771E
Mike Betti
771E
Post by Mike Betti » Sat Feb 18, 2012 1:02 pm
My kit arrived today, finally, and no damage. I have it all unpacked and
looking at starting the inventory. Looks like that will take a while.
Looking forward to this winter project, can't do anything outside around
here, -20F everynight and 10-20 mph winds to go with it.
Mike Betti
David Ricker
771E
Post by David Ricker » Sat Feb 18, 2012 1:02 pm
Hi Mike
So the fun begins, enjoy & keep us up to date on your progress!
Dave R
Elite583.cjb.net
Mike Betti
David A. Ricker
Fall River, Nova Scotia
Canada
771E
Post by Ken » Sat Feb 18, 2012 1:02 pm
I wasted a lot of time looking for parts when I needed them. Sometimes I
didn't even know what the part looked like that I was looking for.
Wray itemized the parts for his Rebel on a spreadsheet with a short
description and the location where he stored it. His description even
helped me a few times. Anyway you might want to jot a few notes on your
packing sheets as you check off items in case it helps you later.
Eventually I had to get some plastic cases with a couple of dozen cubby
holes each to put the nuts and bolts. I often found that one size
different from the length specified fit better so I needed a selection
anyway.
119R
Mike Betti
brad
771E
Post by brad » Sat Feb 18, 2012 1:02 pm
Mike,
Great news, so far I am enjoying the process of building.
Best advice I was given when I started was to create a list of all parts
and where I put them (even gave all the boxes numbers). So far I haven't
wasted any time looking for parts.
Other best advise was this site.
Have fun.
Brad.
On 1/18/2005 5:51 PM, MBETTI@UP.NET wrote to REBEL-BUILDERS:
-> Received: by dcsol.com (Wildcat! SMTP Router v6.0.451.3)
-> for rebel-builders@dcsol.com; Tue, 18 Jan 2005 17:51:25 -0900
-> Received: from btc3.up.net ([205.242.56.16]) EHLO=btc3.up.net
-> by dcsol.com (Wildcat! SMTP v6.0.451.3) with SMTP
-> id 448060093; Tue, 18 Jan 2005 17:51:23 -0900
-> Received: from mike (dial-cvx1-90-39.tap.up.net [208.4.90.39])
-> by btc3.up.net (8.12.10/8.12.10) with SMTP id j0J2pJjM024274
-> for <rebel-builders@dcsol.com>; Tue, 18 Jan 2005 21:51:20 -0500 (EST)
-> Message-ID: <01a801c4fdd1$bb67a2e0$6f5a04d0@mike>
-> From: "Mike Betti" <mbetti@up.net>
-> Subject: 771E
-> Date: Tue, 18 Jan 2005 20:51:09 -0600
-> X-Orig-MIME-Version: 1.0
-> X-Orig-Content-Type: multipart/alternative; boundary="----
=_NextPart_000_01A5_01C4FD9F.700E28A0"
-> X-Priority: 3
-> X-MSMail-Priority: Normal
-> X-Mailer: Microsoft Outlook Express 6.00.2800.1158
-> X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1165
-> X-Antivirus-Remover: Message filtered with wsAV v2.0.0 Build 001
-> My kit arrived today, finally, and no damage. I have it all unpacked and
-> looking at starting the inventory. Looks like that will take a while.
-> Looking forward to this winter project, can't do anything outside around
-> here, -20F everynight and 10-20 mph winds to go with it.
-> Mike Betti
David Ricker
771E
The spreadsheet is a GREAT idea! We did one with notation for where the
parts were stowed around the house & shop including in which MAM box they
were in (ie we kept some of the cardboard boxes & numbered them). Makes it
easier to find things later when you move on to a new assembly. We use it to
track back-ordered parts as well.
If you want a copy of our Elite specific spreadsheet let me know. It would
be interesting to see if the parts are the same for our very early (583)
Elite.
Dave R
Francine D.
www.elite583.cjb.net
anyway.
119R
Mike Betti
David A. Ricker
Canada
Mike Betti
771E
Thanks, I would like to take a look at it. I already have everything
inventoried and put in various boxes with labels. I also put all larger
pieces seperated on shelving with the pt. no. out front. I have a good start
on the stab, up to the point where I need to dimple the skin in specified
area. The problem I ran into is I need a 120 degree cutter to countersink
the dimples into the thicker aluminum cross ribs. I guess I will be ordering
from Avery monday.
Sent: Saturday, January 22, 2005 8:29 AM
Subject: Re: 771E
it
would
Elite.
Dave R
Francine D.
anyway.
119R
around
Mike Betti
David A. Ricker
Canada
