Prop Damper
Prop Damper
Post by Wayne G. O'Shea » Fri Feb 17, 2012 8:33 pm
Your following message has been delivered to the 165 members of
the list murphy-rebel@dcsol.com at 09:11:30 on 13 Nov 2000.
In regards to Warp Drive / 160 H.P. Engine combinations apparently needing
something to stop blade cracking I am forwarding this to the list.
Wayne G.O'Shea
To: <raa@bconnex.net>
Sent: Sunday, November 12, 2000 11:02 PM
Subject: Re: Prop Damper
Mark Landoll (405-392-3847 )sells a damper for Lycoming engines. It bolts
on
to the back of the starter ring gear. It has a ring inside which floats in
some form of silicone to dampen out the power pulses and it adds about 12
pounds. I have not got one for my 0-320 yet but am planning to add it in
future as the ones I have seen do make the engine run somewhat smoother.
Marc DeGirolamo
Phone: (306)934-4434
Fax: (306)934-4551
email(H): mdee@dlcwest.com
email(W): marc.degirolamo@city.saskatoon.sk.ca
REBEL112R
Prop Damper
Post by REBEL112R » Fri Feb 17, 2012 8:33 pm
This fellow also sells auto conversion starters and alternators for the
Lyc's, they are priced right and work. His mounts also fit. Have both on
the 0-235 I have and have not had any problems....
Rebflyer
Prop Damper
Post by Rebflyer » Fri Feb 17, 2012 8:33 pm
Hi all,
Yes this is the same one that Rich Engivall is using. The add is in sport
aviation Mag under prop section. Address as follows
Mark Landoll
1205 Red Bud Ln.
Newcastle OK 73065
405-392-3847
Curt N97MR
Prop Damper
Post by Bob Patterson » Fri Feb 17, 2012 8:33 pm
Thanks Curt !! Hope you had a good trip home !
------------------------------orig.----------------------------------------
At 06:57 PM 11/13/00 EST, you wrote:
Hi all,
Mark Landoll
1205 Red Bud Ln.
Newcastle OK 73065
405-392-3847
Curt N97MR
Rebflyer
Prop Damper
Hi Bob,
Yup, great trip. great viz the whole way as long as we didn't go higher
than 2200 ft. took 2.3 hrs. Even The American customs were ok to deal with!
Looking forward to the next time, Curt N97MR
