f89 fuselage pieces
Wayne Ouellette
f89 fuselage pieces
Post by Wayne Ouellette » Sat Feb 18, 2012 1:09 pm
Hi everybody, I bought an early rebel kit and it doesn't have the F89
doublers that lie inside the tailcone. They join the side skins to the
Fus 30 tail wrap. Does anybody know the thickness of those pieces so I
can fabricate them myself.
Wayne 333R
f89 fuselage pieces
Post by Ken » Sat Feb 18, 2012 1:09 pm
I believe they are 0.020
I think that upgrade was designed when FUS-30 was only 0.020
Sometimes the aft end of the flanges on it have to be trimmed a bit to
clear the elevator push rods so you might want to taper the flanges down
to perhaps 1/4" at the aft end.
Ken 119R
Wayne 333R
Wayne Ouellette
f89 fuselage pieces
Thanks very much Ken, I can keep going now!
Sent: Friday, February 04, 2005 10:48 AM
Subject: Re: f89 fuselage pieces
Ken 119R
Wayne 333R
brad
f89 fuselage pieces
Post by brad » Sat Feb 18, 2012 1:09 pm
Wayne,
I had the same problem. I don't know the guage but it is a formed part.
It seems to me that they wern't too expensive from MAM.
Brad R195
On 2/4/2005 5:23 AM, W.OUELLETTE@SYMPATICO.CA wrote to REBEL-BUILDERS:
-> Received: by dcsol.com (Wildcat! SMTP Router v6.0.451.3)
-> for rebel-builders@dcsol.com; Fri, 04 Feb 2005 05:24:36 -0900
-> Received: from tomts5.bellnexxia.net ([209.226.175.25]) EHLO=tomts5-
srv.bellnexxia.net
-> by dcsol.com (Wildcat! SMTP v6.0.451.3) with SMTP
-> id 383032343; Fri, 04 Feb 2005 05:24:34 -0900
-> Received: from useraobwrjfvto ([206.172.171.168])
-> by tomts5-srv.bellnexxia.net
-> (InterMail vM.5.01.06.10 201-253-122-130-110-20040306) with SMTP
-> id <20050204142431.HUXQ2026.tomts5-
srv.bellnexxia.net@useraobwrjfvto>
-> for <rebel-builders@dcsol.com>; Fri, 4 Feb 2005 09:24:31 -0500
-> Message-ID: <001501c50ac5$18043090$a8abacce@useraobwrjfvto>
-> From: "Wayne Ouellette" <w.ouellette@sympatico.ca>
-> Subject: f89 fuselage pieces
-> Date: Fri, 4 Feb 2005 09:23:26 -0500
-> X-Orig-MIME-Version: 1.0
-> X-Orig-Content-Type: multipart/alternative; boundary="----
=_NextPart_000_0012_01C50A9B.2E3CC3B0"
-> X-Priority: 3
-> X-MSMail-Priority: Normal
-> X-Mailer: Microsoft Outlook Express 6.00.2800.1106
-> X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1106
-> X-Antivirus-Remover: Message filtered with wsAV v2.0.0 Build 001
-> Hi everybody, I bought an early rebel kit and it doesn't have the F89
-> doublers that lie inside the tailcone. They join the side skins to the
-> Fus 30 tail wrap. Does anybody know the thickness of those pieces so I
-> can fabricate them myself.
-> Thanks
-> Wayne 333R
Wayne Ouellette
f89 fuselage pieces
Thanks Brad, they are very simple pieces to make....just a bit of .020 which
seems pretty light to me. I have some .025 here that I will make them out
of.
Thanks again
Wayne 333R
Sent: Friday, February 04, 2005 5:17 PM
Subject: RE: f89 fuselage pieces
Wayne,
Brad R195
srv.bellnexxia.net
SMTP
09:24:31 -0500
-> X-Priority: 3
-> Thanks
-> Wayne 333R
