Turning into a hassle to get the 890 A brush able type proseal. I just
talked with Brian at MAM and he said they just thin the 890 B with Acetone
to a brush able consistency. Has anybody done this? Results okay??
Scott
N174SL
Thinning Pro Seal
steenson
Thinning Pro Seal
Dear Scott,
I thinned with MEK and it worked great. It brushed on smoothly with an acid
brush with bristles cut back a bit. The working time is much reduced however,
once the solvent flashes off.
Jeffrey Steenson
On 8/27/02 2:32 PM, FLYNSKI@PEOPLEPC.COM wrote to MURPHY-REBEL:
-> Turning into a hassle to get the 890 A brush able type proseal. I just
-> talked with Brian at MAM and he said they just thin the 890 B with Acetone
-> to a brush able consistency. Has anybody done this? Results okay??
-> Thanks,
-> Scott
-> N174SL
Jeffrey Steenson
-> Thanks,
-> Scott
-> N174SL
S & L Aldrich
Thinning Pro Seal
Thanks Jeff, I've found some of the RV builders are thinning it also.
Scott
steenson@dcsol.com
Sent: Tuesday, August 27, 2002 4:36 PM
Subject: RE: Thinning Pro Seal
Dear Scott,
however,
Jeffrey Steenson
Scott
steenson@dcsol.com
Dear Scott,
however,
Jeffrey Steenson
RJBWoodman
Thinning Pro Seal
My comment would be......PRC Desoto , the manufacturer recomends not thinning their proseal products. I personally spoke with their chemist and he told me not to thin. Why ? I did not ask. I found their brushable very brushable. Usually ships quicker than they say when you order.
RJ Thomas
Thinning Pro Seal
Scott,
I have. It seems to work just fine. I mixed the Proseal components
together first and then added the acetone. It takes a long time ( +/- five
minutes ) to get a consistent mix and it takes a lot LESS acetone than you
might initially think.
Cheers, rj
R J Thomas
Lafayette, LA
SR 2500/3500 #140 Slow Build
rj.thomas@halliburton.com
(337) 849-4136
Sent: Tuesday, August 27, 2002 5:24 PM
Subject: Thinning Pro Seal
Scott
N174SL
Cheers, rj
R J Thomas
Lafayette, LA
(337) 849-4136
Scott
N174SL
S & L Aldrich
Thinning Pro Seal
I may try calling the office out east. The western US is serviced through Phoenix. After faxing a bunch of worthless info back and forth I still don't have an "account" set up to order. Also their price for the B2 is more than Aircraft Spruce.
From: murphy-rebel@dcsol.com [mailto:murphy-rebel@dcsol.com]On Behalf Of RJBWoodman@aol.com
Sent: Tuesday, August 27, 2002 8:29 PM
Subject: Re: Thinning Pro Seal
