[rebel-builders] Headliner - MAMs and Others
Gary you may have problems with the sky lights and the headliner MAM tells
you not to cut them till you have the liner so they will line up properly..
Dale SR-033
Dale SR-033
Just want list price for it from man, not in box any more as it takes up to
much space, also have the black mounting rubbers and 2 sided tape for
mounting
Gustafson
Sent: Wednesday, February 21, 2007 7:57 PM
Subject: RE: [rebel-builders] Headliner - MAMs and Others
How much are you asking and is it in the original packing boxes?
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of mike
jones
Sent: Wednesday, February 21, 2007 6:21 PM
Just don't want to spend the time to install it, want to finish this dam
thing
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jean
Poirier
Sent: Wednesday, February 21, 2007 1:30 PM
Why are you selling it?
Jean Poirier
Pr
mounting
Gustafson
jones
thing
Poirier
Jean Poirier
Pr
Located in Toronto, price is list price, plus shipping if any
jean.poirier@oxyportneuf.com
Sent: Wednesday, February 21, 2007 6:25 PM
Hello Mike 007
Where are you located and how much?
Jean
Rebel 747R
On Wed Feb 21 18:21 , 'mike jones' <mfjones001@cogeco.ca> sent:
Hello Mike 007
Jean
Rebel 747R
[mike.davis@dcsol.com','','','')">mike.davis@dcsol.com] On Behalf Of JeanJust don't want to spend the time to install it, want to finish this dam
thing
Poirier
Jean Poirier
Pr
Have you buy it recently?
Jean Poirier
Pr
Jean Poirier
Pr
Gary and others: The Rebel interior photos are from my Rebel 652. I just
added another photo (Rebel interiors or "new") for more detail. This is the
2" foam with fabric glued on. I don't see why this would not work with
skylights by tapering the openings, however may have to glue to roof around
skylight to keep in position. I will find out later when I get Rebel 192/731
to that stage as I am adding lots of skylights. The door/window latches are
simple lift up designs by knob on inside and button on the outside. The lock
merely swings the tab into a slot on the exterior push button shaft to
prevent movement. I only put the lock on the pilot side. Passenger/co-pilot
door/window can only be opened from inside. I do not have any detail
pictures of lock assembly but if the need is there, I could sketch out the
design from memory. Bob J
Sent: Wednesday, February 21, 2007 8:23 PM
That is a nice photo and a nice job. Looks professional.
However, I have two questions of the photo.
First, I have 8 skylights in my Rebel and it seems that there
would be a lot of fitting to accommodate the skylights, preferably
having an angle or cone away from the skylight. I guess one could
hot wire cut cone shape openings for each skylight and make it
look just as nice. Looks as if you tried that a bit for the side
windows. I bet it is quiet in there.
Second questions is the door latch. I note a push button and a
key lock on the bottom of the wing fairing and latching mechanism
in the middle of the door frame. I am intrigued by what the mechanism
might be and how it works. Might you also post some pictures of
the door latch and explain how it works. I bet a lot of us are
scratching our heads about door latches for the top window (I am
nearly bald) and this might be useful to many of us.
Thank you (and a lot of others) for sharing hard gained knowledge.
Gary Gustafson
Rebel #242
Nice photo in the file section whoever posted it.. Gives me something to
think about.. Could work in the Moose.. Dale SR-033
Very nice job! It will probably my way... 3 questions:
1- have you prime the aluminium under the foam?
2- never had condensation between foam and aluminium
3- the foam is not glue to aluminium, just the strip keep it in place?
Jean Poirier
Pr
Jean Poirier
Pr
I should not have a problem as my skylights are small
in size and are centered in the middle of each section of
panel. I tried to take that into account by looking at
pictures of other installed MAM headliners.
Thanks for the heads up.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Dale
Fultz
Sent: Wednesday, February 21, 2007 9:10 PM
Subject: Re: [rebel-builders] Headliner - MAMs and Others
Dale SR-033
Fultz
Dale SR-033
I am impressed with the headliner and I think that I
can make it work with my skylights by using a piece
of Velcro glued to the skin and a piece on the fabric.
I hope that it comes out as well as yours did. I think
it is impressive looking and practical for sound.
The door/window latches are a nice touch and simple
once you are given the idea. I think I can make that
work very nicely also. Thank you very much for your
ideas and allowing us to copy them.
Gary Gustafson
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Robert
Johnson
Sent: Thursday, February 22, 2007 8:51 AM
Gary Gustafson
Johnson
Gary Gustafson
Rebel #242
3-4 years ago, just to much work to put it in, it does look great when put
in I must admit
Poirier
Sent: Thursday, February 22, 2007 8:24 AM
Jean Poirier
Pr
in I must admit
Poirier
Jean Poirier
Pr
Bob,
Could you give a source, brand name, or other information describing the
"...2" fire retardent flexible foam..." that you used in your headliner? It
looks quite good.
Roger Hoffman #687R
Eugene, OR USA!
looks quite good.
Roger Hoffman #687R
Eugene, OR USA!
Hi Roger: The foam I used comes from a fabric store called "Fabric Land" .
It is a pale green in color and will not support combustion. If exposed to
an open flame it will shrivel up or shrink but will not continue to burn
when the flame is removed. There was no trade name I know of but I will
check with the store next time I pass. It is also available in various
thickness - 1/2", 1",2" and even 4". - More info to follow. Bob J
Sent: Thursday, February 22, 2007 11:58 PM
Bob,
It
looks quite good.
Roger Hoffman #687R
Eugene, OR USA!
