rear float brackets
Alan Hepburn
rear float brackets
Post by Alan Hepburn » Sat Feb 18, 2012 10:16 am
Bob:
I agree it's perhaps a bit forward, but not as much as a foot. The airplane
is parked considerably nose up, which gives the illusion of the step being
'way forward. The Montana 2200s have the rear spreader one full bay ahead
of where they are on the Murphy 1800s. I think this is partly because Keith
had the Glasair in mind. Anyway, I have a rear raked strut, but I have a
bracing wire running forward to a fitting at the rear end of the door sill
to absorb the aft forces on a hard touchdown. I'll post a pic for anybody
interested. On the Elite, the door sill is really solid (0.062), so I think
it will hold up. Guess we'll see.
Eric was pretty happy with his Rebel, but I do think the aft force on that
rear attach point could be a problem, and on the Rebel it's not so easy to
fix.
Al.
Sent: Tuesday, March 08, 2005 9:04 PM
Subject: Re: rear float brackets
Hi Al !
From the photo, that looks like Ron Barber's old Rebel.
The step appears to be over a foot or more too far forward -
that would account for the angle of the rear support ....
and also the poor performance !! ;-) :-)
Guess they had <some> reason for the positioning.
On Tuesday 08 March 2005 12:05 am, Alan Hepburn wrote:
Wayne:
It was Eric Draper's Rebel. I've posted the pic on Rebel/Float
Installations. The rear spreader is about the same location as on the
Montana 2200s.
Al
Sent: Monday, March 07, 2005 9:31 PM
Probably BILMAR floats Al, not CLAMAR's. I know of at least one Rebel
down
your way with a set of Bilmars on it that doesn't fly right. CLAMAR's
are
similar but significantly lighter, but IMHO still too heavy for the
Rebel
or
Elite or I'd be installing them myself.... considering I work hand in
hand
with Clair Sceli already. Pretty sure the deck pickup points are
pretty
similar on both mfg's floats though so the mounting strut picture
would
show
the "tale" without me needing to get measurements for Gilles.
Sent: Monday, March 07, 2005 9:20 PM
strut is
done
point
least).
If
have point, forward
amphibious
Cover
not
Question
will
skin
at
there
was Thanks
outside
this
doublers
Behalf
Of
life!
ares
dones,
Is it
done
https://www.dcsol.com/login?mode=HTML
be
recipient disseminate,
rear float brackets
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:16 am
I think I'm pretty close on my 9" Al. Keith Kinden (Montana) moved the
spreader bar forward a bulkhead (and thus the attach bracket) because it's
too far back on the Murphy floats and it submerges on take off if you are
too quick to pull the stick right back.
Sent: Tuesday, March 08, 2005 11:05 PM
Bob:
airplane
Keith
think
fix.
Al.
Hi Al !
Wayne:
Montana 2200s.
Al
Rebel
down
CLAMAR's
are
Rebel
or
in
hand
pretty
would
show
strut is
was
done
not
attach
point
least).
If
points,
attach
brought
amphibious
outside.
Cover
but
not
Question
skin
at
there
hole.
outside
doublers
Behalf
Of
life!
ares
Is it
be
done
be
Alan Hepburn
rear float brackets
Gilles:
See pic on Elite float installations.
Unless Keith has some really brilliant ideas, it would be major surgery to
put a rear attach point on my airplane, now that everything's riveted up.
The pic shows a solution that is easy to retro fit. Be interested to know
what you think.
Al
From: "Gilles St-Pierre" <ranchlaseigneurie@hotmail.com>
Sent: Monday, March 07, 2005 9:29 PM
Al
the corner wrap has nt been instaled yet. so is quite easy to stick that
in
between and we have a small machine shop to faconnate that part as
descdibed, but would still appreciate your comments on the other way to
do
it
thank a lot
gilles e717
Date: Mon, 7 Mar 2005 21:20:14 -0500
Gilles:
I think I have a picture of a Rebel on Clamar floats. The rear strut is
raked well forward, just like on the Montana 2200s, but nothing was done
about it, which I don't think is very good. If your fuselage is not
finished, then it would be a much better job to have the rear attach
point
at the rear of the door sill as Bob is doing (on the Elite at least). If
you have finished the fuselage with the standard MAM attach points, I
have
an alternate approach to relieve the fore-aft stress from the attach
point,
which we can discuss.
Al
Sent: Monday, March 07, 2005 5:20 PM
Subject: rear float brackets
Bob
I checked your site and noticed the rear float bracket was brought
forward
1
station
was wondering if it should be done when using Clamar 2200 amphibious
floats
Beautiful pictures,i did pick some hints......!
thanks
gilles e717
Cover
is
will
be
at
was
this
with
Of
doubler
dones,
just
done
like
recipient
disseminate,
Bob Andrews
rear float brackets
Post by Bob Andrews » Sat Feb 18, 2012 10:16 am
Just uploaded a scaned (not the best) picture to the "E - Float
Installations" section. It's a picture of the green and white Elite on MFC
2200 amphibs with the aft fittings moved up one station.
Bob e612
Alan Hepburn
Sent: Tuesday, March 08, 2005 9:05 PM
Bob:
fix.
Al.
Hi Al !
Wayne:
Montana 2200s.
Al
down
are
Rebel
or
hand
pretty
would
show
strut is
done
point
least).
If
have point, forward
amphibious
Cover
not
Question
will
skin
at
there
was Thanks
outside
this
doublers
Behalf
Of
life!
ares
dones,
Is it
done
be
Gilles St-Pierre
rear float brackets
Post by Gilles St-Pierre » Sat Feb 18, 2012 10:16 am
Al
saw the pictures and they got me convinced....one station fwd
thanks again
gilles
Date: Tue, 8 Mar 2005 23:21:51 -0500
Gilles:
what you think.
Al
Al
that
in
do
it
thank a lot
gilles e717
Gilles:
is
done
point
If
have
point,
Al
forward
1 floats
Cover
is
not
will
be
skin
at
there
was
a Thanks
outside
this
doublers
with
Behalf
Of
doubler dones,
it
just
done
like
---------------------------------------------------------------------- recipient disseminate,
Bob Andrews
rear float brackets
Gilles,
I uploaded three pics in the E-Float Installations that show the aft float
fitting and doublers installed. Note that the installation isn't complete
... still need to box the door post ... and then do same to other side. We
have the fitting and doublers programed up and can crank them out on the
mill. If your interested, I'll check with Keith on the cost.
Bob e612
Gilles St-Pierre
Sent: Wednesday, March 09, 2005 6:27 PM
Al
thanks again
gilles
Gilles:
what you think.
Al
Al
that
in
do
it
thank a lot
gilles e717
Gilles:
is
done
point
If
have
point,
Al
forward
1 floats
Cover
is
not
will
be
skin
at
there
was
a Thanks
outside
this
doublers
with
Behalf
Of
doubler dones,
it
just
done
like
C Brockway
rear float brackets
Post by C Brockway » Sat Feb 18, 2012 10:16 am
Bob, I am interested in the fittings and doublers
also. I have some questions though for everyone. I
have no idea if I will go with MAM floats or
another type. Is the door post location only for
non-MAM floats or can the fitting location be used
with the MAM floats as well. The door post fitting
location seems to make more sense for a number of
reasons. I need to make a decision soon as I am
very close to installing the float fittings.
Bob Andrews wrote:
Gilles,
Bob e612
Gilles St-Pierre
Al
thanks again
gilles
Gilles:
what you think.
Al
Al
that
in
do
it
thank a lot
gilles e717
is
done
point
If
have
point,
Cover
not
skin
at
there
outside
doublers
Behalf
Of
it
done
Alan Hepburn
rear float brackets
BTW, if you do go with the Murphy floats, and you have an Elite (not sure
about Rebel), make sure there is no forward bend on that attach bulkhead
(not even a fraction of an inch), and position the attach plates as close to
the outboard edge of the bulkhead as you can. Otherwise, the attach bolt
can interfere with th corner wrap skin.
Al
Sent: Wednesday, March 09, 2005 10:53 PM
Bob Andrews wrote:
Gilles,
float
complete
We
Bob e612
Gilles St-Pierre
Al
thanks again
gilles
Gilles:
up.
know
what you think.
Al
that
in
way to
do
strut
is done
not
attach
point
least).
If
have
attach
point,
brought
amphibious
outside.
Cover
but
not
Question
skin
at there
hole.
outside doublers Behalf
Of
life!
ares
Is
it
be
done -----------------------------------------------------------------
be
Bob Andrews
rear float brackets
612E will be flying around with both sets of aft fittings ... saw no good
reason to remove the MAM fittings that were already installed. Who knows,
the extra set may well come in handy ... for attaching a stringer of fish
... a trolling motor ... securing a [small] canoe ... a fishing chair ... or
hanging stuff in the water to keep cold ... hmmm ....
I found a picture on the Internet of the Green and White Elite on a set of
MAM 1800 amphibs (at least, from looking at the front gear, I think they're
MAM 1800's ...anyone confirm?) ... and did some pixel swapping to move the
struts to the door post. The angle of the picture isn't the greatest for
showing the aft strut rake angle ... www.aacnet.com/elite/1800aft.jpg and
www.aacnet.com/elite/1800fwd.jpg
Bob e612
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of C
Brockway
Sent: Wednesday, March 09, 2005 8:53 PM
Bob Andrews wrote:
Gilles,
We
Bob e612
Gilles St-Pierre
Al
thanks again
gilles
Gilles:
know
what you think.
Al
Al
that
in
do
it
thank a lot
gilles e717
is
done
point
If
have
point,
amphibious
Cover
not
Question
skin
at
there
outside
doublers
Behalf
Of
life!
ares
Is
it
done
be
rear float brackets
Post by Mike Davis » Sat Feb 18, 2012 10:16 am
Hi Bob, that photo is of the old factory demonstrator... if I'm not
mistaken, those are Montana 2200 floats on there.
195SR
Sent: Thursday, March 10, 2005 5:39 AM
Subject: RE: rear float brackets
or
they're
Bob e612
Brockway
Bob Andrews wrote:
Gilles,
float
complete
We
Bob e612
Gilles St-Pierre
Al
thanks again
gilles
Gilles:
up.
know
what you think.
Al
that
in
do is done point If have point,
amphibious
Cover not
Question
skin
at there outside doublers Behalf
Of
life!
ares
Is
it done -----------------------------------------------------------------
be
Bob Andrews
rear float brackets
Hi Mike ... I thought so too at first, but then I saw what looked like
[lightening like] holes in the nose gear forks which looked the same as the
1800's ... and I couldn't tell if the nose gear legs were flat or round.
Also the MFC 2200A's I had seen before had black spackled paint aft of the
green paint, and these don't ... but it could have been an early picture as
you mentioned. Indeed you may be right on here ... they may be MFC 2200's.
I just learned that Keith made two special sets of 2200A's targeted for the
Elite/Rebel that had the aft spreader bar at the same station as the MAM
1800's (aft of the normal MFC 2200A's) ... so that throws a slight curve in
my picture based analysis as I can't be sure which model MFC 2200 is on the
G/W Elite. Did have fun moving the pixels though ... and putting them both
in a power point slide show and with a camera click sound transitioning
between the two pictures made for some pretty cool dynamic aft struts.
Bob e612
Sent: Thursday, March 10, 2005 2:11 PM
195SR
or
they're
Bob e612
Brockway
Bob Andrews wrote:
Gilles,
float
complete
We
Bob e612
Gilles St-Pierre
Al
thanks again
gilles
Gilles:
up.
know
what you think.
Al
that
in
amphibious
Cover not
Question
skin
Of
life!
ares
Is
be
Alan Hepburn
rear float brackets
Agree - they're not Montanas. The nose gears are different, the rear
spreader is too far back (though that could be one of these two sets), you
can see the tops of those circular plastic access hatches, and it's not
Keith's rigging.
Al
Sent: Thursday, March 10, 2005 5:01 PM
as
2200's.
in
both
Bob e612
195SR
good
knows,
fish
or
they're
for
Bob e612
Brockway
Bob Andrews wrote:
Gilles,
float
complete
We
Bob e612
Gilles St-Pierre
Al
thanks again
gilles
surgery
know
stick
as
way
was
not
attach
points,
attach
amphibious
outside.
Question
with
life!
ares
Is
also
be
intended
Bob Andrews
rear float brackets
Found this Elite 1800 Amphib MAM installation on the NW Rebel site ... nice
paint job. Those aft struts look pretty vertical ... and long.
http://groups.msn.com/NWRebelExperiment ... intallatio
n.msnw
Think the bottom line on all this is ... if you have an aft spreader bar
location like the MAM 1800's (or the two special 2200's that MFC built) then
the MAM aft fitting is the one to use. If you have regular MFC 2200's
(which has the aft spreader bar more forward then the 1800's) ... then the
MAM aft fitting can be used too ... or to get the strut more vertical,
attaching one station forward to the aft door post location is the way to
go. From what I've picked up thus far, the advantage to the more forward
aft spreader bar MFC 2200's is that the spreader bar won't make contact with
the water during take offs. However, I haven't flown either off the water,
so I can't speak from experience ... only what I've picked up. If there are
any out there reading this, would like to hear from Elite (or Rebel if
applicable) amphib drivers with experience taking off the water with the MAM
1800's set up ... specifically the aft spreader bar in the water issue (to
dispell or validate) ... thanks.
Bob e612
Alan Hepburn
Sent: Thursday, March 10, 2005 6:04 PM
Keith's rigging.
Al
as
2200's.
in
both
Bob e612
195SR
good
knows,
fish
or
they're
for
Bob e612
Brockway
Bob Andrews wrote:
Gilles,
float
complete
We
Bob e612
Gilles St-Pierre
Al
thanks again
gilles
surgery
know
stick
as
way
was
not
attach
points,
attach
amphibious
outside.
Question
with
life!
ares
Is
also
be
intended
rear float brackets
As I already posted it's true Bob..if you give it the boot and haul the
stick back immediately you put the MAM 1800 rear spreader under water. Also
when doing plow turns... as if you don't have the spreader sealed off to the
float skins you fill the compartment where the spreader stubs come out of
the floats to bolt the speader bar to.
Sent: Thursday, March 10, 2005 9:16 PM
nice
n.msnw
then
with
water,
are
MAM
Bob e612
Alan Hepburn
Keith's rigging.
Al
as
2200's.
in
both
Bob e612
195SR
good
knows,
fish
or
set
they're
for
Bob e612
Brockway
Bob Andrews wrote:
side.
We
surgery
riveted
know
stick
as
way
was
not
attach
points,
attach
amphibious
outside.
bad,
Question
ago,
might
with
the life!
hole
ares
outside!
Is
should
also
be
intended
https://www.dcsol.com/login?mode=HTML ----------------------------------------------------------------- -----------------------------------------------------------------
Bob Andrews
rear float brackets
Thanks Wayne for reminding me where I "picked it up" from. For me anyway
... the jury's out on this one ... thanks for everyones participation and
inputs.
Bob e612
Sent: Thursday, March 10, 2005 7:34 PM
nice
n.msnw
then
with
water,
are
MAM
Bob e612
Alan Hepburn
Keith's rigging.
Al
as
2200's.
in
both
Bob e612
195SR
good
knows,
fish
or
set
they're
for
Bob e612
Brockway
Bob Andrews wrote:
side.
We
surgery
riveted
know
stick
as
way
was
not
attach
points,
attach
amphibious
outside.
bad,
Question
ago,
might
with
the life!
hole
ares
outside!
Is
should
also
be
intended
