I am looking at my fast build Moose wings and they already have a large
aluminum doubler in the aft tip rib position that the wing tip service
bulletin calls for W-1030. Looks like you could just remove a couple of
rivets to cut off the rib flange and slip in the stainless steel angle
W-1031, no need to completely remove the existing doubler or add the new
aluminum one.
Has anyone else done this mod or upgrade to fast build wings yet?
Scott
Moose 174
http://www.murphyair.com/SUPPORT/PDF%20 ... %20MOD.pdf
SR / Moose wing tip mod service bulletin
Scott Aldrich
This may be a double post for some.
aluminum one.
Scott
Moose 174
aluminum one.
Scott
Moose 174
rogerk
I've noticed the same thing on mine. Did anyone ever have an answer to
this question? It looks like the specified doubler already exists.
Roger K
On 4/13/2005 11:31 AM, SA@MWUTAH.COM wrote to REBEL-BUILDERS:
-> I am looking at my fast build Moose wings and they already have a large
-> aluminum doubler in the aft tip rib position that the wing tip service
-> bulletin calls for W-1030. Looks like you could just remove a couple of
-> rivets to cut off the rib flange and slip in the stainless steel angle
-> W-1031, no need to completely remove the existing doubler or add the new
-> aluminum one.
-> Has anyone else done this mod or upgrade to fast build wings yet?
-> Scott
-> Moose 174
-> http://www.murphyair.com/SUPPORT/PDF%20 ... %20MOD.pdf
Roger K
-> aluminum one.
-> Scott
-> Moose 174
