switched the pushrods around as Al mentioned, seems to be a better setup.
I'm still not too happy about the stick arrangement though. I cut off my
stick to attain the required throw, 25/15 degrees. Is that what the Rebels
have? What I don't like about it is when I pull it full up, I really can't
roll it right or left for cross wind taxi too easily. If I take some offset
out of the stick, then I need to reach for it in cruise. I'm curious, would
one of the Rebel owners tell me how much stick travel you have measuring at
the top of your stick from fore to aft? I just want to see if the geometry
is the same as the Elite.
Mike Betti
771E
Sent: Sunday, January 01, 2006 10:36 PM
Subject: Re: rudder pedals
Hi Mike !
Maybe it's just the pics, but your brake pedals seem to be sloped
very far forward ... I like to have the vertical tubes on the rudder
pedals and brakes in line vertically, with that line sloping forward
slightly. This gives a good comfortable range ...
But - whatever position suits you -- and works well through
the full range of travel ... is your best bet ! :-)
For the floor - a doubled floor works well. Run a couple of extra
small square tubes from the cross tubes to the firewall, and run a
sheet of .032+ right across, to pick up the edges of the corner wraps.
You can mount everything to the doubled floor if you are ambitious ! ;-)
On Sunday 01 January 2006 08:41 pm, Mike Betti wrote:mountedI think I have the pedals worked out. I see now why the master cylinders
need to mounted to the floor. I also uploaded some pics to E-controls. I
think the pedals are do-able, it's just the manual lacks too much on this
subject. There is no way to install those pedals with the cylindersitemsas instructed and still get the pedals to line up. Next I need to beef up
the floor.
Mike Betti
771E
Sent: Thursday, December 29, 2005 8:37 AM
Subject: rudder pedals
Mike, the rudder pedal location is one of the most frustrating buildattachmentI've found. I do recommend mounting the lower master cylindersoto the floor. What you are trying to achieve is a linkage arrangementIfthat the brake pedals move with the rudder pedals as they move fore
aft so that you can apply the brake when needed but not inadvertantly.floorthey are not, the brake pedals move fore and aft with respect to the
rudder pedals as the rudder is operated.
I also found that the MAM supplied dimensions for the motor mount /cylinderdoubler where the pedals mount is not sufficiently large to mount the
delrin blocks where I needed them and accommodate the lower brakemounts. The new doublers and brake cylinder mounts are still in
fabrication so can't supply dimensions. One thing I am considering is
complete secondary floor with the pedals and brakes mounted on the
bench
and then the assembly with stiffeners installed as a unit. This would
have the advantages of stiffening the flimsy floor as well as easier
assembly on the bench.
Do measure carefully as the rework is a real pain!
