Float installation - Rebel
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:08 pm
Have posted 6 pictures of FOKM going back on floats. Thought I would show
what I'm up to around here and the fact that you can remove the entire gear
in one assembly c/w with brake lines from the pedal cylinders. This is
especially nice when using bungees as everything stays together. As for the
wishbone butterfly buy a spare one to use for x-cable attachment on 1500's
or to hold the tubes together for 1800's. OR better yet just remove the
x-tubes for a cleaner look and less drag while on floats. Give some thought
to access holes in the cabin floor, for the 5/16 bolts/nuts, so you can do
so!!
Post by Drew Dalgleish » Fri Feb 17, 2012 11:08 pm
so!!
When building my rebel I hoped to go on floats someday so I used a pair of
nutplates on the rear main carrythroughs so that I can just pull the bolts
out from the front.
Nobody ever said you were stupid Drew!! Great way to do it and am I to
presume that you cut the carrythru tubes in half to facilitate being able to
put an anchor nut here, or just a bit larger access hole (in the full tube)
to feed the anchor nut in for it's one time installation.
Sent: Sunday, June 01, 2003 11:23 AM
Subject: Re: Float installation - Rebel
show
gear
1500's
thought
do
so!!
out from the front.
I cut my carrythrough tube in half as per the origional plans for bungee
gear but I think it would be possible to fish a nut plate in from the end
of the tube if someone wanted to leave it uncut.
Rebflyer
Post by Rebflyer » Fri Feb 17, 2012 11:08 pm
As for the holes left from the removal of the square tubes, wishbone to carry
throughs, They made a great access for the hydralic lines I thought. Still
looking on how to fair them out, but I'm having to much fun to stop and work.
One other verification, I am getting a positive 100 rpm more with the K+N
filter than the stock brackett. No other change!
Challenger aviation in Ohio is stc ing them for a host of aircraft,
including the Cessna that we need for the Rebel. 84.00 US Curt N97MR
