[rebel-builders] Engine mount
Post by Wayne G. O'Shea » Sun Feb 19, 2012 2:34 pm
Can't remember Jean. Was that engine conical or dynafocal mounting?
From: "Jean Poirier" <jean.poirier@oxyportneuf.com>
Sent: Monday, January 08, 2007 8:36 AM
Subject: [rebel-builders] Engine mount
[quote]Hello
I am looking for a Rebel engine mount for a Lycoming 0-235.
Jean
Rebel 747R
Jean Poirier
Pr
Jean Poirier
Post by Jean Poirier » Sun Feb 19, 2012 2:34 pm
Oups..
It is for 0-235C1 . I think they call that conical. The mounts are 90
degrees with the crank direction... not at angle... Like my 0-200 in my
C-150... Do you understand what I mean?
Jean
Rebel 747R
Jean Poirier
Pr
Flat face to bolt engine to = conical mount Jean. Angled = Dynafocal
There are two versions of the conical. The original for using the nose bowl
and doors cowling and then an updated one that was redesigned so that
conical mount engines would fit up inside the speed cowling. I believe it
was made with the engine 1 1/2" higher or similar than the original. Walter
probably knows exactly as that is what he has on his Rebel!
Can't help you with a mount, I only have a dynafocal tucked away for a rainy
day..... that currently is not for sale before anyone asks.
Sent: Monday, January 08, 2007 4:45 PM
Subject: RE: [rebel-builders] Engine mount
[quote]Oups..
Jean
Rebel 747R
Jean Poirier
Pr
Jean Poirier
Hep..
If I remember when I was looking before ordering the kit, Bob P. recommend
me the standard cowl saying it was easier to work with and the speed lost
was not significant. I have already buy a nose bowl at the last Sun'Fun
from an Ontario guy who was making Cup copy (he did sale the company to the
people of "Turbin Legend" or "turbin Cub". What will be your choice today?
Jean Poirier
Pr
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 2:34 pm
Yes, that's correct. There were 2 versions of the conical mount. The 2nd one raised the engine 1.5 inches higher. What I don't know, is exactly which one MAM sells today, or maybe they still have both.
Date: Monday, January 8, 2007 1:57 pm
Subject: Re: [rebel-builders] Engine mount
nose bowl
that
believe it
original. Walter
for a rainy
Oups..
mounts are 90
200 in my
Jean
Rebel 747R
Jean Poirier
Pr
Post by Bob Patterson » Sun Feb 19, 2012 2:34 pm
Hi Jean !
The 4 door cowl is still MY choice ! :-)
http://www.prosumers.ca
On Monday 08 January 2007 22:06, Jean Poirier wrote:
[quote]Hep..
Jean Poirier
Pr
jean.poirier
Post by jean.poirier » Sun Feb 19, 2012 2:34 pm
Hello Bob
On their web site, MAM just show one conical engine mount, probably the one for speed cowl. I will ask them tomorow... Do you have a part
number for the "standard one" ?
Jean
Rebel 747R
On Mon Jan 8 19:07 , Bob Patterson <beep@sympatico.ca> sent:
[quote]
Hi Jean !
[quote]Hep..
Jean Poirier
Pr
Post by Wayne G. O'Shea » Sun Feb 19, 2012 2:52 pm
Rare as hen's teeth Jean.....but worth a shot to ask here on the list. 95%
of the mounts that left the factory are/were dynafocal.
Randy recently ordered one from Steve for his fuselage and it's supposed to
be here mid March, so I can attach to same......and it had better.......
Sent: Wednesday, February 21, 2007 5:00 PM
[quote]Hello
I am looking for Lycoming conical engine mount for a Rebel (part number
E-79). Let me know if you have one for sale.
Jean
Rebel 747R
Jean Poirier
Pr
Nancy Puff
Post by Nancy Puff » Sun Feb 19, 2012 2:52 pm
Hi Jean
The part # is E-77 for the Conical Mount Rebel/ Elite 477.83 USD @ Murphy
There are no Rings required for this one and is easier to get made.
But Wayne is right the most common one is the Dynafocal
Nancy
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jean Poirier
Sent: Wednesday, February 21, 2007 2:00 PM
Hello
E-79). Let me know if you have one for sale...
Jean
Rebel 747R
Jean Poirier
Pr
Nancy...are they still making two different ones or just a single style of
the conical to cover both cowlings. The original conical was for the nose
bowl and doors cowling and later they realized that to fit a conical engine
into the speed cowling (that was laid up using a dynafocal engine)....it had
to be made 1.5" higher to the engine center line than the original conical
mount. That 1.5" makes a big difference in the look of the cowl when using
the nose bowl and doors. I can tell an old conical mount Rebel and a
dynafocal mount Rebel from 500 feet away when both have the nose bowl and
doors cowling...........and I really prefer the ability to slop the nose
down to the nose bowl away from the windshield with the old mount. The
newer/higher conical and the dynafocal mounts both make the nose bowls top
edge pretty much level with the windshield bottom..ie no slope away to the
nose.
Sent: Wednesday, February 21, 2007 5:38 PM
[quote]Hi Jean
Nancy
Poirier
Hello
Jean
Rebel 747R
Jean Poirier
Pr
jean.poirier
Post by jean.poirier » Sun Feb 19, 2012 2:52 pm
Hello Nancy
I know, thanks.
Jean
On Wed Feb 21 17:38 , 'Nancy Puff' <nancy@rotech.ca> sent:
[quote]Hi Jean
Nancy
From: mike.davis@dcsol.com [mike.davis@dcsol.com','','','')">mike.davis@dcsol.com] On Behalf Of Jean Poirier
Hello
Jean
Rebel 747R
Jean Poirier
Pr
Nancy Puff
Hi Wayne,
They are not making two different ones it is the same conical mount they made before
Darryl says that the Conical mount will work with the new High Speed cowling it was modified to fit both.
I can't say from personal experience however.
Nancy
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Wayne G. O'Shea
Sent: Wednesday, February 21, 2007 2:57 PM
Nancy...are they still making two different ones or just a single style of the conical to cover both cowlings. The original conical was for the nose bowl and doors cowling and later they realized that to fit a conical engine into the speed cowling (that was laid up using a dynafocal engine)....it had to be made 1.5" higher to the engine center line than the original conical mount. That 1.5" makes a big difference in the look of the cowl when using the nose bowl and doors. I can tell an old conical mount Rebel and a dynafocal mount Rebel from 500 feet away when both have the nose bowl and doors cowling...........and I really prefer the ability to slop the nose down to the nose bowl away from the windshield with the old mount. The newer/higher conical and the dynafocal mounts both make the nose bowls top edge pretty much level with the windshield bottom..ie no slope away to the nose.
[quote]Hi Jean
Nancy
Poirier
Hello
Jean
Rebel 747R
Jean Poirier
Pr
Thanks...is what I figured to keep it simple. Most wouldn't know there was
ever a difference...if I'd just shut my mouth! LOL
Sent: Wednesday, February 21, 2007 6:17 PM
[quote]Hi Wayne,
made before
Nancy
[quote]Hi Jean
Nancy
Jean
Poirier
Hello
Jean
Rebel 747R
Jean Poirier
Pr
Nancy Puff
Hey Wayne,
Unless there was some change before I got there
I was told there was only ever one mount
But before they changed the cowling it only fit the nose bowl.
They did do a lot of work with the new high speed cowling to make it fit both.
I only have 2 cents to contribute you have so much more :)
Nancy
Sent: Wednesday, February 21, 2007 3:26 PM
Thanks...is what I figured to keep it simple. Most wouldn't know there was ever a difference...if I'd just shut my mouth! LOL
[quote]Hi Wayne,
made before
Nancy
[quote]Hi Jean
Nancy
Jean
Poirier
Hello
Jean
Rebel 747R
Jean Poirier
Pr
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 2:52 pm
Some day it would be interesting to compare my conical mount to a current one. It was my engine that was brought into MAM many years ago, to fit a new conical mount for the speed cowl. The original one was 1.5 inches lower. I assume, but am not sure if mine is the current one. They also made a new bottom cowl with my engine, with the carb centered. Not sure if that is still used either. I do remember, and also quite a few years ago, walking through the factory with Robin, and found a few old moulds in a back room for the high speed cowl. One of them was for my engine.
But if I ever go to a clone 0360, will have to decide if I want to stick with my old conical mount and whether I will need a new cowl.
Date: Wednesday, February 21, 2007 3:39 pm
Hey Wayne,
it fit both.
Nancy
Of Wayne G. O'Shea
Hi Wayne,
mount they
made before
Speed
Nancy
Behalf Of
single style of
the nose
conical
dynafocal
line than
the look
old conical
both have
the ability
with the
both make the
bottom..ie no
Hi Jean
USD @ Murphy
Nancy
Behalf Of
Jean
Poirier
Hello
(part number
Jean
Rebel 747R
Jean Poirier
Pr�sident
Oxyg�ne Portneuf Inc.
username "rebel"
password "builder"
