New to the group ...
Bob Andrews
Greetings,
Want to introduce myself to the group, and say thanks for making your
archives available for reading. Plan to trailer my recently purchased Elite
home to Libby this weekend. The Elite was ground looped after 42 hrs (just
into Phase II) having only been on the spring gear ... so have some repair
work to do. Plan to install 2200 amphibs right away. Will know the extent
of needed repairs once we start peeling it open in the upcoming weeks.
During the repair phase, I want to incorporate as many Elite related mods as
possible - elevator horns, etc. Its great to know you're out there.
Bob Andrews
Bob Andrews
Bet I can send you some pictures of just what the square tubes look
like........ Did the legs tear out?? Have lots of pics that can help you and
willing to share since you're way over there!
Takes some work...but the square carrythroughs and FUS-2 gussets can be
removed in one piece and then replaced with new in one piece..then the lower
outer floor all replaced...without removing the door posts.
Good luck with the Elite and acquisition
Sent: Monday, January 31, 2005 1:41 PM
Subject: New to the group ...
EliteGreetings,
(justhome to Libby this weekend. The Elite was ground looped after 42 hrs
extentinto Phase II) having only been on the spring gear ... so have some repair
asof needed repairs once we start peeling it open in the upcoming weeks.
Bob Andrews
Hi Bob !
Welcome to the group !!! That was fast ! :-)
With a little luck, we
One other thought as well......If you do indeed need to tear out the
carrythoughs and if the cabin floor is buckled behind them...no reason you
couldn't leave the tabs on the FUS-2's...add the wishbone tubes....add a set
of rear attach fittings at the approriate distance back and switch her over
to some Rebel style "bungee" gear! Guess there's no reason everyone couldn't
do this building an Elite either!
Sent: Monday, January 31, 2005 1:57 PM
Subject: Re: New to the group ...
andBet I can send you some pictures of just what the square tubes look
lowerwilling to share since you're way over there!
repairouter floor all replaced...without removing the door posts.
EliteGreetings,
archives available for reading. Plan to trailer my recently purchased(justhome to Libby this weekend. The Elite was ground looped after 42 hrsinto Phase II) having only been on the spring gear ... so have some
modsextentwork to do. Plan to install 2200 amphibs right away. Will know theof needed repairs once we start peeling it open in the upcoming weeks.
aspossible - elevator horns, etc. Its great to know you're out there.
Bob Andrews
Bob Andrews
Thanks Wayne ... nope the gear didn't get torn off ... they just sorta found
a new place to rest. Thanks for your inputs ... will know more soon ...
plan to work closely with this group through every step along the way to
WOW. Bob.
Sent: Monday, January 31, 2005 11:57 AM
WOW. Bob.
EliteGreetings,
Bob Andrews
Bob Andrews
Thanks bob ... think I've heard "That was fast" somewhere before ... hmmmm
.... like from my wife? ... yep.
... Bob.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Bob
Patterson
Sent: Monday, January 31, 2005 12:01 PM
Hi Bob !
... Bob.
Patterson
Hi Bob !
Bob Andrews
Plan to put it directly on the 2200 amphibs ... but that's not to say that
it will always be on floats. At this point think only the right spring gear
survived unscathed ... but not sure. Configuring for bungee gear may well
be a feasable way to go ... will put that dominio in the stack ... :-)
Thanks, Bob.
Sent: Monday, January 31, 2005 12:16 PM
Thanks, Bob.
EliteGreetings,
Bob Andrews
If they found a "new place to rest" the tubes are probably snookered as
well! Will send you a pic direct so you can compare similarities!
Sent: Monday, January 31, 2005 2:31 PM
Subject: RE: New to the group ...
foundThanks Wayne ... nope the gear didn't get torn off ... they just sorta
anda new place to rest. Thanks for your inputs ... will know more soon ...
WOW. Bob.
EliteGreetings,
Bob Andrews
Bob Andrews
Thanks.
Sent: Monday, January 31, 2005 12:37 PM
WOW. Bob.
EliteGreetings,
Bob Andrews
Bob Andrews
Bob ... roger that, will do ... but being at the very most bottom of this
Elite learning curve, I have not one clue what heavy adapter fitting you're
refering too ... but would bet that Keith does :-)
... Bob
Patterson
Sent: Monday, January 31, 2005 12:30 PM
Leaving the tabs on sounds like a good idea for Bob, as he
... Bob
Patterson
Al Paxhia
Hi Bob,
Welcome to the group, how is Libby treating you?
Al
Sent: Monday, January 31, 2005 10:41 AM
Al
Greetings,
Elite
(just
extent
as
Bob Andrews
Bob Andrews
Hi Al ... great to hear from you ... and thanks ... and Libby is treating us
great !! ... good to be back in the north country again (for me anyway) ...
we all like it here a lot. I'm at the airport (MFC) most every day, and of
course there's coffee at the Amish store at 10am when I can. I stopped
asking Shaun (12 yr old son) if he's ready to move back to Maryland ... said
he was getting real tired of saying NO !! Libby could use some more snow
though ... a bit warm out there ... snowmobiles are spending way too much
time on the trailer for January. This Elite is as close as I can get to
yours for now ... so, with your permission of course, I'll happily settle
for being your lil' brother. By the way ... have you pushed "the button"
yet? (Shaun keeps asking me about it) Bob.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Al
Paxhia
Sent: Monday, January 31, 2005 1:22 PM
Hi Bob,
Al
Paxhia
Hi Bob,
Al
Greetings,
Elite
(just
extent
as
Bob Andrews
Al's saving that button for when the trees are going to eat him and if the
laughing gas is too much for the engine..oh well it wasn't going to be
pretty anyhow LOL !!
Sent: Monday, January 31, 2005 3:39 PM
usHi Al ... great to hear from you ... and thanks ... and Libby is treating
...great !! ... good to be back in the north country again (for me anyway)
ofwe all like it here a lot. I'm at the airport (MFC) most every day, and
saidcourse there's coffee at the Amish store at 10am when I can. I stopped
repairhe was getting real tired of saying NO !! Libby could use some more snow
Paxhia
Hi Bob,
Al
Greetings,
Elite
(just
modswork to do. Plan to install 2200 amphibs right away. Will know the
extent
as
Bob Andrews
Gilles St-Pierre
Bon
welcome to the group, ....!!!
By the way, what is your chassis number
good luck
gilles st pierre
e717
good luck
gilles st pierre
e717
