[rebel-builders] Bingelis book recommendation?
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 11:30 am
Ben,
Although I'd highly recommend both, the FWF may be more relevant to
actual building.
bransom@dcsol.com wrote:
I'm adding a couple misc things to an A/C Spruce order, thought I'd get a
Bingelis book, partly for knowledge, partly for inspiration. There are two
with rather similar descriptions.
Firewall Forward
Bingelis on Engines
Anyone recommend one over the other?
-Ben
Tim Hickey
Post by Tim Hickey » Sun Feb 19, 2012 11:30 am
Ben:
Those books are a great source of information. The Firewall Forward would be
the best, I believe, but you should also get the Sportplane Builder, and
Sportplane Construction. If you can only afford one, get the Sportplane
Builder. And drop hints for Christmas for the other two. I do not have
Bingelis on Engines, so I can't say much about it. But the other three are
almost required reading.
Tim Hickey
808R (maybe)
Sent: Monday, December 11, 2006 1:02 PM
Subject: [rebel-builders] Bingelis book recommendation?
two
Firewall Forward
Bingelis on Engines
-Ben
Post by Drew Dalgleish » Sun Feb 19, 2012 11:30 am
I have all 4 books and recommend them all although tony on engines is
mostly a rehash of firewall forward. In firewall forward he mostly uses
continental engines for examples and in tony on engines he uses his
lycoming instalation in an rv6 as the example. If you're only going to get
one book I think firewall forward is the better choice.
At 02:06 PM 12/11/2006 -0600, you wrote:
Ben:
Tim Hickey
808R (maybe)
two
Firewall Forward
Bingelis on Engines
-Ben
Keith Leitch
Post by Keith Leitch » Sun Feb 19, 2012 11:30 am
If you are an EAA member they usually have a
discounted price if you buy the set. Seems to me it
was around $70.00 for the set of four.
Keith
tony on engines is
engines he uses his
choice.
Ben:
two. I do not have
Tim Hickey
808R (maybe)
recommendation?
two
Firewall Forward
Bingelis on Engines
-Ben
____________________________________________________________________________________
Do you Yahoo!?
Everyone is raving about the all-new Yahoo! Mail beta.
http://new.mail.yahoo.com
bransom
Post by bransom » Sun Feb 19, 2012 11:30 am
Thanks all for the recommendation, will start with Firewall Forward. BTW,
ACS is $20 each, $70 for the set of 4 (EAA or not). EAA.org is $25 each,
80 for 4.
-Ben
Keith
tony on engines is
engines he uses his
choice.
Ben:
two. I do not have
Tim Hickey
808R (maybe)
recommendation?
Do you Yahoo!?
Mike Davis
Post by Mike Davis » Sun Feb 19, 2012 11:30 am
Just thought I'd mention that I have started rebuilding the builders site
book store. Still some work to do, but since I work on this primarily when
I'm not otherwise busy at work it might take a while. ;-) Anyway, and
purchases made here will help support the builders list.
http://astore.amazon.com/rebelbuilderslis
I will also get a link added to the archive site to incorporate it right
into the site.
Sent: Tuesday, December 12, 2006 9:44 AM
Subject: Re: [rebel-builders] Bingelis book recommendation?
80 for 4.
-Ben
Keith
tony on engines is
engines he uses his
choice.
At 02:06 PM 12/11/2006 -0600, you wrote: Firewall Forward would be Sportplane Builder, and one, get the Sportplane two. I do not have But the other three are recommendation? order, thought I'd get a inspiration. There are
----------------------------------------------------------------- https://mail.dcsol.com/login -----------------------------------------------------------------
Do you Yahoo!?
