Hi guys,
It appears I found a US source for the Canadian Tire spring some have been
using for a tail spring on Rebels. I received it today and it looks
_Exactly_ like the one in the picture in the archives called 04082314.jpg.
I got it at www.lowcosttrailersupplies.com and the part number is WIE3.
The picture in the archives tells where to make the cuts but I have a few
questions - like which end gets the tailwheel, do you leave the bolt holding
the leaves together?, Ditto the clamp, and which end of the third leaf gets
1 1/2 inches cut off. If someone has a good picture of it installed, that
would probably clear things up.
Thanks much!
Joel Jacobs
Rebel 416R
Trailer spring as tail spring
Joel...it will depend how it sits on the airplane and if you have the exact
same spring the fully curled end being cut off is the fuselage end and the
joggled end you cut flush with the second spring is the tailwheel end. You
need to remove sufficient 3rd spring to clear the lower rudder hinge bolt.
There have been a few arguments (I mean discussions) as to whether the bolt
stays in or not... with some people fearing it being sheared or the
tailwheel attach bolt being sheared. Some leave the center bolt and then
slot the second springs tailwheel bolt hole to let it slide a bit in a hard
landing. Others only bolt the tailwheel to one spring and cut the 2nd one
back to do so. Others, like me, have left in the spring retainer bolt and
bolted the tailwheel yoke through two spring leaves with a single AN8 bolt.
I have made MANY hard tailwheel first landings and had no problems...the
choice is yours!
Gotta get to bed...been up since 4am!
Sent: Monday, October 25, 2004 4:21 PM
Subject: Trailer spring as tail spring
choice is yours!
holdingHi guys,
getsthe leaves together?, Ditto the clamp, and which end of the third leaf
Thanks much!
Joel Jacobs
Rebel 416R
Joel,
There is a descriptive photo on Wray Thompson's website at this url:
http://wrayt.tripod.com/leafSpringcuts.jpg
And if you run a mail search in the archives for the following mail from
Wayne O'Shea, read way down into it, you will see his description of how to
modify it.
anyway. Maybe it will help.
Roger Hoffman #687R
Eugene, OR USA!
modify it.
Well I see Wayne has already answered your question, but I will send thisFrom: OIFA@IRISHFIELD.ON.CA
Date: 7/11/2002 2:23 PM
Subject: Re: 3 leaf trailer spring for tailwheel - Rebel
Conference: interim-mrl
Roger Hoffman #687R
Eugene, OR USA!
Thanks Wayne!
It's beginning to make sense now. If I'm visualizing this correctly the
third spring, that is cut to clear the hinge bolt, is not in the saddle
clamp... It's just held on top of the other two springs by the bolt through
the leafs behind the saddle clamp.
I can see where this will help move my CG back!
Joel
Rebel 416R
Sent: Monday, October 25, 2004 10:48 PM
Subject: Re: Trailer spring as tail spring
Joel
Rebel 416R
exactJoel...it will depend how it sits on the airplane and if you have the
boltsame spring the fully curled end being cut off is the fuselage end and the
hardstays in or not... with some people fearing it being sheared or the
bolt.landing. Others only bolt the tailwheel to one spring and cut the 2nd one
beenI have made MANY hard tailwheel first landings and had no problems...the
choice is yours!
Hi guys,
04082314.jpg.using for a tail spring on Rebels. I received it today and it looks
fewI got it at www.lowcosttrailersupplies.com and the part number is WIE3.
thatholdingquestions - like which end gets the tailwheel, do you leave the boltgetsthe leaves together?, Ditto the clamp, and which end of the third leaf1 1/2 inches cut off. If someone has a good picture of it installed,
Thanks much!
Joel Jacobs
Rebel 416R
Think you are visualizing correctly!
I actually take the saddle clamp/wrap around strap off the side shown in the
picture and reinstall it on the otherside (on the tail wheel side of things)
of the retainer bolt to hold the leaves aligned .
Sent: Tuesday, October 26, 2004 1:06 PM
throughThanks Wayne!
thethe leafs behind the saddle clamp.
Joel
Rebel 416R
exactJoel...it will depend how it sits on the airplane and if you have thesame spring the fully curled end being cut off is the fuselage end and
Youjoggled end you cut flush with the second spring is the tailwheel end.
bolt.need to remove sufficient 3rd spring to clear the lower rudder hinge
oneboltThere have been a few arguments (I mean discussions) as to whether thehardstays in or not... with some people fearing it being sheared or the
slot the second springs tailwheel bolt hole to let it slide a bit in alanding. Others only bolt the tailwheel to one spring and cut the 2nd
andback to do so. Others, like me, have left in the spring retainer bolt
WIE3.bolt.bolted the tailwheel yoke through two spring leaves with a single AN8beenI have made MANY hard tailwheel first landings and had no problems...the
choice is yours!
Hi guys,
It appears I found a US source for the Canadian Tire spring some have04082314.jpg.using for a tail spring on Rebels. I received it today and it looks
_Exactly_ like the one in the picture in the archives calledI got it at www.lowcosttrailersupplies.com and the part number is
fewThe picture in the archives tells where to make the cuts but I have athatholdingquestions - like which end gets the tailwheel, do you leave the boltgetsthe leaves together?, Ditto the clamp, and which end of the third leaf1 1/2 inches cut off. If someone has a good picture of it installed,would probably clear things up.
Thanks much!
Joel Jacobs
Rebel 416R
Gee you worded that diplomatically Wayne!
One bolt should make for a softer spring as well if that is desired.
Whichever way you go try not to install it such that a hard landing
pries the spring leaves apart with large forces at the tailpost clamp.
I'd hate to see that clamp fail because it was used in a way that it was
not designed for.
granny Ken
not designed for.
granny Ken
choice is yours!
Hey, I thought I'd done pretty good typing that out...... considering how
long I'd been up for when I posted it!! )
Second leaf shouldn't be a problem with the tail post clamp as only the one
leaf is bolted to the fus bottom...two leaves go through the post clamp and
the retainer bolt for all 3 leaves is pretty close to the post clamp area.
Don't see the leaves seperating enough to cause a problem...at least haven't
seen any evidence of it yet (in 9+ years of flight)
uncle Wayne
Sent: Tuesday, October 26, 2004 4:52 PM
uncle Wayne
exactGee you worded that diplomatically Wayne!
not designed for.
granny Ken
choice is yours!
