Inside tail cone skin
Mike Betti
Post by Mike Betti » Sat Feb 18, 2012 1:43 pm
Hi all,
I'm getting ready to install the floor channels prior to the floor skin.
I haven't riveted the lower outside corners in yet and was going to
rivet them once the floor channels are in place. Would I want to leave
the outside corners off to aid in drilling the inside lower corners from
the bottom up? A couple problems come to mind like maybe loosing
alignment of bulkheads by doing this and then the outer corners not
fitting again. Just looking for some ideas, with those small inside
radias to try and hit with a drill bit.
Mike Betti
771E
Schmucker, Del
Post by Schmucker, Del » Sat Feb 18, 2012 1:43 pm
Mike:
I don't recall riveting the inside corner wraps at the radias. I just
riveted on the wide flanges of the channels. I don't think you would
have enough edge material to rivet the inside narrower channels.
Thank you,
Del Schmucker
Information Systems Manager
Keewatin-Patricia District School Board
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
del.schmucker@kpdsb.on.ca
www.kpdsb.on.ca
Mike Betti
Sent: Tuesday, June 28, 2005 6:45 PM
Subject: Inside tail cone skin
Hi all,
Mike Betti
771E
mbetti
Post by mbetti » Sat Feb 18, 2012 1:43 pm
Thanks for your input. You may be on to something, the airplane is strong enough with out a floor so why weaken the bulkheads with rivets in those narrow corners.
Mike Betti
771E
On Thu, 30 Jun 2005 09:51:03 -0500, rebel-builders@dcsol.com said:
Mike:
Thank you,
Del Schmucker
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
www.kpdsb.on.ca
Mike Betti
Hi all,
Mike Betti
771E
