My Air System
Terry L McClary
My Air System
Post by Terry L McClary » Fri Feb 17, 2012 9:47 pm
I wasn't as ambitious as Dave. I bought a 2 gal wet \ dry vacuum that
had a blower output as well as vacuum. (A lot of the newer vacuum don't
have a blower output they exhaust the air around the motor which is
mounted on top.) I mounted PVC fittings in the output port and then
installed quick disconnects like they sell for your garden hose into the
fitting. I got the idea of using the vacuum after looking and listening
to the commercial units at SNF.
I used a garden hose that was approved for drinking water (marked on the
package) for my supply line and put quick disconnect fittings on both
ends. What I found was the hose marked approved for drinking water
didn't have the "plastic" odor the other hoses had.
On the mask, I found a plumbing fitting that would fit the cartridge
opening. I then mounted a 90 degree elbow in this fitting to direct the
hose toward the floor. I cut about 4 foot of garden hose (enough to
reach the waist without binding) and put a quick disconnect on the waist
end. I attached the hose to the 90 degree fitting with a small hose
clamp.
I looked at the homebuilt article that was listed a couple of messages
back before I did my thing. What I found was that after I bought a
blower motor and then built a box, it was going to be about the same cost
and faster to use the wet \ dry vacuum. I used the quick disconnect
fittings in my hose so I could disassemble the rig and store things out
of the way. The fitting at the waist is so you can support the hose
without having the weight of the hose pull your mask off.
Good luck,
Terry
Sent: Thursday, February 07, 2002 11:04 PM
Subject: Re: Air System
Hi Gary
I have put up my DRAFT page on the blower photos, you can see it
at
because
site is really in the setup stage and for now I consider it not
for public
consumption, I have provided you with the address because of your
interest
in
the fresh air blower. I will let the (mailing list) group know
when I am
ready
to go public.
Hope you find the photos useful.
Dave R.
Gary wrote:
If possible some pictures would be of great help. Did you
attach the
line
to a mask? I remember seeing something like that in one of the
aviation
mags
but can't remember which mag it was. All I can remember is they
removed
one
of the filters in the mask an attach a line to it.
Gary M
Through Adversity To The Stars
712R
Sent: Sunday, February 03, 2002 5:01 PM
effective, I came
up
with
out well
but
want to
breathe....
$CDN30.00 and
built a
big
ShopVac
filter
pipe
fittings
on the
overload
blower
this at
about a
run the
blower
can pick
up
ozone
all costs
for
health
shipping
crate
see a
picture, let
** To unsubscribe, send e-mail to list-server@dcsol.com
with
** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by
itself
** Archives located at
itself **
http://rebel:builder@www.dcsol.com:81/default.htm **
David Ricker
My Air System
Post by David Ricker » Fri Feb 17, 2012 9:47 pm
Hi Terry
You have put together about what I used to use, I switched after getting some
not so nice things into the shop vac . The blower I am using is basically a
big version of the shop vac. The shop vac will work well although I had some
concerns about the temperature it reached.
Good tips on the potable water hose, we got some clear reinforced material at
an industrial supply vendor.
Dave R.
clamp.
Good luck,
Terry
Hi Gary
at
because
for public
interest
in
when I am
ready
to go public.
Dave R.
Gary wrote:
attach the
line
aviation
mags
removed
one
effective, I came
up
out well
but
want to
$CDN30.00 and
big
ShopVac
pipe
fittings
overload
this at
run the
can pick
up
all costs
for
shipping
see a
