between 7.5 - 8 US gph) to find the rpm that allows the smoothest running
and fastest airspeed at a given altitude. The higher I go, the more RPM I
need, and the fuel distribution seems to change as well, as indicated by the
EGTs. Where I seem to have more trouble is at the higher altitudes where I
can't get as smooth running without more fuel usage. At 10 or 11K, I
sometimes find myself using 8 or 8.5 US gph, which doesn't make sense,
knowing that the engine is producing far less than 75% power. I also need to
keep reminding myself that the true airspeed is more than my IAS up there,
as it seems slow when I need to push it to get 90 instead of my usual 100 or
105 mph near sea level.
bransom@dcsol.com
Sent: June 26, 2006 12:08 PM
Subject: [rebel-builders] fuel rate
4 EGTs, yes, but I don't quite get how the fuel monitor helps, i.e., you
can't just lean cuz it says it's thirsty. ??
-Ben
EGTs, RPM and ASI, to get the most fuel efficiency and smooth running RPMThis is where my fuel monitor really helps me. It allows me to lean with
at every altitude. I usually cruise at 7.5 US gph where without this gauge
would likely be running at 8 or 8.5 if I just leaned to smooth running.
With my carb, all 4 EGTs don't peak at once, so a little playing around is
always necessary to get the best compromise.
Date: Monday, June 26, 2006 11:04 am
Subject: Re: [rebel-builders] 1800 amphibs
Oh. I just thought it was slower, but I guess if it means driving
aroundin high gear (flatter pitch), it is more power, more gas.
...and dangit,
more $, ...like most fun things
on theI don't know Ben....I could easily burn 9.5US gal/hr with FOKMdifferent engine, or'phibs.
Sent: Monday, June 26, 2006 1:24 PM
under thehad a bigrearthe threeredretracted.> AnyO-ringspositive on theminutes totransitioning on water.keeplove the plane.nose wheellitres/per/hour hours..............Angusleaked worsedremel toolthanfrom beingtothen installeddroppedtogether with onlthepressure holdsy athe cylinderforI'm stillbut------not--------5/9/2006--
