[rebel-builders] voltage regulators
Post by Drew Dalgleish » Sun Feb 19, 2012 11:00 am
I'm using a nipondenso alternator with a built in regulator works great.
At 09:09 AM 7/31/2006 -0400, you wrote:
hi all
i have b&c 40 amp alternator and am wonder what others are using for voltage
regulator ?? the b&c controller/regulator is way to much money, several
hundred dollars
mike#007
Post by Walter Klatt » Sun Feb 19, 2012 11:00 am
Same here. Got mine from a wrecker out of an old Chevy Sprint. No problems
for 450+ hours. I think it cost me about 30 bucks.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Drew
Dalgleish
Sent: July 31, 2006 6:45 AM
Subject: Re: [rebel-builders] voltage regulators
hi all
voltage
hundred dollars
mike#007
Angus McKenzie
Post by Angus McKenzie » Sun Feb 19, 2012 11:00 am
Me too. With a Toyota starter.....Angus
Sent: Monday, July 31, 2006 9:53 AM
Subject: RE: [rebel-builders] voltage regulators
Dalgleish
hi all
voltage
hundred dollars
mike#007
Checked by AVG Free Edition.
Version: 7.1.385 / Virus Database: 268.10.5/403 - Release Date: 7/28/2006
Post by Ken » Sun Feb 19, 2012 11:00 am
Excellant as an external regulator allows complete control of the
alternator and the simple additon of overvoltage protection. That is the
preferred way to do it IMO. Many guys use a automotive regulator.
Standard part VR166 for example at about $40. is shown in aeroelectric
Z-23 diagram. I'd personally favour a solid state one since they have
some built in temperature compensation.
Chrylser also used to use a cheap solid state unit through the 1970's.
The VR166 or equivalent is popular however. B&C sell the overvoltage
protector for about $35. which I'd recommend
Ken .
Jones, Michael wrote:
hi all
hundred dollars
mike#007
Jones, Michael
Post by Jones, Michael » Sun Feb 19, 2012 11:00 am
hey angus,drew
i have asked this before but never got answer, what is tongue value for
engine mounting bolts, that's the an8's for engine to frame mounting ??
mike
Angus McKenzie
Sent: Monday, July 31, 2006 10:48 AM
Dalgleish
hi all
voltage
hundred dollars
mike#007
Jones, Michael
hi ken
i have the b&c crowbar overvolt protection item, but as Niagara airparts
does not sell their internal regulated alternator i now have the b&c unit
and need regulator, b&c have good unit but not cheap !! but it is very good,
with monitors for bus voltage as well, is this the unit you refer to that
you think is the best way to go
thanks
mike
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Ken
Sent: Monday, July 31, 2006 11:13 AM
Ken .
hi all
voltage
hundred dollars
mike#007
steve whitenect
Post by steve whitenect » Sun Feb 19, 2012 11:00 am
For the conical mounts, Tony Bing says 40-60 inch pounds
Steve W.
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
To: "'rebel-builders@dcsol.com'" <rebel-builders@dcsol.com>
Date: Mon, 31 Jul 2006 11:17:30 -0400
hey angus,drew
mike
Angus McKenzie
problems
Dalgleish
hi all
voltage
hundred dollars
mike#007
7/28/2006
Jones, Michael
great thanks steve, i have those books did not see it, will have to read
again
mike#007
steve whitenect
Sent: Monday, July 31, 2006 11:58 AM
Steve W.
hey angus,drew
mike
Angus McKenzie
problems
Dalgleish
hi all
voltage
hundred dollars
mike#007
7/28/2006
Sure the B&C unit is very good and will outlast your airplane.
However the VR166 regulator from your local auto parts store will do the
job a lot cheaper if you don't mind a bit less reliability. Personally
since you already have the crowbar overvoltage protector I'd probably
use the VR166 as they are cheap enough that you could keep a spare in
stock if you wanted.
hi ken
thanks
mike
Ken .
hi all
voltage
hundred dollars
mike#007
Jones, Michael
hi ken
getting b&c module free from levans, so choice is made, my alternator was
quoted with regulator and they will eat the cost, good deal eh !!
mike
Sent: Monday, July 31, 2006 12:59 PM
hi ken
good,
thanks
mike
Ken .
hi all
voltage
hundred dollars
mike#007
Angus McKenzie
Hi Guy
Homemade mounting brackets for both the starter and alternator
(Nippondenso/Honda).
The Toyota truck starter is in a one-piece milled solid bracket, I'll look
for pictures.
The alternator mount is made from welded 1" flat-bar with the Delco/Citabria
pulley installed.
And, I'm using a Ford voltage regulator on the fire-wall..........Angus
Sent: Monday, July 31, 2006 11:09 AM
Angus, what did you use for a bracket for the Toyota starter?
I made one for ours, but not happy with it.
Guy Lamarche
Sent: Monday, July 31, 2006 10:47 AM
problems
Dalgleish
At 09:09 AM 7/31/2006 -0400, you wrote: voltage Drew
7/28/2006
Post by Mike Kimball » Sun Feb 19, 2012 11:00 am
That sounds pretty light. Not much past finger tight. Do you mean foot
pounds?
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jones,
Michael
Sent: Monday, July 31, 2006 8:06 AM
To: 'rebel-builders@dcsol.com'
again
mike#007
steve whitenect
Steve W.
hey angus,drew
mike
Angus McKenzie
problems
Dalgleish
hi all
voltage
hundred dollars
mike#007
7/28/2006
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:07 am
On my personal Rebel I hunted down the socket from a junk car and obtained a
new Regulator for a Honda Civic. Much better control than the Chrysler style
ON/OFF style generally used. Also has output for the alternator fail idiot
light and very good voltage control. My Gill 25 battery lasted from when
obtained '94..installed and first flown June '95 and I removed it last year
when I moved the battery to the back of the tailcone. I then installed the
removed battery in my f-in-laws 701 and it lasted another year before it
wouldn't turn his 912S this spring....so 11+ seasons...generally unheard of
with aircraft batteries...so the regulator must be doing a good job. Takes a
bit of work and a Honda Civic wiring diagram to wire up though and 10 years
later I'm not sure where the wiring diagram is.
To: "Rebel-Builders (E-mail)" <rebel-builders@dcsol.com>
Sent: Monday, July 31, 2006 9:09 AM
Subject: [rebel-builders] voltage regulators
hi all
voltage
hundred dollars
mike#007
