SR / Moose wing tip mod service bulletin
Scott Aldrich
Post by Scott Aldrich » Sat Feb 18, 2012 10:24 am
I am looking at my fast build Moose wings and they already have a large
aluminum doubler in the aft tip rib position that the wing tip service
bulletin calls for W-1030. Looks like you could just remove a couple of
rivets to cut off the rib flange and slip in the stainless steel angle
W-1031, no need to completely remove the existing doubler or add the new
aluminum one.
Has anyone else done this mod or upgrade to fast build wings yet?
Scott
Moose 174
http://www.murphyair.com/SUPPORT/PDF%20 ... %20MOD.pdf
Scott Aldrich
This may be a double post for some.
aluminum one.
Scott
Moose 174
rogerk
Post by rogerk » Sun Feb 19, 2012 5:07 pm
I've noticed the same thing on mine. Did anyone ever have an answer to
this question? It looks like the specified doubler already exists.
Roger K
On 4/13/2005 11:31 AM, SA@MWUTAH.COM wrote to REBEL-BUILDERS:
-> I am looking at my fast build Moose wings and they already have a large
-> aluminum doubler in the aft tip rib position that the wing tip service
-> bulletin calls for W-1030. Looks like you could just remove a couple of
-> rivets to cut off the rib flange and slip in the stainless steel angle
-> W-1031, no need to completely remove the existing doubler or add the new
-> aluminum one.
-> Has anyone else done this mod or upgrade to fast build wings yet?
-> Scott
-> Moose 174
-> http://www.murphyair.com/SUPPORT/PDF%20 ... %20MOD.pdf
