Moose/SR level flight attitude
Scott Aldrich
Post by Scott Aldrich » Sat Feb 18, 2012 12:26 pm
Have any of you that are flying measured or noted your pitch attitude in
level cruise flight? Flaps reflex, faired?
Scott
Moose 174
Dick Shotwell
Post by Dick Shotwell » Sat Feb 18, 2012 12:26 pm
Hi Scott,
I don't know the pitch angle but I have noted that our pitot tube is pitched
up slightly. I became aware of this when our AS indicator was reading low.
The pitot tube was installed parallel to the chord so if it is pitched up,
so is the wing. (This is in level, cruise attitude at cruise speeds). When
I realized that it was pitched up slightly I began to wonder if the error in
the AS indicator was being caused by the pitch-up. So far I have done
nothing to correct this. Any ideas?
Dick Shotwell
Moose 096
Sent: Tuesday, August 24, 2004 15:30 PM
Subject: Moose/SR level flight attitude
Scott
Moose 174
Scott Aldrich
I am not sure what the incidence of the wing is? I think I heard 3 degrees
so if your pitot is level with chord it would up in relation to the floor.
Everyone seems to have a different pitot/static setup so it is hard to get
any comparisons.
If all Moose tend to cruise nose high, I am wondering if some more down
thrust (shims) on the engine would be a good idea (before I fit my cowl)??
Scott
Moose 174
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Dick
Shotwell
Sent: Tuesday, August 24, 2004 5:28 PM
Subject: Re: Moose/SR level flight attitude
Hi Scott,
Dick Shotwell
Moose 096
Scott
Moose 174
Post by Bob Patterson » Sat Feb 18, 2012 12:26 pm
Hi Scott !
It can be challenging to get accurate airspeed indications - the Rebels
have had that problem since the beginning. Partly because of the huge range
of angles they can fly at - one solution has been to go to a larger dameter
tube for the pitot (I used 5/16" tubing on 2 Rebels - helped considerably)
Maybe we need a tilting head on the pitot, with vanes to keep it aligned
with the relative wind, like the flight testing setup on new
aircraft !! ;-) :-)
Good thought on the shims - I've heard several people say that the DH
Beaver has problems, especially on floats, unless you change the thrust
line a bit ..... You might want to talk to some folks with lots of Beaver
mod experience - and let us know what they have to say !
any comparisons.
Scott
Moose 174
Shotwell
Hi Scott,
pitched up slightly. I became aware of this when our AS indicator was
reading low. The pitot tube was installed parallel to the chord so if it is
pitched up, so is the wing. (This is in level, cruise attitude at cruise
speeds). When I realized that it was pitched up slightly I began to wonder
if the error in the AS indicator was being caused by the pitch-up. So far
I have done nothing to correct this. Any ideas?
Dick Shotwell
Moose 096
Scott
Moose 174
Ted Waltman
Post by Ted Waltman » Sat Feb 18, 2012 12:26 pm
I too have wondered the same (re engine shims) as even with qutie high
power settings it seems as if I'm flying slightly nose high. Not to
poke fun at you Scott, but I'm not sure what "...level cruise flight..."
means in a Moose <grin>.
This being said, I'm not sure what engineering analysis one would have
to go through to find the optimal angle to mount the engine. Seems like
that study, while very interesting, could be an expensive science
project involving a whole bunch of aerodynamics, wind tunnel tests and
computer time.
None the less, I've looked plenty of times (at my pitot tube and
wing/horizon attitude) in cruise...never, that I recall, has it been
level at any power setting...
Ted
Bill Delcambre
Post by Bill Delcambre » Sat Feb 18, 2012 12:26 pm
Without doing too much thinking about it, might I suggest a different
question to point you to the engine offset solution; Does it require
significant rudder pressure / rudder tab to fly straight? If the engine is
angled up significantly, I'd expect some P-factor to be in play, causing a
need for left rudder or a significant tab. If not, it's probably not a big
deal.
Or, I could be full of bull about this....
Bill
Sent: Tuesday, August 24, 2004 8:33 PM
Subject: RE: Moose/SR level flight attitude
degrees
any comparisons.
Scott
Moose 174
Shotwell
Hi Scott,
pitched
low.
When
in
Dick Shotwell
Moose 096
in
Scott
Moose 174
Post by Walter Klatt » Sat Feb 18, 2012 12:26 pm
The pitot tube on my Rebel is angled down slightly, even in level
flight. This allows it to still register on landings, even with a
high angle of attack. It does not seem to read low in cruise,
though. This did not happen entirely by design, but during one of
my fill-ups a long time ago.
[mailto:mike.davis@dcsol.com]On Behalf Of Bob
Patterson
Sent: Tuesday, August 24, 2004 8:08 PM
Hi Scott !
to keep it aligned
aircraft !! ;-) :-)
say that the DH
change the thrust
any comparisons.
Scott
Moose 174
Shotwell
Hi Scott,
our pitot tube is
Dick Shotwell
Moose 096
Scott
Moose 174
Ted Waltman
Sounds like there's a story there Walter <grin>.
Bob's point about noting what rudder force (if any) is req'd in "level"
flight is a good one. The problem with that, though, is that on my
Moose, for instance, my vert stab is offset slightly to the right to
compensate for P-factor. On the other hand, I saw at least one Moose at
Oshkosh where the vert stab was aligned straight with the fuselage. So,
how does one objectively compare rudder force notes with folks?
Anyway, it seems that the airspeed is relative anyway. We all fly a
flight attitude on takeoff and landings, noting, over time, what seems
to be a good Vx, Vy and approach speed. In cruise, it's relative too;
we get "there" when we get "there." ...or so it seems to me.
I do know that I'm no where even remotely close to the speeds posted on
the MAM site for the Moose. Heck, I'd have to have a JATO rocket on the
side to get to those speeds <grin>.
Ted
Sent: Wednesday, August 25, 2004 7:33 AM
flight. This allows it to still register on landings, even with a high
angle of attack. It does not seem to read low in cruise, though. This
did not happen entirely by design, but during one of my fill-ups a long
time ago.
Patterson
Hi Scott !
to keep it aligned
aircraft !! ;-) :-)
say that the DH
change the thrust
any comparisons.
Scott
Moose 174
Shotwell
Hi Scott,
our pitot tube is
Dick Shotwell
Moose 096
Scott
Moose 174
List archives located at: https://www.dcsol.com/default.htm
Nothing major, but on mine, it is easy to bump the pitot tube
when fuelling on that side if you're not careful. I bent it back
up, but it still has a slight downward slant, which as it turned
out, made for more accurate readings on landings.
Yes, airspeeds are just relative indicators. With mine, when I
did my GPS checks, it reads about 5 mph high (cruising speeds)
near sea level but low when up high. However, it is most accurate
at normal cruising altitudes (about 3500 if I remember
correctly).
[mailto:mike.davis@dcsol.com]On Behalf Of Ted
Waltman
Sent: Wednesday, August 25, 2004 6:56 AM
req'd in "level"
is that on my
to the right to
least one Moose at
the fuselage. So,
We all fly a
time, what seems
it's relative too;
speeds posted on
JATO rocket on the
Ted
even in level
even with a high
my fill-ups a long
time ago.
Patterson
Hi Scott !
to keep it aligned
aircraft !! ;-) :-)
say that the DH
change the thrust
any comparisons.
Scott
Moose 174
Shotwell
Hi Scott,
our pitot tube is
Dick Shotwell
Moose 096
Scott Aldrich
Ted, that would be constant altitude, constant airspeed, but not with me at
the controls :)
Bill, actually you did a lot of thinking as you remembered which way the
prop turns on an M14..
It would seem then that most are cruising nose high whether on floats or
not.
Waltman
Sent: Wednesday, August 25, 2004 6:08 AM
computer time.
Ted
