baffle mounted. I increased the opposing scat tube and directed onto the filter with a cool collar installed. I also put a 2 inch chin spoiler and a 2 inch induction mod on the cowl inlets.
My Cht run 4 415 rear
3. 75 front strangely they rise little in climb.
Today at 78 F I saw 190
Hoping tommorrow at 85
- see 200-205.
John
Sent from my Verizon Wireless BlackBerry
Date: Wed, 20 Aug 2008 11:14:27
Subject: Re: [rebel-builders] Elite Heat
Hi Bob,
Tks
John W
chileman88
Steve
I heard 1. 3 ratio but don't really know.
I have a 2 inch x 8 chin spoiler and a 2 x4 x2 top
Induction mod on the cowl inlets.
Todays test went well ran it at 2450 for 1. 2 hour mostly over the water however at high 70 F
Sealed my baffles tight all holes with rtv.
Will test again Friday at
86-88 F.
John
------Original Message------
Sender: mike.davis@dcsol.com
ReplyTo: rebel-builders@dcsol.com
Sent: Aug 20, 2008 2:54 PM
Subject: RE: [rebel-builders] Elite Heat
Hi John
Steve W
WALTER KLATT
OK, if your cooler is baffle mounted, then I would suspect that your bottom outlet is not big enough. Your cruise CHTs are a little high too, which could be the same problem.
If you have a flow volume problem through your cowl, I think closing the filter duct and redirecting that flow to the cooler would do more good. If your outlet was bigger, then the flow to the filter might have helped a little more.
Is your cruise speed a little slower with the Borer compared to the Sensenich? Your engine may also be utilizing more power with the Borer, which then translates into more heat.
What's the induction mod look like on your inlets?
Date: Wednesday, August 20, 2008 2:43 pm
- see 200-205.
John
Hi Bob,
row
7
firewall
Tks
John W
Post by Drew Dalgleish » Sun Feb 19, 2012 7:51 pm
At 10:04 AM 8/20/2008 -0700, you wrote:
Hi Bob,
Tks
John W
I couldn't get my engine to cool properly until I moved the cooler from the
firewall to the rear baffle. Check out a cherokee and install the cooler
the same way as piper does. I also lowered my temps by using ceramic header
tape on my exhaust.
chileman88
Tks Drew
Sent: Aug 20, 2008 5:40 PM
Hi Bob,
Tks
John W
tape on my exhaust.
Post by Bob Patterson » Sun Feb 19, 2012 7:51 pm
Hi John !
Sorry I'm late getting back ! Cutting a larger hole in the bottom
definitely made things worse !! It will help if you enlarge the outlet
by going down 4" or more, AND extending the bottom rearward,
so it ends a couple of inches BEHIND the firewall. This prevents
a backflow of air into the bottom of the cowl, and promotes suction.
The other thig that will help is to smooth the airflow over that
lip at the bottom of the firewall - ideally, you'd wrap a sheet of
aluminum all the way across, to 6" above the bottom, that wraps
down, over the lip, and onto the belly. That's almost impossible to
do after building, so I used metal body repair tape to cover that
area as much as I could, working around the mounts, gascolator,
etc. - This is standard procedure on all RV's -- they gain at least
5 mph, and cooler engines !!
If I understand you, you are taking 4" scat tubes off of BOTH
sides .... I would only take ONE, down to the oil cooler -- you
might be taking too much cooling air out ....
If you can find a picture of the bottom of Walter's old O-320
cowling, THAT worked better than any I've seen ! It looks a bit
like a bullfrog, but hey, it cools !! :-)
I have added a chute to the bottom of my cowl, so I can drop
it down for hot weather, and close it for cooler .... it's just metal
in a U shape, with straight sides. Two bolts hold the sides, in
one of 3 positions ... The chute starts behind the carb, and extends
a couple of inches behind the firewall, and has a small (1.5") lip
at the bottom rear.
Sounds like you are very close to comfort already !
If your CHT sensors are the 'under-plug' type, and are
on the bottom of the cylinder, they already read about 40 degrees
hotter than the real, probe-type CHT sensors.... so maybe you
are OK now ... You can see this by moving the sensors to the
plugs on top of the cylinders ...
bobp@prosumers.ca
On Wednesday 20 August 2008 17:04, John W wrote:
Hi Bob,
Tks
John W
Post by Walter Klatt » Sun Feb 19, 2012 7:51 pm
Yes, Bob, I ended up with that big opening on my old 320 cowl, to get better
cooling on hot days for long climbs. After about the 4th iteration, it was
adequate, but didn't get really good, until I opened up the inlets as well.
That lowered by CHTs by about 40 degrees.
On my new 360 cowl, I have a big lower opening, too, but it looks a lot
better than my last one. This one seems to be cooling a lot better already,
so with a little more tweaking, I should be OK without having to open the
inlets.
Interestingly with Dennis' new Elite, he did his own cowl with big inlets
(see the pic), but a small lower opening (much smaller than mine). Yet his
cooling is good. So despite popular wisdom on this subject, I believe that
the inlet size contributes more to cooling than the size of your outlet. A
bigger outlet, though, will help if your inlets are too small, to a point,
as I found out with my old cowl.
Another difference might be prop spacing. My old 320 had a 1.75 inch spacer,
while my 360 has 2.5.
Speed makes a big difference, too. As I said before, going into reflex will
lower my CHTs. And of course a wheeled plane usually has no problem with
heat.
Patterson
Sent: August 20, 2008 5:27 PM
Hi John !
at the bottom rear.
bobp@prosumers.ca
Hi Bob,
Tks
John W
Please post some pics of your cowl, Walter !!
I'm sure all would like to see them !
bobp@prosumers.ca
better cooling on hot days for long climbs. After about the 4th iteration,
it was adequate, but didn't get really good, until I opened up the inlets
as well. That lowered by CHTs by about 40 degrees.
already, so with a little more tweaking, I should be OK without having to
open the inlets.
spacer, while my 360 has 2.5.
will lower my CHTs. And of course a wheeled plane usually has no problem
with heat.
Patterson
Hi John !
at the bottom rear.
bobp@prosumers.ca
I haven't taken any pics of it yet myself, although I know lots of others
have. Maybe someone on the list has one (Garry?). In any case, can do, just
have to remember to take my camera next time to the hangar.
Patterson
Sent: August 20, 2008 6:52 PM
bobp@prosumers.ca
open the inlets.
with heat.
Patterson
Hi John !
at the bottom rear.
bobp@prosumers.ca
OK, just had someone send me some pics of my plane with the new cowl. I
posted the files, so again just click on new files to see them.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Walter
Klatt
Sent: August 20, 2008 7:13 PM
Patterson
bobp@prosumers.ca
open the inlets.
with heat.
Patterson
Hi John !
at the bottom rear.
bobp@prosumers.ca
