Moose N526AP is back in the air after almost 9 months of rebuild. Flys
great, cyl temps all in the 350 to 375 range, OAT 50* F, fuel burn is a
little high but will work on that later.
One problem, cycled the master switch and blew the SL70 transponder. Don't
ask why I was screwing around with the master switch, but it was not
necessary.
Al
Moose flys again
Moose flys again
Hi Al,
Glad to hear you are back up flying. I'm still doing my research. Most people
have the same comments an opinions about their SR2500/3500's.
Mark Scott
Connecticut.
Mark Scott
Connecticut.
necessary.
Al
Moose flys again
Al,
Any ideas as to why the transponder "blew"? What do you mean by "blew"? is
there an internal fuse that protects the overal assembly? Etc.? Etc.? Etc.?
Please let us know of your troubleshooting and diagnosis.
Good luck, you'll need it,
Rick D.
On 2/1/03 1:31 PM, PAXHIA2@ATTBI.COM wrote to MURPHY-REBEL:
-> From <paxhia2@attbi.com> Sat, 01 Feb 2003 11:22:15 -0900 remote from
dcsol.com
-> Received: by dcsol.com (Wildcat! SMTP Router v5.6.450.6)
-> for murphy-rebel@dcsol.com; Sat, 01 Feb 2003 11:22:15 -0900
-> Received: from sccrmhc02.attbi.com ([204.127.202.62])
EHLO=sccrmhc02.attbi.com
-> by dcsol.com (Wildcat! SMTP v5.6.450.6) with SMTP
-> id 1401641328; Sat, 01 Feb 2003 11:22:12 -0900
-> Received: from paxhia (12-231-32-86.client.attbi.com[12.231.32.86])
-> by sccrmhc02.attbi.com (sccrmhc02) with SMTP
-> id <2003020120220700200i4jo2e>; Sat, 1 Feb 2003 20:22:07 +0000
-> Message-ID: <000701c2ca2f$5be1e600$6501a8c0@attbi.com>
-> From: "Al & Deb Paxhia" <paxhia2@attbi.com>
-> References: <20030201.020216.-249197.0.tlmcclary@juno.com>
-> Subject: Moose flys again
-> Date: Sat, 1 Feb 2003 12:20:26 -0800
-> X-Orig-MIME-Version: 1.0
-> X-Orig-Content-Type: text/plain; charset="iso-8859-1"
-> X-Priority: 3
-> X-MSMail-Priority: Normal
-> X-Mailer: Microsoft Outlook Express 6.00.2800.1106
-> X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1106
-> Moose N526AP is back in the air after almost 9 months of rebuild. Flys
-> great, cyl temps all in the 350 to 375 range, OAT 50* F, fuel burn is a
-> little high but will work on that later.
-> One problem, cycled the master switch and blew the SL70 transponder. Don't
-> ask why I was screwing around with the master switch, but it was not
-> necessary.
-> Al
Rick D.
dcsol.com
-> X-Priority: 3
-> necessary.
-> Al
Moose flys again
Way to go Al! Nice to hear "she" is all back together and working right
again.
Now, why were you screwing around with that master switch while running??
Oops, I wasn't supposed to ask!!!!
Sent: Saturday, February 01, 2003 3:20 PM
again.
*-------------------------------------------------------------------------*Moose N526AP is back in the air after almost 9 months of rebuild. Flys
necessary.
Al
Moose flys again
Congratulations Al !!
I'm sure your back to loving it again !!! :-)
....bobp
------------------------------orig.-----------------------------------
....bobp
necessary.
Al
