Rebel "652"-Wing tanks
Doug Martin
Post by Doug Martin » Fri Feb 17, 2012 8:27 pm
Installing metal fuel tanks check out a couple of items.
1. Make sure to bond (ground/earth) the tank to the airframe, for static
electricty.
2. Pressure test the tanks for pin hole leaks, before use.
3. depending on the size of the tanks, don't for get to baffel internaly
for banks & climbs.
4. Take a look at Cessna 170 and Stinson 108 for tanks that are removable.
At 12:46 PM 11/30/99 -0500, you wrote:
&&"" tank arrangement.-Comments appreciated soon as I am 70% along
with the R. H. wing. Note :I will be powered by an 0320-160 HP.
Doug Martin
greyghost@powernet.net
Tim Carter
Post by Tim Carter » Fri Feb 17, 2012 8:27 pm
Sent: Tuesday, November 30, 1999 3:19 PM
To: 'LisaFly99@aol.com'
Subject: RE: Rebel "652"-Wing tanks
Yes, it has been done by Greg Gould in the Bay Area (somewhere) of
California.
Also, there was a technical bulletin put out by MAM about it. Something
along the lines of "we really strongly do not recommend that".
Tim
#438R
Sent: Tuesday, November 30, 1999 12:05 PM
Subject: Re: Rebel "652"-Wing tanks
If I remember right there was an article in the Rebel Rouser 3 or 4 years
ago
about welded fuel tanks. And somebody had done it. MAM may have had an
article on it. Not sure but I know its bin done. #460 P.S.&L.S.
bjohnson
Post by bjohnson » Fri Feb 17, 2012 8:27 pm
Hi again-After listening to various builders experiencing tank sealing problems, I would like opinions on the following. I have a source that could manufacture welded .050 alum. tanks. They would fit in the (3) bay area between the existing stringers (top & bottom) enabling use of the existing wing skin arrangement. The only structural change would be the removal of the center area of ribs # 2 & 3. The tank would support the remaining rib sections via riveted angles. The tanks would weigh approx. 20 lb each which would only replace the fuel weight reduced due to the smaller tank capacity. Has anyone gone this route or is everyone satisfied with the "pro-seal" tank arrangement.-Comments appreciated soon as I am 70% along with the R. H. wing. Note :I will be powered by an 0320-160 HP.
klehman
Post by klehman » Fri Feb 17, 2012 8:27 pm
Bob
This is more opinion than anything else as I haven't even closed my tanks yet,
but I notice that other aircraft with aluminum tanks are certainly not immune to
leaks. And many of those provide a way to remove the tank for repairs (Cessna,
Zenith,etc.) which would be much more difficult on a Rebel. If you do have a
leak I think it is easier to fix the proseal tanks. Also usually welded tanks
are insulated from the structure to avoid flexing and leaks, not incorporated
into the ribs to encourage flexing and....
Personally I would be much happier selling, purchasing, or flying an aircraft
that 'stuck' fairly close to the plans for the main structure.
LisaFly99
Post by LisaFly99 » Fri Feb 17, 2012 8:27 pm
If I remember right there was an article in the Rebel Rouser 3 or 4 years ago
Post by Wayne G. O'Shea » Fri Feb 17, 2012 8:27 pm
Your following message has been delivered to the 135 members of
the list murphy-rebel@dcsol.com at 19:09:58 on 30 Nov 1999.
Tim and All , The reason MAM said "don't do this", was because people were
hacking out the stringers to put the tanks in! Thus seriously damaging the
integrety of the wing structure and destroying load paths! You won't catch
me in a Rebel with the stringers cut out in the first 3 bays, let alone like
the one aircraft I saw during a Ramble, that had them cut out in the first 3
and also just past the strut in the critical bending area of the wing. Not
the kind of "folding wing" I really would want! Bob has the right idea,
leaving all the original wing structure around the tank and sliding the tank
in between the former sections of the ribs. When I penciled up drawings for
similar, in 1993 I made it so the tank also incorporated the root rib, which
could be bolted between the two spars and the torque tube horn would have
been bolted on instead of riveted to allow pulling the tank, when it started
to leak.(and I knew they would so I scraped the idea and stuck with the wet
wing!) Many aircraft have removable tanks, certified and amateur built and
the tanks always start to leak or weep thru the sometimes porous welds. I
have had to fix every Zenair 701 tank that has been on our field, helped
pull Cessna 172 tanks that where leaking and helped with a Northstar that
started to leak after 8 years of flying, all on welds! All welds where fixed
with Proseal and have never leaked again! Stick with the wet wing. Once you
have prosealed everything tight, it should stay that way. Most leaks in
tanks are rivets that crack when pulled and fuel drips through the mandrel
hole. Easy to fix by taking a dremel tool with small spherical ball bit and
lightly undercutting a ring inside the mandrel hole. Then force proseal into
the mandrel hole with a syringe. Let sit 48 hours before refilling tanks.
When I build Rebel wings the tank adds about 20 hours work to a wing,
compared to one without a tank.(120hr with tank-100hr without) It will take
longer than that to build your jig to make the tank so it fits properly and
trust me, you won't have customers waiting in line to buy the mod or any
other ones for that matter (trust me I know)
Again just my two cents, Wayne
Date: Tuesday, November 30, 1999 6:30 PM
Subject: FW: Rebel "652"-Wing tanks
California.
Tim
#438R
ago
BILNEWKIRK
Post by BILNEWKIRK » Fri Feb 17, 2012 8:27 pm
BOB JOHNSON
I HAVE TANKS CONSTRUCTED EXACTLY LIKE YOU EXPLAINED, EXCEPT THAT THE LEFT
WING IS 3 BAYS (13 GAL.) AND THE RIGHT TANK IS 4 BAYS (18 GAL). I MOSTLY FLY
ALONE SO THE EXTRA WEIGHT ON THE PASSENGER SIDE OFFSETS MY WEIGHT.
I USED THE SUPPLIED TANK CAPS UNDER FORWARD-FOLDING DOORS. BE SURE TO PLUG
THE CAPS VENTS WITH EPOXY OR YOU WILL BE A GLIDER PILOT WHEN THE FUEL LEVEL
GETS LOW . I DID THAT. NOT FUN.
I AM TICKLED WITH THE RESULT.
BILL NEWKIRK
Post by Bob Patterson » Fri Feb 17, 2012 8:27 pm
Sorry for the delay - as usual, straight to the point ....
Stick with the standard tanks ! (not too subtle ! :-) )
If the metal is prepped properly, you will have no problems, and
the tank will never leak. I have owned welded tanks, and bladder tanks -
they ALL leaked eventually, and were difficult & expensive to fix ! I can
tell you horror stories of Rebels with welded tanks ....
ALL commercial aircraft, and ALL military aircraft now use Pro-Sealed
tanks. Even the new Cessnas are doing it, i hear :-) The wet wing system
is "simple, light, and strong" (the Murphy motto ! ) :-)
------------------------------orig.--------------------------------------------
<!DOCTYPE HTML PUBLIC "-//W3C//DTD W3 HTML//EN">
<HTML>
<HEAD>
<META content=text/html;charset=iso-8859-1 http-equiv=Content-Type>
<META content='"MSHTML 4.72.3110.7"' name=GENERATOR>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT color=#000000 size=2>Hi again-After listening to various builders
fit in
use
HP.</FONT></DIV></BODY></HTML>
Tim Carter
OK,
All...I need to give my .02...since this thread is going on for a while...
I did all these mental gymnastics too over the wet wing. I went with the wet wing, suffered through all the proseal mess, and even got an approved mod from MAM to cut inspection holes in each of the three bays on the underside of the wing tank.
Since these inspection hole covers were the last to be sealed, with the wing upside-down, I was able to paint the proseal around all of the top tank skin feying surfaces and rivets as well after the top tank skin was installed.
I pressure tested the first wing to 2 psi with a manometer, and even put freon gas in it and tested all joints with a freon tester, and no leaks.
Now, when the weather changes from cold to hot or vice-versa, and I can still pull the flush Usher non-vented caps off, I get a satisfying whoosh of air (the vent-pipe bosses are still sealed with plugs). No leaks. The tanks are eventually to be vented with a cross-ships vent tube, and on the RH wing there is is a vent from the outboard solid rib to a vent pipe that exits behind the strut (a-la Cessna). I used SealPak polysulfide sealant B grade (spatula consistency) for the feying surfaces, and A grade (paintable consistency) for the topcoat of rivets, etc.
IMHO...do not mess around with the wing structure in order to put solid tanks in. If you prepare the feying surfaces properly (and it is a LOT of work...scuff, MEK, wipe, proseal) you will get a good finished product.
I kept having this dream of the wing collapsing and folding at the root...and I have a six-year-old daughter...
Keep the structure sound.
Tim
#438R
Sent: Wednesday, December 01, 1999 7:13 PM
Hi Bob
I also gave the fuel tanks a great deal of thought while building the wing & like yourself, looked at a number of different ways to build a fuel tank into each wing. However, after much thought, I redesigned how the fuel tanks were constructed, had it approved by MAM, and, finally went ahead with wet wings. The factory has adopted some but not all of the recommendations. I am not saying this to pat myself on the back, as there are alot of talented builders out there from whom I have learned a great deal, but, to reinforce the fact that in the final analysis, the wet wing is the best option. When done properly, following the plans and doing some improvements which will not compromise the original strength built into the wing, the wet wings can be completed with no leaks and give trouble free performance from the beginning.
There is no way that I would accept adding a total of 40 lbs. into the aircraft just because I was uncertain about the integrity of the wet wing design. That is one of the reasons that the popular Glastar is so heavy. I have extra instruments etc. etc. which makes my airplane heavier than others but, I can take them out when the all glass cockpit arrives, (in my dreams), but you would be stuck with the manufactured fuel tanks stuffed into the wing cavities. In my opinion, you could never take the wing apart and put wet wing in later and not compromise on the original strength of the wing. Nobody would ever do this. With an 0320 installed, you do not have the option of adding 40 unnecessary pounds. Take the plunge, don't worry about it and go ahead with it. If you do the tanks as I did and I am sure as more people are doing now, you can test the tanks before closing the wing completely.
The completed job is worth the effort. If you want to have the most fun in your Rebel and blow away all the SuperCubs at your strip, keep the airplane light & close to the plans. Not that I have an opinion!
Best Regards
Brian #328R
From: Bob Johnson [mailto:bjohnson@wsd.wabco-rail.com]
Sent: Tuesday, November 30, 1999 12:46 PM
Subject: Rebel "652"-Wing tanks
James A. Remington
Post by James A. Remington » Fri Feb 17, 2012 8:38 pm
Maule must be doing something right. I've had mine with welded aluminum tanks for
10 years and no leaks yet. I don't know of any Maule that has had leaking tanks
but I sure have heard of a lot of Rebel owners who have had leaking proseal tanks.
Make mine welded aluminum.
jar
<HTML>
<HEAD>
</HEAD>
fit in
use
Post by Wayne G. O'Shea » Fri Feb 17, 2012 8:38 pm
Your following message has been delivered to the 134 members of
the list murphy-rebel@dcsol.com at 20:51:57 on 1 Dec 1999.
I guess it is down to the question of who do you trust the most. Yourself
and helper with Proseal and Rivet gun. Or the welder with his tig torch set
to high or to low when he makes that last overlap weld at the end of the
bead! Wayne
From: James A. Remington <jaremington@earthlink.net>
To: (Murphy Rebel Builders List) <murphy-rebel@dcsol.com>
Date: Wednesday, December 01, 1999 8:38 PM
tanks for
tanks
tanks.
jar
system
could
existing
which
capacity.
tank
<HTML>
<HEAD>
</HEAD>
builders
following. I
fit in
enabling
use
be the
20 lb
tank
70%
Brian Cross
Post by Brian Cross » Fri Feb 17, 2012 8:38 pm
Hi Bob
Best Regards
Brian #328R
Well said Brian, and Yes Bob your completed Rebel(even on amphibs) will blow away every wheel geared 150HP Super Cub out there! My Rebel, when it had only a 100HP flew both faster and slower than the 150 HP, Northstar Prototype ("Improved" Super Cub Clone). So stop playing on your computer and get out in the work shop!
From: Brian Cross <rebelair@idirect.com (rebelair@idirect.com)>
To: Murphy Rebel Builders List <murphy-rebel@dcsol.com (murphy-rebel@dcsol.com)>
Date: Wednesday, December 01, 1999 10:14 PM
Hi Bob
Best Regards
Brian #328R
Tim, It's funny how Kids can change your view on life, isn't it! Wayne (I've got 3)
From: Tim Carter <tlcarter@email.msn.com (tlcarter@email.msn.com)>
To: 'Murphy Rebel Builders List' <murphy-rebel@dcsol.com (murphy-rebel@dcsol.com)>
Date: Thursday, December 02, 1999 2:15 AM
OK,
Tim
#438R
Hi Bob
Best Regards
Brian #328R
Post by Wayne G. O'Shea » Fri Feb 17, 2012 8:39 pm
the list murphy-rebel@dcsol.com at 22:47:24 on 3 Dec 1999.
All, you must remember that a lot of the older Rebels fuel tanks where also
done with RV1410 rivets and not the tank rivets, that some of us older
builders pushed the factory to supply. This is a source of a lot of the tank
leaks. The solid tank rivets can also be a small problem as you will usually
get 2 or 3 in a tank that crack and leak out through the mandrel holes, so
pressure check your tanks before painting your plane or installing the
wings. You can either drill these out and install new ones, or if you don't
want to leave drilled out rivets in the tank, do the dremel and proseal fix
I previously explained. And yes you should all thank Brian Cross for the
tank first, skin later method of building as it guarentees access to leaks
prior to closing the wing(even though I still do the top tank skin last)
I've just done it this way so many times and you can't teach an old dog new
tricks! To pressure test my tanks, I plug all the outlets with plugs, except
one. In this one I install a snifter valve(threaded fitting with air valve,
used for well pressure tanks). Over the fuel filler cap, I elastic band a
Condom. Simply pressurize the tank at snifter valve until Condom looks like
a water tower! It will stay this way for hours if no leaks. Even one rivet
mandrel leak and the condom will immediately start to deflate! If you tank
is tight, the condom, due to atmospheric pressure changes will be out one
day and then inflated inside the tank the next and will stay this way for
weeks.(provided no one has "pin holed" your condoms!) I also fill my tanks
with fuel, prior to placing the top tank skins. This guarentees no leaks in
the bottoms, sides etc., so if the top skin does spring a leak, you can
still fly 1/2 tanks+ untill you get a good day to fix the leak.
Date: Friday, December 03, 1999 10:12 PM
Thanks for the success story, Tim !
Just one small clarification ....
The group here has found the best results with a slightly different
sequence of metal prep -
Clean with MEK, wipe, THEN scuff with ScotchBrite, and immediately
apply ProSeal. You can use a blast of air, but DO NOT WIPE after scuffing,
as you want clean, bare metal for best adhesion, and there might be a tiny
bit of oil on the cloth ...
Another thought - use a separate set of clecoes for areas to be
ProSealed - these are to be stored in MEK or Metal-Sol. Oil on the clecoes
has been the source of some leaks around rivets !
I think most of the stories of leaky tanks date back to before the
factory changed to Brian Cross' method of finishing the tanks, and before
we started using lengths of drill rod to align the tank top when dropping
it into place on top of the ProSeal. There have been many successful
completions lately !
Certainly, the addition of oval inspection holes, either on top, or
on the bottom, is not a bad idea, 'just in case' you might want access
in the future. The factory can give advice on how to install doublers
to make this a safe & effective solution. More than a few Rebel builders
have done this ...
.......bobp
At 11:21 PM 12/1/99 -0800, you wrote:
OK,
wing
skin
B
(paintable
Tim
#438R
Hi Bob
wing
with
recommendations.
improvements
wet
from
the beginning.
others
dreams),
about
more
completely.
Best Regards
Brian #328R
could
which
capacity.
tank
<HTML><HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1">
<META content="MSHTML 5.00.2614.3401" name=GENERATOR></HEAD>
<DIV><FONT color=#0000ff face=Arial size=2><SPAN
class=910000407-02121999>OK,</SPAN></FONT></DIV>
class=910000407-02121999></SPAN></FONT>&nbsp;</DIV>
class=910000407-02121999>All...I need to give my .02...since this thread
is
going on for a while...</SPAN></FONT></DIV>
class=910000407-02121999>I
did
all these mental gymnastics too over the wet wing.&nbsp; I went with the
wet
from
wing tank.</SPAN></FONT></DIV>
class=910000407-02121999>Since
skin
installed.</SPAN></FONT></DIV>
freon gas
leaks.</SPAN></FONT></DIV>
class=910000407-02121999>Now,
pull
the flush Usher non-vented caps off,&nbsp;I get a satisfying whoosh of air
(the
vent-pipe bosses are still sealed with plugs).&nbsp; No leaks.&nbsp; The
tanks
wing
behind
the strut (a-la Cessna).&nbsp; I used SealPak polysulfide sealant B grade
(spatula consistency) for the feying surfaces, and A&nbsp;grade (paintable
consistency) for the topcoat of rivets, etc.</SPAN></FONT></DIV>
class=910000407-02121999>IMHO...do not mess around with the wing structure
in
order to put solid tanks in.&nbsp; If you prepare the feying surfaces
properly
finished product.</SPAN></FONT></DIV>
<DIV>&nbsp;</DIV>
class=910000407-02121999>I&nbsp;kept having this dream of the wing
collapsing
daughter...</SPAN></FONT></DIV>
class=910000407-02121999>Keep
the structure sound.</SPAN></FONT></DIV>
class=910000407-02121999>Tim</SPAN></FONT></DIV>
class=910000407-02121999>#438R&nbsp;</SPAN></FONT></DIV>
class=910000407-02121999>&nbsp;</SPAN></FONT></DIV>
<BLOCKQUOTE style="MARGIN-RIGHT: 0px">
<DIV class=OutlookMessageHeader><FONT face="Times New Roman"><FONT
size=2>-----<SPAN class=910000407-02121999><FONT color=#0000ff
face=Arial>&nbsp;</FONT></SPAN></FONT></FONT></DIV>
size=2><SPAN class=910000407-02121999>&nbsp;</SPAN>Original
Message-----<BR><B>From:</B> Brian Cross
[mailto:rebelair@idirect.com]<BR><B>Sent:</B> Wednesday, December 01,
1999
7:13 PM<BR><B>To:</B> Murphy Rebel Builders List<BR><B>Subject:</B> RE:
Rebel
"652"-Wing tanks<BR><BR></DIV></FONT></FONT>
class=770565202-02121999>Hi
Bob</SPAN></FONT></DIV>
class=770565202-02121999></SPAN></FONT>&nbsp;</DIV>
class=770565202-02121999>I
into
each wing.&nbsp;&nbsp; However, after much thought, I redesigned how the
fuel
with
wet wings.&nbsp; The factory has adopted some but not all of the
recommendations.&nbsp; I am not saying this to pat myself on the back,
as
great
wing is
the best option.&nbsp; When done properly, following the plans and doing
some
performance from the beginning.&nbsp; </SPAN></FONT></DIV>
class=770565202-02121999>There is no way that I would accept adding a
total of
integrity of
the wet wing design.&nbsp; That is one of the reasons that the popular
Glastar
is so heavy.&nbsp; I have extra instruments etc. etc. which makes my
airplane
fuel
tanks stuffed into the wing cavities.&nbsp; In my opinion, you could
never
original strength of the wing.&nbsp; Nobody would ever do this.&nbsp;
With an
pounds.&nbsp; Take the plunge, don't worry about it and go ahead with
it.&nbsp; If you do the tanks as I did and I am sure as more people are
doing
now, you can test the tanks before closing the wing completely.&nbsp;
completed job is worth the effort.&nbsp; If you want to have the most
fun in
airplane
light & close to the plans.&nbsp; Not that I have an
opinion!</SPAN></FONT></DIV>
class=770565202-02121999>Best
Regards</SPAN></FONT></DIV>
class=770565202-02121999>Brian #328R</SPAN></FONT></DIV>
<DIV align=left class=OutlookMessageHeader dir=ltr><FONT face=Tahoma
size=2>-----Original Message-----<BR><B>From:</B> Bob Johnson
[mailto:bjohnson@wsd.wabco-rail.com]<BR><B>Sent:</B> Tuesday, November
30,
1999 12:46 PM<BR><B>To:</B> Murphy Rebel Builders
Rebel "652"-Wing tanks<BR><BR></DIV></FONT>
builders
following.
would
bottom)
structural
The
tank
would
reduced
everyone
soon as
0320-160
HP.</FONT></DIV></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
