vans engine baffles
Jones, Michael
vans engine baffles
Post by Jones, Michael » Sat Feb 18, 2012 10:10 am
does any one out there who used the vans engine baffle kit recall which kit
they used, there are several and dont know if there will be any major
differances, i would assume the kit for rv-3/4 would work okay
mike#007
vans engine baffles
Post by Drew Dalgleish » Sat Feb 18, 2012 10:10 am
mike#007
I don't know for sure Mike but the rv3/4 have a very narrow cowl so the
baffle sides are likely cut quite low. The rv6 cowl looks a lot more like a
rebel.
K. Oliver
vans engine baffles
Post by K. Oliver » Sat Feb 18, 2012 10:10 am
the rv6 is what I used for my Elite with an O320
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
Sent: Monday, February 14, 2005 1:45 PM
Subject: Re: vans engine baffles
mike#007
rebel.
Alan Hepburn
vans engine baffles
Post by Alan Hepburn » Sat Feb 18, 2012 10:10 am
The RV-6 kit is the one you need. You have to cut it well down above the
front jugs, so there is only about an inch of metal left there (Elite cowl),
and also it has to be cut back at the front, as the RV has quite a deck in
front of the front cylinders (presumably has a longer shaft extension). I
have some pics that I will upload to the Elite area.
If you're using an O-360, you maight also consider their carb air box. I
also used their fiberglass 13" spinner. It's a lot easier to see where to
drill holes through glass than through aluminum!
Al
