Aluminum wingtips (what I really want to do with my 2 weeks)
Jesse Jenks
I haven't heard from Dave Fife for months, so I've been considering building
my own Hoerner tips. Using hotwire cut foam to make one-off fiberglass tips
would be an option also, but I thought it would be really cool to have an
all metal wing. It shouldn't be that hard really, the trickiest part I think
would be establishing the plane of the upswept end plate so the top and
bottom sheets can be trimmed in the right place. I was thinking of using a
laser that is normal to the desired plane of the end plate that can pivot on
that plane. Once the top and bottom skins were clecoed to the wing with
extra length hanging beyond the desired end plate location you could easily
use the laser to mark the trim lines. There would only be three basic pieces
to each tip; top and bottom skins flat wrapped to the airfoil shape right on
the wing, and the end plate which would be totally flat as described, or you
could put in some under camber (still no compound curve) pretty easily. The
coolest part is that once you had the outline of the three pieces you could
just duplicate them for the other wing and other airplanes, as opposed to
foam and glass where you have to make a plug for both wings. The other
tricky part I guess is joining the three pieces. I was thinking the the
bottom seam being an obtuse angle could use a tab formed from an extra strip
on the bottom of the end plate, using fluting pliers or a shrinker. The
upper seam being much sharper would probably require a separate joiner strip
made from a bent V section. It would require some extreme forming to fit the
top of the airfoil but again, flutes, shrinker and/or notches should do the
trick. This piece would be mostly inside the tip anyway so doesn't have to
be pretty. Landing light cover would be simple flat wrapped Lexan in the LE
section of the tip.
Any thoughts?
section of the tip.
Any thoughts?
Bob P's got one of the two sets I made somewhere Jesse.... I tad short for a
light in the tip though...I'll send you a picture..
Sent: Saturday, September 17, 2005 12:52 PM
Subject: Aluminum wingtips (what I really want to do with my 2 weeks)
buildingI haven't heard from Dave Fife for months, so I've been considering
tipsmy own Hoerner tips. Using hotwire cut foam to make one-off fiberglass
thinkwould be an option also, but I thought it would be really cool to have an
onwould be establishing the plane of the upswept end plate so the top and
easilythat plane. Once the top and bottom skins were clecoed to the wing with
piecesuse the laser to mark the trim lines. There would only be three basic
onto each tip; top and bottom skins flat wrapped to the airfoil shape right
youthe wing, and the end plate which would be totally flat as described, or
Thecould put in some under camber (still no compound curve) pretty easily.
couldcoolest part is that once you had the outline of the three pieces you
stripjust duplicate them for the other wing and other airplanes, as opposed to
stripon the bottom of the end plate, using fluting pliers or a shrinker. The
themade from a bent V section. It would require some extreme forming to fit
thetop of the airfoil but again, flutes, shrinker and/or notches should do
LEtrick. This piece would be mostly inside the tip anyway so doesn't have to
section of the tip.
Any thoughts?
Jesse Jenks
I should have known you would have already made some. Was it hard?
Subject: Re: Aluminum wingtips (what I really want to do with my 2 weeks)
Date: Sat, 17 Sep 2005 13:48:22 -0400
buildingI haven't heard from Dave Fife for months, so I've been consideringtipsmy own Hoerner tips. Using hotwire cut foam to make one-off fiberglassanwould be an option also, but I thought it would be really cool to havethinkall metal wing. It shouldn't be that hard really, the trickiest part Iawould be establishing the plane of the upswept end plate so the top and
bottom sheets can be trimmed in the right place. I was thinking of usingpivotlaser that is normal to the desired plane of the end plate that can
oneasilythat plane. Once the top and bottom skins were clecoed to the wing with
extra length hanging beyond the desired end plate location you couldpiecesuse the laser to mark the trim lines. There would only be three basicrightto each tip; top and bottom skins flat wrapped to the airfoil shape
onyouthe wing, and the end plate which would be totally flat as described, orThecould put in some under camber (still no compound curve) pretty easily.couldcoolest part is that once you had the outline of the three pieces youtojust duplicate them for the other wing and other airplanes, as opposedstripfoam and glass where you have to make a plug for both wings. The other
bottom seam being an obtuse angle could use a tab formed from an extrastripon the bottom of the end plate, using fluting pliers or a shrinker. The
upper seam being much sharper would probably require a separate joinerthemade from a bent V section. It would require some extreme forming to fitthetop of the airfoil but again, flutes, shrinker and/or notches should dototrick. This piece would be mostly inside the tip anyway so doesn't haveLEbe pretty. Landing light cover would be simple flat wrapped Lexan in thesection of the tip.
Any thoughts?
Took some head scratching and hours. Mine are just two pieces..The sloped
and the top skin & why I said they are a bit short..but I didn't want to
play with fiberglass and figured the hoerner at this length = the supplied
MAM tip at the extended length....due to the vortex effect of increasing
wing span. I wasn't looking so much for a performance mod...as a way out of
playing with glass. I had to make the first pattern from steel flashing so
it was stiff enough to work with. Basically if you get the bottom/side
coming up on it's angle and left long...then take a flat object..tape a
marker to the end of it and slide the flat object along the wing..keeping it
parallel to the wing spars... to mark the wing profile on the new sheet.
This gives you a bend line for the flange to pick up the top wing extension.
I know..clear as mud...will see if I can find you some pics as they were
being built.
Sent: Saturday, September 17, 2005 3:12 PM
being built.
forI should have known you would have already made some. Was it hard?
anda
buildingI haven't heard from Dave Fife for months, so I've been consideringtipsmy own Hoerner tips. Using hotwire cut foam to make one-off fiberglassanwould be an option also, but I thought it would be really cool to havethinkall metal wing. It shouldn't be that hard really, the trickiest part Iwould be establishing the plane of the upswept end plate so the top
usingbottom sheets can be trimmed in the right place. I was thinking of
withapivotlaser that is normal to the desired plane of the end plate that can
onthat plane. Once the top and bottom skins were clecoed to the wing
oreasilyextra length hanging beyond the desired end plate location you couldpiecesuse the laser to mark the trim lines. There would only be three basicrightto each tip; top and bottom skins flat wrapped to the airfoil shape
onthe wing, and the end plate which would be totally flat as described,
easily.youcould put in some under camber (still no compound curve) pretty
theThecouldcoolest part is that once you had the outline of the three pieces youtojust duplicate them for the other wing and other airplanes, as opposedfoam and glass where you have to make a plug for both wings. The other
Thestripbottom seam being an obtuse angle could use a tab formed from an extraon the bottom of the end plate, using fluting pliers or a shrinker.
fitstripupper seam being much sharper would probably require a separate joinermade from a bent V section. It would require some extreme forming to
dothetop of the airfoil but again, flutes, shrinker and/or notches should
havethetrick. This piece would be mostly inside the tip anyway so doesn't
thetobe pretty. Landing light cover would be simple flat wrapped Lexan in
LEsection of the tip.
Any thoughts?
Prior to Dave I was going to use the Maverick tip design. MAM gave me
the section from the Maverick manual when I asked. They are similar to
hoerner's and fabric covered.
You do understand that metal will take you several times longer than
your wildest estimate ;(
Jesse Jenks
Thanks Wayne, I get it.
I might give it a try. I'd rather just pay Fife the $600. but I think he
fell off the edge of the earth or something.
Date: Sat, 17 Sep 2005 16:16:56 -0400
it
extension.
being built.
weeks)I should have known you would have already made some. Was it hard?
Subject: Re: Aluminum wingtips (what I really want to do with my 2forDate: Sat, 17 Sep 2005 13:48:22 -0400
Bob P's got one of the two sets I made somewhere Jesse.... I tad shortfiberglassa
buildinghavetipsIanandthinkusingwitha pivot
onbasiceasilydescribed,pieces right
on
oreasily.youyouTheopposedcouldothertotheextraThestripjoinerfitstripdothehavethethetoLE
Jesse Jenks
Yeah, but that's true about the whole airplane.
I'll have a look at the Maverick too. Considering all options, but using the
supplied tips is not one of them at this point. They stink. I was looking at
a friends' RV-6 wingtips and they are beautifully made The glass work and
gel coat are really really good. I wish Murphy would have invested a bit
more effort into theirs.
Jesse Jenks wrote:
buildingI haven't heard from Dave Fife for months, so I've been consideringmy own Hoerner tips.
Jesse Jenks
Thanks Bob, I'll give Dave Fife until I finish my second wing to come out of
hiding before I do anything.
Date: Sun, 18 Sep 2005 11:07:53 -0400
Gee, Jesse - make me an offer O/L for the metal tips - they're
here in the basement ! (Along with a 'speed cowl' for a Continental
IO-240, if anyone is interested ....) (and a LOT of other junk !) ;-)
All ready to install !
On Saturday 17 September 2005 09:32 pm, Jesse Jenks wrote:weeks)Thanks Wayne, I get it.
Subject: Re: Aluminum wingtips (what I really want to do with my 2slopedDate: Sat, 17 Sep 2005 16:16:56 -0400
Took some head scratching and hours. Mine are just two pieces..Thetoand the top skin & why I said they are a bit short..but I didn't wantsuppliedplay with fiberglass and figured the hoerner at this length = theincreasingMAM tip at the extended length....due to the vortex effect ofoutwing span. I wasn't looking so much for a performance mod...as a way
offlashingplaying with glass. I had to make the first pattern from steel
sowing..keepingit was stiff enough to work with. Basically if you get the bottom/side
marker to the end of it and slide the flat object along thesheet.it
parallel to the wing spars... to mark the wing profile on the newwereThis gives you a bend line for the flange to pick up the top wing
extension.
I know..clear as mud...will see if I can find you some pics as theyweeks)being built.
Subject: Re: Aluminum wingtips (what I really want to do with my 2shortweeks)weeks)forconsideringtofiberglassparthavetopIofandcanusingwingcouldwithshapebasicpiecesdescribed,
or easily.theyou opposed othershrinker.the extraformingThe joiner
toshouldfitdoesn'tdoLexanhave
in-----------------------------------------------------------------the-----------------------------------------------------------------
suppliedThanks Wayne, I get it.
ofMAM tip at the extended length....due to the vortex effect of increasing
soplaying with glass. I had to make the first pattern from steel flashing
shortit was stiff enough to work with. Basically if you get the bottom/side
it
extension.
being built.
consideringfor
partfiberglasshave
topI
canandusing
couldwith
shapebasic
thedescribed,
oreasily.youopposedother
shrinker.theextra
toThejoiner
shouldfit
indohave
cosmedi
Hello Jesse,
I spoke with David Fife by telephone six weeks ago; he was going to finish off the Elite prototype wing tips by the end of this year. So I guess he still is in business. He had just moved house (usual problems). I will give him a telephone call today and ask him to contact the list.
Kind regards,
Greg. Gordon.
Kind regards,
Greg. Gordon.
cosmedi
Hello Jesse,
Tried David Fife's telephone number; received a recorded message saying "that the number was disconected or no longer in use". You and I are both back to square one!!!
Greg.
Greg.
Rebflyer
Hi Jesse,
Well I just spent the last 2 days with Dave. He's finally got to the
bottom of the move, and he can actually see the tip molds now.
Drop him a line again and see what happens. Remember its aircrafttipps @
Yahoo.com. It's an e-mail site not a web page.
Curt N97MR
Curt N97MR
Rick Harper
Yo Gregus !
Don't forget to get me a pair too !
Biggus
Cc: Jesse Jenks
Sent: Monday, September 19, 2005 7:54 AM
weeks)
Hello Jesse,
Kind regards,
Greg. Gordon.
Biggus
Cc: Jesse Jenks
weeks)
Hello Jesse,
Kind regards,
Greg. Gordon.
Jesse Jenks
Thanks Curt and Greg,
I'll keep trying.
I'll keep trying.
Hi Jesse,
Curt N97MR
