[rebel-builders] B&C oil filter
Mike Betti
Post by Mike Betti » Sun Feb 19, 2012 10:47 am
Thanks Ralph,
I have the Vernatherm from my old filter head. According to B&C if you use
Champion filters .....108 or ....109 they have a built in bypass and also a
drainback valve that allows the filter to be spun off with out it draining
on the ground. I guess it will remain to be seen.
Mike Betti
771E
Sent: Monday, May 08, 2006 8:47 PM
Subject: [rebel-builders] B&C oil filter
The B&C with 1.4 spacer is correct for the O-360A4M on the MAM mount in
the Elite. You will need the Vernatherm as well. Drip free oil changing
is done by breaking the filter loose to hand tight. Then slip a plastic
bag over the filter and adapter while it is removed, catching the oil in
the bag.
Post by Wayne G. O'Shea » Sun Feb 19, 2012 10:47 am
I use a 108 on Howard's and where it may very well have a bypass valve in it
you can sure pour the oil out of it. I'd hate to see the mess if it was
upside down at time of removal.
I understood their means of no mess was to poke a hole in the bottom of the
filter and then let it drain for a couple hours before removing.
Sent: Monday, May 08, 2006 10:14 PM
Subject: Re: [rebel-builders] B&C oil filter
Thanks Ralph,
Mike Betti
771E
changing
the bag.
Bruce Georgen
Post by Bruce Georgen » Sun Feb 19, 2012 10:47 am
You can poke a hole in the filter with an awl, and what 15 minutes while the engine cools off, before removing it.
Bruce G
Sent: May 8, 2006 10:14 PM
Thanks Ralph,
Mike Betti
771E
the bag.
PeoplePC Online
A better way to Internet
http://www.peoplepc.com
Mike Betti
Great..........I like the mess you get when oil runs down the back of the
engine around all those little cracks and crevices and then onto the cowl. I
think you got something there with the hole in it thing.
Sent: Monday, May 08, 2006 9:26 PM
it
Thanks Ralph,
use
draining
Mike Betti
771E
changing
plastic
in
the bag.
Terry Dazey
Post by Terry Dazey » Sun Feb 19, 2012 10:47 am
Hey Mike:
Here is a drain kit form Avery Tools $26.00 U.S.
https://www.averytools.com/cart/searcha ... +drain+kit
Sorry for the long URL.
Terry Dazey
Rebel 662
it
Mike Betti
Thanks for the tip Terry.
Sent: Tuesday, May 09, 2006 1:36 PM
Hey Mike:
Terry Dazey
Rebel 662
cowl. I
in
it
