Thanks Gilles, but what I was asking is why you thought the lower skin
needed reinforcing over the top skin. I was hoping you had some reasoning
for your thoughts! The lower skin is in tension and the top is in
compression (during normal flight loads). The Moose .063 doubler on the top
leading edge area helps to stop the skin from buckling between the rivet
pitch and the large rivets keep it in place to do so. It is also very
important at holding the integrity of the leading edge structure since all
loads off the "floating" main spar need to be transferred to the front
fuselage pickup (unlike a Cessna wing)
Guess I'm just getting a bit concerned after you asked questions about
stringer thickness and skin thickness for the SR/Moose when the best I can
tell you are building an Elite. Maybe it's none of my business to watch out
for you, if you are planning to adlib some design changes, but that's just
the way I am! I have lost too many aviation friends already and don't need
to add to the list. If you are planning any changes to structures I would
suggest that you get a direct okay from Darryl Murphy or at least an
Aeronautical Engineer. Otherwise if you do indeed make structural changes
please at registration of your airplane call it a Gilles Special" and remove
Murphy from the picture. What you MAY have planned could fit into the
"bigger Band-Aid" scenario and when you reinforce one area and make it too
rigid another area (that's likely critical!) is going to crack/buckle or
snap.
I'll leave you alone,
ranchlaseigneurie@hotmail.com>
To: <
murphy-rebel@dcsol.com>
Sent: Saturday, March 06, 2004 10:53 PM
Subject: Re: Moose -SR wing
Wayne, you deserve personal answer
when I was car racing (for 20 years) I always had little modifications
that
made the car safe and easy to drive, for that reason I was quite often
leading the pack. At the time fomula 5000 were as fast as formula 1 at
Silverstone and I felt pretty good turning laps 1/10 of a second faster
than
Ronnie (Peterson)
The only thing that I have ever buckled is my safety belt....the upper
part
of the wing has not reached that point yet...!!!!! ;-)
gilles
oifa@irishfield.on.ca>
Reply-To: <
To:
Date: Sat, 6 Mar 2004 15:35:41 -0500
Tell me why it makes more sense to you!? and if you are "adlibbing"
reinforcements into your Elite?
To: <
Sent: Saturday, March 06, 2004 3:33 PM
Subject: Moose -SR wing
can someone tell me why they add the reinforcemnt on top of the wing
instead
of in the bottom on the the Moose and 3500 SR To me it would make
more
t
p://hotmail.com/enca&HL=Market_MSNIS_Taglines
STOP MORE SPAM with the MSN Premium and get 2 months FREE*
http://join.msn.com/?pgmarket=en-ca&pag ... 034&SU=htt
Archives located at
To contact the list admin, e-mail
mike.davis@dcsol.com
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
