drilling the windshield. So far I've got no leaks and the windshield hasn't
started to bow out at the sides like some rebels with fiberglass retainers.
You didn't say which windshield you're using. I bought the formed window
upgrade that probably comes with the new kits. Hope this helps.
At 04:07 PM 10/14/00 -0230, you wrote:
---------*I actually began preparing (trimming, drilling holes and cutting
retainer strips) for my windshield a couple of years ago. Since then,
as we all know, Murphy has revised their windshield installation
procedure which advises against drilling holes into the windshield and
making fiberglass retainer strips all around. Well, now I've completed
the lower fiberglass trim piece and have drilled out the lower flange
for 1/8 rivets but I thought not to drill any more holes into the
windshield and upper flange of the trim piece. I wonder if this would
now cause more stress on windshield since I've already drilled the top
and sides. Perhaps I should continue on with the old procedure and drill
all of the holes. I don't enjoy working with fiberglass and the thought
of making up three more fiberglass retainers is 'stomach turning'. Glad
I'm building a metal airplane!
Thanks.
Clay
Click here for Free Video!!
