I have the Vernatherm from my old filter head. According to B&C if you use
Champion filters .....108 or ....109 they have a built in bypass and also a
drainback valve that allows the filter to be spun off with out it draining
on the ground. I guess it will remain to be seen.
Mike Betti
771E
Sent: Monday, May 08, 2006 8:47 PM
Subject: [rebel-builders] B&C oil filter
The B&C with 1.4 spacer is correct for the O-360A4M on the MAM mount in
the Elite. You will need the Vernatherm as well. Drip free oil changing
is done by breaking the filter loose to hand tight. Then slip a plastic
bag over the filter and adapter while it is removed, catching the oil in
the bag.
