[rebel-builders] Corner wrap joints, Rebel
Post by Wayne G. O'Shea » Sun Feb 19, 2012 1:34 pm
I've found as long as you keep the aft edge distance to minimums there is no
reason to do the "plywood and baseball bat" adjustment! If you hold it down
tight while drilling from the center tab out in both directions and then do
the top/side edges it will fit just fine when pulled down with rivets.
Sent: Monday, March 20, 2006 10:21 PM
Subject: [rebel-builders] Corner wrap joints, Rebel
I am working on the upper corner wraps. Where the upper fus 10 (I am using
fus 70s) joins the fus 33 at bulkhead "B" it won't lay down around the
radius because of the taper. The manual shows something involving a
plywood
cutout, but I wasn't sure what they are getting at. Do I need to do some
kind of forming of the radius edge of the fus 70 to make it fit properly,
and if so what is the best way to do it? I am tempted to just ignore it,
because the gap is only visible from inside, but I'm not sure what will
hapen when I rivet it down.
Thanks.
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 1:34 pm
OK, thanks Wayne.
Subject: Re: [rebel-builders] Corner wrap joints, Rebel
Date: Mon, 20 Mar 2006 22:29:33 -0500
no
using
plywood
properly,
Thanks.
N.Smith
Post by N.Smith » Sun Feb 19, 2012 1:34 pm
Hi Jesse
I'd hold the radius tight down with screw down skin pins - not spring ones
when drilling. That way it will be held as flush as possible and not change
much when riveted.
Nigel
745E
Jesse Jenks
Sent: 21 March 2006 03:21
radius because of the taper. The manual shows something involving a plywood
Thanks.
Jesse Jenks
Thanks Nigel,
I have seen those being used for this purpose in several pictures of other
Rebels. Unfortunately, I don't have any. Maybe it's time to order some, or
use the "baseball bat method" as Wayne describes. Come to think of it, I
don't have one of those either. Dang!
Subject: RE: [rebel-builders] Corner wrap joints, Rebel
Date: Tue, 21 Mar 2006 07:03:25 -0000
Hi Jesse
much when riveted.
Nigel
745E
Jesse Jenks
Thanks.
Jim Cole
Post by Jim Cole » Sun Feb 19, 2012 1:34 pm
Hi Jesse, I had the best luck using that great invention - duck tape -
to help keep the corner wrap in place and with addition of an extra set
of hands managed to keep good pressure on the curvature to drill the
holes and then cleco as we went.
Jim
Rebel 333
Jesse Jenks wrote:
Thanks Nigel,
Hi Jesse
much when riveted.
Nigel
745E
Jesse Jenks
Thanks.
N.Smith
Hi Jesse
It's worth getting some red ones (#40) and some yellow ones (#30) before you
start drilling. I messed up both top sides by using ordinary spring cleco's
and when I started riveting the extra pull meant the holes went out of
alignment as I approached the upper and lower edges. 2 new bits from MAM
later I used the screw skin pins and no problems second time around. D'oh
Nig
745E
Jesse Jenks
Sent: 21 March 2006 16:53
Thanks Nigel,
Hi Jesse
much when riveted.
Nigel
745E
Jesse Jenks
Thanks.
Jesse Jenks
Nigel,
Unfortunately I had already drilled one side to #40. I stared at it for a
while, and decided to try something. I cut the end of the fus 33 that is
sandwiched between the bulkhead and the fus 70, so that it resembles the
bulkhead tabs. This allows the fus 33 and the bulkhead tabs to bend out
slightly and mate flush with the inside of the fus 70. Same idea as the
plywood and baseball bat forming, but from the inside. From the outside it
looks perfect, and on the inside now there are no gaps.
Date: Tue, 21 Mar 2006 20:05:58 -0000
Hi Jesse
you
Nig
745E
Jesse Jenks
Thanks Nigel,
Hi Jesse
ones
change
much when riveted.
Nigel
745E
Jesse Jenks
using
plywood
Thanks.
N.Smith
Hi Jesse
Hopefully you are alright. If you start in the centre of the radius and work
out to the upper and lower edges, pulling the layers together as much as
possible before drilling up to #30 you may find it's going to be alright for
you. The rivets will really squeeze the layers together though so screw down
cleco's help to make sure.
Good luck
Nig
Jesse Jenks
Sent: 22 March 2006 03:04
Nigel,
Hi Jesse
you
Nig
745E
Jesse Jenks
Thanks Nigel,
Hi Jesse
ones
change
much when riveted.
Nigel
745E
Jesse Jenks
using
plywood
Thanks.
