No Title
jean.poirier
No Title
Post by jean.poirier » Sun Feb 19, 2012 4:31 pm
Hello
How much could I expect for a pair of seats in a Rebel (I supply the standard frames)...
Jean
Rebel 747R
Guest
No Title
Post by Guest » Sun Feb 19, 2012 4:39 pm
Guest
No Title
Post by Guest » Sun Feb 19, 2012 4:40 pm
Guest
No Title
Post by Guest » Sun Feb 19, 2012 4:45 pm
rwampach
No Title
Post by rwampach » Sun Feb 19, 2012 4:47 pm
Try Spruce or one of the other suppliers, or an aircraft salvage yard.
The high temp probe for IFR/Known ice are quite expensive, the low temp probe such as found on many Cessna's 150's on up are in most of the salvage yards in either a 14 or 28 volt configuration. Be sure to get a mount adapter to go with the probe. I thought I had seen some at our local yard here in Sacramento CA.
Mine is mounted in the leading edge to the same rib that the common hinge point for Ail / Flap is located by an access plate, so that I have access to the inside. I added a doubler to reinforce the bottom skin
Dick Wampach SR-108
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of snowyrvr@mtaonline.net
Sent: Monday, June 30, 2008 9:45 AM
Subject: [rebel-builders] Heated Pttot Tube
Anyone got any great suggestions for a heated pitot tube?
Paul Michel
No Title
Post by Paul Michel » Sun Feb 19, 2012 4:47 pm
Congrats Dale.
It really IS worth it, isn't it?
Paul J. Michel
Rebel 374
Guest
No Title
Post by Guest » Sun Feb 19, 2012 4:48 pm
flyexp
No Title
Post by flyexp » Sun Feb 19, 2012 4:55 pm
All,
I have my Rebel up for sale on Barnstormers N413RB in Chattanooga, TN. If you guys know of anyone interested, send them my way.
Thank you,
Scott Cline
Guest
No Title
Post by Guest » Sun Feb 19, 2012 5:09 pm
Guest
No Title
Post by Guest » Sun Feb 19, 2012 5:18 pm
doug wilson
No Title
Post by doug wilson » Sun Feb 19, 2012 5:29 pm
To anyone putting a IO-540 lycoming in a moose or super-rebel and you need a engine mount I have the jig for it .Contact me and I will send it to you and you can build it yourself.I am located in central canada .
doug
Stay on top of things, check email from other accounts!
http://go.microsoft.com/?linkid=9671355
Guest
No Title
Post by Guest » Sun Feb 19, 2012 5:30 pm
Guest
No Title
Cindy and Brooks
No Title
Post by Cindy and Brooks » Sun Feb 19, 2012 5:37 pm
Guest
No Title
Post by Guest » Sun Feb 19, 2012 5:38 pm
