Setting up shop
Mike Betti
Setting up shop
Post by Mike Betti » Sat Feb 18, 2012 9:53 am
Hi all,
I'm still waiting for my Elite kit to arrive, supposed to be in the next
couple weeks. Any way, I'm in the process of setting up shop for
construction.
When it comes to cutting spars or heavy pieces of aluminum, what is the
cutter of choice? I was thinking of putting a fine tooth blade on my
upright bandsaw? Or how about cut off wheels?
Mike Betti
Setting up shop
Post by Wayne G. O'Shea » Sat Feb 18, 2012 9:53 am
Mike...there will be no spars to cut...at least you better not be! As for
the thicker sheet...by some quality wood blades in widths to suit straight
or curved cuts. Basically any power tool you use for wood working will cut
alum just fine. I use a miter saw for all my channel/angle etc.
Cheers and happy building,
Sent: Wednesday, December 15, 2004 10:40 PM
Subject: Setting up shop
Hi all,
construction.
Mike Betti
LisaFly99
Setting up shop
Post by LisaFly99 » Sat Feb 18, 2012 9:53 am
In a message dated 12/15/2004 9:49:57 PM Central Standard Time,
oifa@irishfield.on.ca writes:
MIKE
Like Wayne said that's about it in a nut shell. I use a band saw a lot on
aluminum, thin fine tooth blade. And a disc / belt combo sander. there's a lot
of radiuses to do, touch it on the sander and clean it up with you're file.
Instead of filing from scratch.
PS- When you use the power miter saw put on some ear protection! Eye
protection is a no brainier.
PDSmith
Setting up shop
What'ya say Phil??
Sent: Wednesday, December 15, 2004 11:00 PM
Subject: Re: Setting up shop
PS- When you use the power miter saw put on some ear protection! > PDSmith
Murray & Carol Cherkas
Setting up shop
Post by Murray & Carol Cherkas » Sat Feb 18, 2012 9:53 am
Hello from Calgary
There are specific jig saw blades made especially for aluminum. Find them
and use them, you'll be glad you did. Of course you aren't going to use a
jig saw for everything. Aluminum sticks in the teeth of the blade making it
a little wider and jamming it up.
Good Luck
Murray
LisaFly99@aol.com
Sent: December 15, 2004 9:00 PM
MIKE
lot
PDSmith
Setting up shop
Go into a Busy Bee tool or similar outfit and buy a jug of oil that you mix
about 30 to 1 with water (gives just enough oil to keep things...like your
tool bed/cutters... from rusting). Used for milling or lathing. Works
wonders and makes the difference of a clogged and burnt mill cutter to one
that stays clean and sharp. Sure it would probably do the same on the saw
blade.
Sent: Thursday, December 16, 2004 9:25 PM
Subject: RE: Setting up shop
Hello from Calgary
it
Good Luck
Murray
LisaFly99@aol.com
MIKE
on
lot
file.
PDSmith
LisaFly99
Setting up shop
In the past there's been a lot of good advise about tools on this list. I
don't remember if this has been mentioned, but a good magnet on a 3 foot broom
stick beats the heck out of a broom for cleaning up those mandrels. Or maybe
it's just a known fact.
PDSmith
Setting up shop
I'm also told, by Brent at MAM, that Doall industrial puts out an awesome
tool wax (Toolsaver) P/N RAM24000001 Bout $12-14 a tube, but lasts a very
long time.
On the water/oil mix I just put it in a 1.99 spray bottle and squirt it on
while cutting. On the mill I can recycle most of it from the bed drain holes
into a small container. On my lathe... someday I'll get my tank and spray
tube functioning....but for now I just squirt and let the stuff drain into
my tank (for use when I do get it hooked up).
Sent: Thursday, December 16, 2004 9:36 PM
mix
blade.
Hello from Calgary
them
it
Good Luck
Murray
LisaFly99@aol.com
MIKE
on
lot
file.
PDSmith
Mike Betti
Setting up shop
Is the shrinker / stretcher a necesary tool in the building of the Elite.
Still waiting for kit,
Mike Betti
Sent: Friday, December 17, 2004 2:06 PM
long time.
holes
mix
your
one
saw
blade.
Hello from Calgary
them
use
making
it
Good Luck
Murray
LisaFly99@aol.com
MIKE
lot
on
there's
lot
file.
PDSmith
LisaFly99
Setting up shop
In a message dated 12/17/2004 5:22:53 PM Central Standard Time,
mbetti@up.net writes:
MIKE
On the Rebel it isn't a must have tool. It does make a few parts easier, but
it really doesn't warrant the price. If you belong to an EAA or RAA chapter
someone probably has one that can be barrowed. On a float kit not the prebuilt
floats it's a must have tool.
PDSmith
setting up shop
Post by Ralph Baker » Sat Feb 18, 2012 9:53 am
Mike,
You will not need a shrinker/stretcher to build your Elite. You will
need a set of fluting pliers.
N.Smith
Setting up shop
Post by N.Smith » Sat Feb 18, 2012 9:53 am
Hi Mike
I haven't started on the wings yet, but on the fuselage the only time I've
used a shrinker is to help the curvature on the bottom of the bottom corner
wraps from the firewall to the cabin area, just forward and under the gear
attach point (taildragger not nosewheel config). I probably could have done
it other ways, but since I have access to a shrinker I thought I'd give it a
try. That's the only place I've come across on the entire fuselage.
Nigel
745E
Derby
Mike Betti
Sent: 17 December 2004 23:22
Mike Betti
long time.
holes
mix
your
one
saw
blade.
Hello from Calgary
them
use
making
it
Good Luck
Murray
LisaFly99@aol.com
MIKE
lot
on
there's
lot
file.
PDSmith
JACK JOOS
Setting up shop
Post by JACK JOOS » Sat Feb 18, 2012 9:53 am
Nigel et-al,
That corner wrap is the same where I found the shrinker to be very useful.
Also, all those sheet metal parts that MAM stamps out a right angle along a
curved surface (wing roots,firewall,top of instrument panel,etc.) and hence
are basically warped by the excess metal existing along the curved flange
can be made flat again by a small amount shrinking along the flange. Of
course you can take out the excess metal with fluting pliers but then
riveting along the hills and valleys is a problem.
Jack
SR193
No.Calif.
Date: Sat, 18 Dec 2004 10:13:30 -0000
Hi Mike
Nigel
745E
Derby
Mike Betti
Mike Betti
long time.
holes
mix
your
one
saw
blade.
them
use
making
it
lot
on
there's
a file.
bosdes
Setting up shop
Post by bosdes » Sat Feb 18, 2012 9:53 am
Kerosene is a good lubricant when cutting aluminum with a bandsaw. Ted Hauri
-------------- Original message from "Wayne G. O'Shea" <oifa@irishfield.on.ca>: --------------
long time.
To:
mix
blade.
To:
Hello from Calgary
them
it
Good Luck
Murray
LisaFly99@aol.com
MIKE
on
lot
file.
PDSmith
Setting up shop
Does it mix well with the brush sparks from a motor?
To: <rebel-builders@dcsol.com>; <rebel-builders@dcsol.com>
Cc: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
Sent: Saturday, December 18, 2004 8:49 PM
Hauri
