Cowl Fit
Cowl Fit
How important is the seal between the cowl and air filter on the underside of
the lower cowl? I have a gap of about 3/4" and I'm not sure how to seal it,
or how well sealed it needs to be.
How about the front Baffles? Should I rivet the rubber seal to the front edge
of the front baffles that cover the lower half of the air intake and deflect
the air up?
Bruce G
the air up?
Bruce G
Cowl Fit
One more question. How many of you guys painted (primed) your baffles? Is it
worth the extra effort?
Bruce G
Bruce G
Cowl Fit
Yes - extend the rubber seal forward from the front baffles,
until you get a good seal.
The seal between the cowl and the air filter is VERY important !!
Any air coming in there will pressurize the bottom section of the
cowl, reducing airflow through the cylinders, causing high CHT's .
You could try using aluminum frame guides and the rubber seal,
or a very large scat tube and gear clamps ... The big problem
is that the engine really hops around on Dynafocal mounts - an inch
or more of movement, so you need flexibility !!
This is a real challenge - if anybody has a good solution,
please let me know - I'd love to fill this area on mine !!
....bobp
-----------------------------orig.----------------------------------
....bobp
the air up?
Bruce G
Cowl Fit
Nobody I know ! No !
....bobp
--------------------------------orig.-------------------------
....bobp
Bruce G
Cowl Fit
Hi Bob,
What I did on my cowl was to take baffle seal and rivet it to the air filter holder. The wrap and corner puckers were a pain, but worth it. When I now go to remove the lower cowl, I can remove all the screws and the cowl will hange on the seal. It also hel
ps when reinstalling the cowl as I reach through the air intake and align the baffle seal first to hold the cowl as I install the lower screws.
I'm not sure you'll have the same distance from carb to intake as I do though, as I'm running the conical style 0-320.
If the room is there for you, it is nice not to have to deal with clamps or any other type of attaching device while wrestling with the bottom cowl. IMHO Curt 97MR
Cowl Fit
How about using neoprene adhesive foam strips to seal the cowl and air filter
junction? Has anyone tried this?
Bruce G 357R
Bruce G 357R
Cowl Fit
Bob
I did that on 328R. I believe you looked at that last summer.
Brian #328R
Sent: Wednesday, January 16, 2002 9:54 PM
Subject: Re: Cowl Fit
....bobp
Brian #328R
....bobp
ofHow important is the seal between the cowl and air filter on the underside
edgethe lower cowl? I have a gap of about 3/4" and I'm not sure how to seal it,
deflectof the front baffles that cover the lower half of the air intake and
** To unsubscribe, send e-mail to list-server@dcsol.com with **the air up?
Bruce G
Cowl Fit
Thanks Brian ! I probably need a 'refresher' look - finally
ready to DO SOMETHING about it !!!
....bobp
----------------------------------orig.---------------------------------
....bobp
Bob
Brian #328R
....bobp
At 09:16 PM 1/16/02 EST, you wrote:ofHow important is the seal between the cowl and air filter on the undersideedgethe lower cowl? I have a gap of about 3/4" and I'm not sure how to seal it,
How about the front Baffles? Should I rivet the rubber seal to the frontdeflectof the front baffles that cover the lower half of the air intake and** To unsubscribe, send e-mail to list-server@dcsol.com with **the air up?
Bruce G
Cowl Fit
Geeze Bob, if you really want something to do outside in the winter you can
come up here and lay under my backhoe, so I can get to work in the
shop!!!!!:):):):)
Sent: Friday, January 18, 2002 12:48 PM
Subject: RE: Cowl Fit
shop!!!!!:):):):)
undersideThanks Brian ! I probably need a 'refresher' look - finally
....bobp
At 09:58 AM 1/18/02 -0500, you wrote:Bob
Brian #328R
....bobp
At 09:16 PM 1/16/02 EST, you wrote:How important is the seal between the cowl and air filter on the
it,ofthe lower cowl? I have a gap of about 3/4" and I'm not sure how to seal
**edgeor how well sealed it needs to be.
