I know the Elite instructions are a little different than the Rebel in this area. The instructions tell you to connect the top of the added bulkhead used for sandwiching the attach bracket to bulkhead A. This would form some what of a triangle in this area. Is this correct?
Mike Betti
771E
Float attach brackets
Hi Mike
I've tied my extra bulkheads to the original at the top using the 9 rivets
at the overlap on each side. A covering strip is then added to the flanges
down to the floor to form a box section - again as stated in the manual.
The attach bracket itself is sandwiched and riveted (not bolted) using the
larger rivets as in the manual.
Nigel
745E
mbetti@up.net
Sent: 30 June 2005 17:03
Subject: Float attach brackets
Mike Betti
771E
Nigel
745E
mbetti@up.net
Mike Betti
771E
Mike:
Another thing is to make sure the holes in the bracket that protrude from
the fuselage are as far from the fuselage skin as possible. That is, the
bracket is sandwiched about as close as it can get to the outer skin. Also,
when you rivet the bulkheads to the corner wraps, make sure they are dead
flat - not warped forward at all. Otherwise, the nut on the float attach
bracket can touch the fuselage skin. At least it can with the brackets
Montana supply. I'm not sure about the Murphy ones.
Al
Al
Thanks for the replies to all. I think I got it under control now.
Mike Betti
Sent: Thursday, June 30, 2005 8:55 PM
Subject: Re: Float attach brackets
Mike Betti
Mike:
Also,
Al
