DJK to amphibs
DJK to amphibs
Post by Wayne G. O'Shea » Sat Feb 18, 2012 1:38 pm
What's wrong with this picture?? :O)
http://www.irishfield.on.ca/gallery/djkhangerflying.jpg
DJK to amphibs
Post by Drew Dalgleish » Sat Feb 18, 2012 1:38 pm
Looks good Wayne you're about 3 weeks ahead of me :( At your speed you
should be getting it wet by the weekend.
DJK to amphibs
Post by Mike Davis » Sat Feb 18, 2012 1:38 pm
I like those new transparent struts!
To: "Murphy Rebel Builders List" <rebel-builders@dcsol.com>
Sent: Thursday, June 09, 2005 5:31 PM
Subject: DJK to amphibs
DJK to amphibs
Less drag Mike...for a faster cruise!
Sent: Thursday, June 09, 2005 10:27 PM
Subject: Re: DJK to amphibs
DJK to amphibs
Got it to here by 8PM tonight. Rear and front struts made and flying wires
installed front and back (instead of cables - AN674 steamlines)
http://www.irishfield.on.ca/gallery/djktofloats.jpg
Hope to get the diagonals installed tomorrow (already cut to length) and the
hydraulic lines run thru the struts. Going to be a little longer than the
weekend though Drew. Got a nieces wedding to attend this weekend just to
mess up my plans! (I hear my son grumbling as well...he's gotta go too!)
Sent: Thursday, June 09, 2005 10:22 PM
DJK to amphibs
I'd be afraid of mis-stepping while climbing into the cockpit, and end up
taking a swim!
Sent: Thursday, June 09, 2005 6:31 PM
Legeorgen
DJK to amphibs
Post by Legeorgen » Sat Feb 18, 2012 1:38 pm
Wow, Wayne. I bet that saves you 30 or 40 lb. That should translate into 20
or 30 HP. Looking good!
Bruce
DJK to amphibs
Post by Walter Klatt » Sat Feb 18, 2012 1:38 pm
What degrees are you shooting for on your throat angle, Wayne?
Sent: Thursday, June 09, 2005 7:38 PM
At your speed you
DJK to amphibs
I set it at about 2.9 to 3 degrees.... Float top to cabin bottom.
I can come up a hole on the front (or down a hole - did bottom fitting so it
can be dropped a hole and top so it can be raised a hole) Back struts can go
down three holes total (1 top, 2 bottom) or up how ever many holes are left
(about 7 I think!)
Sent: Thursday, June 09, 2005 11:20 PM
Subject: RE: DJK to amphibs
At your speed you
At 09:31 PM 6/9/2005 -0400, you wrote: ------------------------------------------------------
DJK to amphibs
Yeah, that should be good to try. Mine is still at 2.5, but Bruce
G. has his at 3.5.
Sent: Thursday, June 09, 2005 8:26 PM
cabin bottom.
(about 7 I think!)
angle, Wayne?
AN674 steamlines)
At your speed you ----------- ----------- -------------------------------------------------------
DJK to amphibs
CYP worked well at 2.7...but I know Howard liked to really fly it on at
speed and I like to slow down a bit more.
Can't for the life of me remember how I set FOKM and it worked/s nice. Garry
can you look in the install notes...bet I wrote it in there.
I figured 3 degrees was a good place to start. Each rear hole changes things
about 0.4 degrees...so I've got lots to play with if required and have easy
x wire adjustment since I used flying wires and not turnbuckles and cable.
Sent: Thursday, June 09, 2005 11:42 PM
G. has his at 3.5.
cabin bottom.
(about 7 I think!)
angle, Wayne?
AN674 steamlines)
Garry Wright
DJK to amphibs
Post by Garry Wright » Sat Feb 18, 2012 1:38 pm
I can't find any reference to mount angle in the tech log. Also no
mention of angle in the journey log where the transition from 1500 to
1800 occurs. Any other suggestions?
DJK looks great on those floats. I bet you have trouble getting around
to taking them off again. : )
G. has his at 3.5.
cabin bottom.
(about 7 I think!)
angle, Wayne? AN674 steamlines) -------------------------------------------------------
Terry Dazey
DJK to amphibs
Post by Terry Dazey » Sat Feb 18, 2012 1:38 pm
And I thought I was trying to save weight! Is that you sitting in the
cockpit? HAHA!
Terry Dazey
Rebel 662
Good shot Wayne.
bransom
DJK to amphibs
Post by bransom » Sat Feb 18, 2012 1:38 pm
What?! I didn't know there was a retractable Rebel! And what the hell is
some fool doing trying to fly through a hangar?
-Ben
DJK to amphibs
Figured I would have put it in the Tech log from when I remounted them as
1800's redoing the front struts. I'll look thru the work log and see if I
put it there and let you know for your own reference.
To: "rebel builders" <rebel-builders@dcsol.com>
Sent: Friday, June 10, 2005 12:45 AM
Garry
things
easy
cable.
G. has his at 3.5.
