Lower Forward Corner Wraps Moose
murray
Post by murray » Sat Feb 18, 2012 10:02 am
Hi
MAM tech is closed for a week and I an installing the Lower Forward Corner
Wraps...manual says to overlap the two rows of rivet holes on the lower panel
but the part supplied by MAM looks like it will only cover one hole on the
bottom panel..
Murray
SN237
Al Paxhia
Post by Al Paxhia » Sat Feb 18, 2012 10:02 am
Murray,
I went through three wraps before I figured out that the two hole overlap
only works at the front. I just shaped the wrap to go from two holes down to
a single hole overlap at the back 2 or 3 rivets.
Al
Sent: Friday, January 21, 2005 7:51 PM
Subject: Lower Forward Corner Wraps Moose
Hi
panel
bottom panel..
Murray
SN237
murray
Post by murray » Sat Feb 18, 2012 10:05 am
Al,
Thanks for the reply decided to just make up new wraps that covered all the
holes...good to have a shear and roller will up load a picture or two so
others may see.
Thanks Murray
JACK JOOS
Post by JACK JOOS » Sat Feb 18, 2012 10:05 am
An added comment:--
I also had to do a second set of bottom corner wraps. It really helps and
does a nice fitting job too if you can use a shrinker to "kink" the edge
that fits under the belly band.
Jack
moose SR193
Date: Tue, 25 Jan 2005 21:47:49 -0900
Subject: Re: Lower Forward Corner Wraps Moose
Al,
others may see.
Thanks Murray
