SR3500 Fus-409/Pulley BB-128
Post by Wayne G. O'Shea » Fri Feb 17, 2012 9:38 pm
Hi guys and gals!
Now for something totally different! I have a question for you SR builders,
that I would like some replies to! Looks like it's time for me to get some
list usage the other way, with this new project underway!
I am sorting out all the stuff that is done and still needs to be done to
this SR2500/3500 I have come to own, so I can start "tearing" into it.
Before I go drilling those big 1/2" cable clearance holes through the fins
front attach bracket (scary looking stuff aye!) I have noticed that the two
BB-128 pulleys that are mounted to the Fus-409 brackets are so big in
diameter that the previous builder had to shim the brackets out from the
bulkhead for the pulleys to clear it enough to roll and that the predrilled
cotter pin (cable retainer) holes are not useable. There is not enough
material, out far enough, to drill new cotter holes. I think I remember
seeing a note from Elaine in shipping about a change in pulley diameters
from old stock to new stock that may have been addressing this, but I can't
find it. What have those of you that are beyond this point ran into here??
Change of pulleys, mfg new brackets, extend the top bracket tab with a
couple add ons to allow for a new cotter hole, or ??.
Sasquatch #017
..... and many, many Rebels!
Al & Deb Paxhia
Post by Al & Deb Paxhia » Fri Feb 17, 2012 9:38 pm
Hi Wayne,
Well as I best remember, the folks at MAM said they discontinued the smaller
pulley and I was short one. Then I received a larger FUS409 bracket and
larger pulleys, the larger bracket and pulleys did not align with the hole
in the fin. I used the original smaller 409 and ordered a smaller pulley
from Aircraft Spruce. All went together OK we will see how it works.
Al
SR#26
Sent: Monday, January 14, 2002 6:15 PM
Subject: SR3500 Fus-409/Pulley BB-128
Hi guys and gals!
builders,
two
predrilled
can't
Sasquatch #017
Al, thanks! That is what I figured and maybe I should dig a little harder
through all the boxes and see if there is another set of FUS-409's here. I
don't think there are though, so I will check through my pulley stock in my
NOS stuff and see if I have some with a smaller O.D. so I can use the cotter
hole and a similar 1.9" cable groove diameter so no extra stress on the
cables. I noticed that these BB-128 pulleys have a really deep side wall, so
there must be a pulley with a smaller O.D and the same cable groove
diameter. Just don't want to drill those 1/2" holes through the fin attach
at the current location and then change pulleys and have to make them into
slots!
Sent: Monday, January 14, 2002 10:34 PM
Subject: Re: SR3500 Fus-409/Pulley BB-128
Hi Wayne,
smaller
Al
SR#26
Hi guys and gals!
builders,
some
fins
two
predrilled
can't
here??
Sasquatch #017
Post by Mike Kimball » Fri Feb 17, 2012 9:38 pm
This surprises me because I have serial number 44 which I bought almost 5
years ago from MAM which is a pretty early kit and I had no trouble at all.
The brackets, pulleys, hole alignment all worked fine.
SR#044
Sent: Monday, January 14, 2002 6:52 PM
slots!
Hi Wayne,
smaller
Al
SR#26
Hi guys and gals!
builders,
some
fins
two
predrilled
can't
here??
Sasquatch #017
capete
Post by capete » Fri Feb 17, 2012 9:38 pm
Wayne,
According to our manual (circa 21/06/99) and shipping list,
we are to use the BB-128, which we have listed as MS24566-3B on shipping
list, with the FUS 409 brackets We put everything together without any
problems and our holes for the cotter pin (cable retainer) have enough
clearance.
And of course, if this has changed in latest manuals we have not heard about
it...
P & M
SR003
Sent: Monday, January 14, 2002 9:15 PM
Hi guys and gals!
builders,
two
predrilled
can't
Sasquatch #017
Thanks guys and Monica!
Making sense now by the serial number "range". The packing slip spells out
BB-128's which are 1.9" diameter at the cable and 2.5" overall, but
Peter/Monica's early kit #003 was shipped with MS24566-3B's that are only
1.5" at the cable and 2" overall. The kit I have (that was Dr. Rob Helt's)
is serial #17 and it was shipped with the BB-128's and the older smaller
Fus-409's. I guess somewhere in there people tipped off MAM and they started
making larger Fus-409's to go with the larger diameter BB-128's. I guess Rob
never asked for the new Fus-409's, as I don't see them here, so I will make
my own up and stay with the larger pulley for less cable stress.
Sent: Tuesday, January 15, 2002 3:56 PM
Wayne,
clearance.
about
it...
P & M
SR003
Hi guys and gals!
builders,
some
fins
two
predrilled
can't
here??
Sasquatch #017
Don Cormack
Post by Don Cormack » Fri Feb 17, 2012 9:38 pm
I have SR 087. My pulleys are of the larger diameter and require either a
larger bracket or a shim. I haven't yet actually mounted my pulleys. So I may
look for smaller ones, to avoid extra holes in the fin mount.
Don
SR#044
slots!
Hi Wayne,
smaller
Al
SR#26
Hi guys and gals!
builders,
some
fins
two
predrilled
can't
here??
Sasquatch #017
Donald E. Cormack
Vice Dean,
School of Graduate Studies, and
Professor of Chemical Engineering
65 St. George Street
University of Toronto
Toronto, Canada M5S 2Z9
Tel: (416)978-2384 FAX: (416)978-1649
donald.cormack@utoronto.ca
Don, sounds like MAM has a larger set (of Fus-409's) for the asking, why not
check that out and go with the larger pulleys you have if you haven't
drilled the holes through the fin mount yet!? Probably what I should do also
(or make my own) as I haven't drilled the holes through the fin bracket, but
the Fus-409 pulley brackets are already drilled and cleco'd in place at
3/32".
Have you put a pulley, bolt and bracket pair together, to see if in fact you
don't already have the larger Fus-409's?
Cc: <murphy-rebel@dcsol.com>
Sent: Tuesday, January 15, 2002 6:10 PM
Subject: Re: RE: SR3500 Fus-409/Pulley BB-128
may
Don
5
all.
SR#044
harder
my
cotter
wall, so
attach
into
slots!
Hi Wayne,
smaller
hole
pulley
Al
SR#26
builders,
get
some
done
it.
fins
two
in
predrilled
enough
remember
diameters
can't
here??
itself
Donald E. Cormack
Vice Dean,
Didn't go the first/second time due to the server problems!
Sent: Tuesday, January 15, 2002 11:01 PM
Subject: RE: SR3500 Fus-409/Pulley BB-128
not
also
but
3/32".
you
either
So
may
Don
wrote:
almost
5
at
all.
Behalf
Of
harder
here.
stock
in
my
cotter
wall, so
attach
them
into
bracket
hole
pulley
works.
SR
get
be
done
into
it.
through
that
big
in
from
enough
remember
diameters
but
into
with
with
itself
itself
Donald E. Cormack
Vice Dean,
