Float strut material
Pretty quiet so thought I'd throw out a "tidbit" for all the guys mounting
their floats this winter/spring.
Had another guy (that I'll leave anonymous till he wants to introduce
himself here!!) come by for a piece of streamline tube after cutting one too
many from the same 12' supplied length.
It is imperative that you cut all three struts for the SAME side of the
airplane from each length. It only leaves a small piece of scrape doing
this. Any other way and you'll be short material.
It is also important that you start at the proper end of the 12' length, or
thanks to the angle cuts you'll end up short as well!!
If you set the full length down on the floor with the rounded (fwd) edge
pointing AWAY from you the front strut for the 1800's gets cut from the end
to the LEFT of you (make sure you get the angle going the right way as well
or you will come up short material as well - measured length from the LEFT
square end will be longer on the fwd edge than rear edge). This angle you
just cut is the bottom of the front strut and then you will need to cut the
square end to the same angle for the top. Then the angle and the remaining
material that you have just cut is pretty close to the angle at the bottom
of the diagonal. Next you would cut the square ended rear strut from the
RIGHT end of the length, leaving you the diagonal piece of material with
enough left for final trimming to length.
I use the 74 X 54 Sensenich on my 150 hp Rebel on 1800 amphibs.
Seems to be well matched and a good all around prop. Static RPM
is 2500 and it will hit 2700+ at full throttle straight and
level. Climb is 2550.
So with 10 more hp the 74 X 56 may have similar performance.
If I was doing it again, though, I would try the 74 X 52 on mine,
because for my type of flying, I would prefer a little more take
off and climb performance. I may then have to increase my cruise
RPM by about 100 or so to get the same cruise speed. Top speed
would likely suffer, but then I don't cruise at full throttle
anyway, so that does not matter.
Good to hear of another Rebel about to fly on floats. You'll love
it, I'm sure.
it, I'm sure.
[mailto:mike.davis@dcsol.com]On Behalf Of Bob
Fisher
Sent: Sunday, December 07, 2003 6:16 AM
Subject: Re: Float strut material
hi all i`m the guy thanks for bringing this to
everyones attention
wayne!
bob fisher nobel ontario rebel 342 0-320 160
hp going on phil
stubley`s mostly built amphibs
question? who out there is using a 74'' sensenich
?( on floats) and what
pitch seems to work well mine is 56'
Sent: Saturday, December 06, 2003 11:02 PM
Subject: Float strut material
all the guys mountingPretty quiet so thought I'd throw out a "tidbit" forwants to introducetheir floats this winter/spring.
Had another guy (that I'll leave anonymous till hetube after cutting onehimself here!!) come by for a piece of streamline
toothe SAME side of themany from the same 12' supplied length.
It is imperative that you cut all three struts forpiece of scrape doingairplane from each length. It only leaves a smallend of the 12' length,this. Any other way and you'll be short material.
orthe rounded (fwd) edgethanks to the angle cuts you'll end up short as well!!
If you set the full length down on the floor with1800's gets cut from thepointing AWAY from you the front strut for the
endgoing the right way asto the LEFT of you (make sure you get the angle
wellmeasured length from the LEFTor you will come up short material as well -edge). This angle yousquare end will be longer on the fwd edge than rearyou will need to cutjust cut is the bottom of the front strut and then
theangle and the remainingsquare end to the same angle for the top. Then thethe angle at the bottommaterial that you have just cut is pretty close torear strut from theof the diagonal. Next you would cut the square endedpiece of material withRIGHT end of the length, leaving you the diagonal*------------------------------------------------------enough left for final trimming to length.
-------------------*https://rebel:builder@www.dcsol.com/default.htmTo unsubscribe from this list go to:
Archives located at*------------------------------------------------------To contact the list admin, e-mail mike.davis@dcsol.com
Archives located at
Hi Bob
Jerry here,if you don't mind I'm curious about the brand of floats you
mentioned Phil Stubley's,any info on floats,size,price,etc would be
appreciated.It will be interesting about info on props out there to.
THANKS
jerry
Sent: Sunday, December 07, 2003 6:15 AM
THANKS
jerry
whathi all i`m the guy thanks for bringing this to everyones attention
wayne!
bob fisher nobel ontario rebel 342 0-320 160 hp going on phil
question? who out there is using a 74'' sensenich ?( on floats) and
mountingpitch seems to work well mine is 56'
LEFTtootheir floats this winter/spring.
himself here!!) come by for a piece of streamline tube after cutting oneormany from the same 12' supplied length.
It is also important that you start at the proper end of the 12' length,endthanks to the angle cuts you'll end up short as well!!
pointing AWAY from you the front strut for the 1800's gets cut from thewellto the LEFT of you (make sure you get the angle going the right way asor you will come up short material as well - measured length from the
yousquare end will be longer on the fwd edge than rear edge). This angle
remainingthejust cut is the bottom of the front strut and then you will need to cutsquare end to the same angle for the top. Then the angle and the
bottommaterial that you have just cut is pretty close to the angle at the
*-------------------------------------------------------------------------*of the diagonal. Next you would cut the square ended rear strut from the
wayne!
question? who out there is using a 74'' sensenich ?( on floats) and what
wayne!
tooPretty quiet so thought I'd throw out a "tidbit" for all the guys mounting
theor you will come up short material as well - measured length from the LEFT
*-------------------------------------------------------------------------*square end to the same angle for the top. Then the angle and the remaining
Yes, even my current 74 X 54 will exceed 2700, but it's the take
off and climb I'm after. That's also why I'm interested in the
Borer.
Looking forward to getting you out here in the spring, Bruce.
Archives located at
Borer.
https://rebel:builder@www.dcsol.com/default.htm-----Original Message-----
Sent: Sunday, December 07, 2003 7:03 PM
Howard's running a 74DM-52 which in my mind is a bit
too fine for his 150HP,
but he is happy with it and I guess that's all the
matters. Pretty sure it
will exceed 2700rpm in level flight but it sure leaves
the water in a HURRY!
Sent: Sunday, December 07, 2003 10:01 PM
right now and mountingHi Bob,
I use a 74x56 metal Sensenich 0320 150HP on wheelsand not over speed.amphibs this winter.
I have to climb to 7500 feet to get full throttle
That'sonly produce 75% powerthe altitude most normally aspirated engines will
on aMPH IAS at 75%. Give ornormal day at full throttle anyway.
It has good climb though, and I can cruise at 120It sure would get outtake.
Walter,
You suggested a 74x52...hmm, that might be to fine.
offor floats. Not surethe water quick. I believe MAM suggests the 56 or 54our engine/plane combo.though. Sensenich does say 56 for a climb prop onthis spring.We will have to do some comparisons with our planes*------------------------------------------------------Bruce
Archives located at
*----------------------------------------------------------------To contact the list admin, e-mail mike.davis@dcsol.com
Archives located at
hi jerry these are murphy floats 1800 with gear i would rather not
say what i paid , but it was a lot!
i hope they will be worth it i`ve been spoiled as i have had two planes
over the past 18 years but both amphibious
bob fisher
Sent: Sunday, December 07, 2003 9:56 AM
bob fisher
oneHi Bob
THANKS
jerry
wayne!
question? who out there is using a 74'' sensenich ?( on floats) andmountingpitch seems to work well mine is 56'
Pretty quiet so thought I'd throw out a "tidbit" for all the guystheir floats this winter/spring.
thetoomany from the same 12' supplied length.
doingairplane from each length. It only leaves a small piece of scrape
edgeorthanks to the angle cuts you'll end up short as well!!
thepointing AWAY from you the front strut for the 1800's gets cut from
cutLEFTendwellto the LEFT of you (make sure you get the angle going the right way asor you will come up short material as well - measured length from theyousquare end will be longer on the fwd edge than rear edge). This anglejust cut is the bottom of the front strut and then you will need to
theremainingthesquare end to the same angle for the top. Then the angle and thebottommaterial that you have just cut is pretty close to the angle at theof the diagonal. Next you would cut the square ended rear strut from
withRIGHT end of the length, leaving you the diagonal piece of material
*-------------------------------------------------------------------------*enough left for final trimming to length.
hi walter thanks much for the info on your prop i guess the best thing
to do is to try it out with the existing prop and if it is too coarse, have
it repitched!
bob fisher
Sent: Sunday, December 07, 2003 9:42 AM
Subject: RE: Float strut material
it repitched!
bob fisher
*-------------------------------------------------------------------------*I use the 74 X 54 Sensenich on my 150 hp Rebel on 1800 amphibs.
it, I'm sure.
Fisher
everyones attention
wayne!
hp going on phil
Archives located at
Hi Bob,
I use a 74x56 metal Sensenich 0320 150HP on wheels right now and mounting
I have to climb to 7500 feet to get full throttle and not over speed. That's
the altitude most normally aspirated engines will only produce 75% power on a
It has good climb though, and I can cruise at 120 MPH IAS at 75%. Give or
take.
Walter,
You suggested a 74x52...hmm, that might be to fine. It sure would get out of
the water quick. I believe MAM suggests the 56 or 54 for floats. Not sure
though. Sensenich does say 56 for a climb prop on our engine/plane combo.
We will have to do some comparisons with our planes this spring.
Bruce
take.
Walter,
Bruce
Howard's running a 74DM-52 which in my mind is a bit too fine for his 150HP,
but he is happy with it and I guess that's all the matters. Pretty sure it
will exceed 2700rpm in level flight but it sure leaves the water in a HURRY!
That'sHi Bob,
on athe altitude most normally aspirated engines will only produce 75% power
ofnormal day at full throttle anyway.
take.
Walter,
*-------------------------------------------------------------------------*the water quick. I believe MAM suggests the 56 or 54 for floats. Not sure
Bruce
Wayne,
I hear the parts of the North East are getting as much as 3 and 4 feet of
snow fall. Did you receive that much snow fall? How long does it take to remove
the wheels or floats and mount your ski's on the Rebel?
Bruce
Bruce
Yup, that makes sense. You are over revving with the 74 X 56 as I
would expect with 160 hp. I would try it on floats with this
pitch before flattening it to 54. That's what mine is, and it
will over rev slightly on floats with 150 hp. My climb is at 2550
RPM. Which landing gear do you have now, spring gear or bungie?
Fisher
Sent: Sunday, December 21, 2003 1:41 PM
hi walter i tried my rebel yesterday at 2000 ft
-7 degrees c and i
am getting about 2725 to 2750 w.o.t. ( about 130
mph) and that is a 160
hp in good shape ? i think ? 265 hrs!
my impression is that the prop will need to be
flattened a little , 2-4
inches? when i get the floats on this spring
climb out when warmed up is about 2500 at 70mph.
does this make sense to you? bob fisher
Walter,
Archives located at
hi walter i tried my rebel yesterday at 2000 ft -7 degrees c and i
am getting about 2725 to 2750 w.o.t. ( about 130 mph) and that is a 160
my impression is that the prop will need to be flattened a little , 2-4
That'sHi Bob,
take.
Walter,
Bruce
bungie covered with a vinyl bag works good but maybe not as aerodynamic
as waynes springs?
bob patterson noted that the front of my gear legs are not fared ie; flat 1
in square tubing that would slow things down!
anyway it will all be gone in march? i hope. i`m almost ready to paint my
floats, just the sides- gun metal grey flat and the top black? flat
ala the big guys
bob fisher
Sent: Sunday, December 21, 2003 6:23 PM
as waynes springs?
ala the big guys
bob fisher
*-------------------------------------------------------------------------*Yup, that makes sense. You are over revving with the 74 X 56 as I
Fisher
-7 degrees c and i
Walter,
Archives located at
