propeller extension
Murray and Carol Cherkas
propeller extension
Post by Murray and Carol Cherkas » Fri Feb 17, 2012 10:55 pm
Hi ALL:
Lycosaurus 0-320, Murphy aluminum cowling and nose bowl.
DO I NEED A PROP EXTENSION? How long?
Thanks for the help.
Murray Cherkas
REBEL 505
GETTING THERE
propeller extension
Wayne, your vocabulary is so extensive.
Murray
Sent: Wednesday, April 09, 2003 5:38 AM
Subject: Re: propeller extension
NOPE!!!!!!!!!!!!
Sent: Wednesday, April 09, 2003 12:25 AM
Subject: propeller extension
Hi ALL:
Murray Cherkas
REBEL 505
GETTING THERE
propeller extension
Post by Wayne G. O'Shea » Fri Feb 17, 2012 10:55 pm
NOPE!!!!!!!!!!!!
Hi ALL:
Murray Cherkas
REBEL 505
GETTING THERE
propeller extension
Trying to average out the really long bull$h!! emails with some short ones,
to cut down on keyboard time!!! ;o)))
Seriously, if you take about 8 x AN365-1032 or 428 nuts and tape them to
your flywheel face just inboard of the ring gear and then clamp the nose
bowl on top, this will give you the required clearance for motor movement
and you won't need a prop extension in most cases. You can run a 10" spinner
without removing the starter bump in the cowling. If your use a B&C starter
or the Skytec HT you can fill in the bump flush and then you can even run a
13" spinner. If you leave the bump then you need about a 3/4" spacer to
allow a spinner larger than 10"'s to clear the hump.
Sent: Wednesday, April 09, 2003 2:28 PM
Subject: RE: propeller extension
Murray
NOPE!!!!!!!!!!!!
Hi ALL:
Murray Cherkas
REBEL 505
GETTING THERE
propeller extension
Thought I should clarify that this taping of nuts to the flywheel is to
postion the nose bowl in order to build the cowling assembly frame and
doors.
Of course you take them all off when you are done!! ;o))
Sent: Wednesday, April 09, 2003 1:38 PM
ones,
spinner
starter
Murray
NOPE!!!!!!!!!!!!
Hi ALL:
Murray Cherkas
REBEL 505
GETTING THERE
klehman
propeller extension
Post by klehman » Fri Feb 17, 2012 10:55 pm
Any recommendations for the type of resin to use for removing the
starter bump and other modifications to the fibreglass nose bowl? I'm
guessing it's just made of common polyester resin? I may have to make a
new nose bowl for the Subaru but there is still hope that I can get away
with modifying the existing one. :)
propeller extension
Post by Bob Patterson » Fri Feb 17, 2012 10:55 pm
Surprised you're not using the Rotax 912 cowling - several
succesful Subaru conversions have ... It's a good start, and
has the radiator mounts already done. Some have used it stock,
and others - like Geert, have made it easier to work on...
---------------------------------orig.----------------------------
propeller extension
Anything on the shelf at CTC will work just fine!
Sent: Thursday, April 10, 2003 10:36 AM
movement
spinner
starter
run a
