fus-27 flange
Joel Jacobs
fus-27 flange
Post by Joel Jacobs » Sat Feb 18, 2012 12:21 am
Hi Folks,
I've been battling that fuselage root rib flange a couple days now with not
much success. I tried sandwiching it between two strips of 1/8"X3/4" iron
strips an using C-clamps as suggested and it did straighten the flange but
the rib will no way lay flat on the table like the manual says. I'm either
going to have to buy a shrinker or flute the flange. Will a shrinker be
handy for anything else? I don't want to buy one just for this piece. Is
the flange visible from inside the completed cabin? If not I'll flute it.
Joel
P.S. www.harborfrieght.com has a shrinker/stretcher set - not one machine
with both jaws but two machines - for $149.
Joel Jacobs
fus-27 flange
Dang, spelt that rong - should be http://www.harborfreight.com
Joel
fus-27 flange
Post by Mike Kimball » Sat Feb 18, 2012 12:21 am
How crooked is the rib? Mine wouldn't lay completely flat after
straightening the flange with the method you used but when I positioned it
in place and started drilling and clecoing, things fell into place pretty
well. It probably still has a minor wave to it but I can't tell by casual
observation.
SR#044
Joel Jacobs
Sent: Monday, November 05, 2001 6:40 AM
Subject: fus-27 flange
Hi Folks,
Joel
Don Cormack
fus-27 flange
Post by Don Cormack » Sat Feb 18, 2012 12:21 am
The only way to get root rib straight is to use fluting pliers. You are going
to need these pliers for the ribs in the rudder and elevator as well... and for
the roof ribs that are aligned parallel to the root ribs.
Don Cormack
SR#086
observation.
SR#044
Joel Jacobs
Hi Folks,
Joel
Donald E. Cormack
Vice Dean,
School of Graduate Studies, and
Professor of Chemical Engineering
65 St. George Street
University of Toronto
Toronto, Canada M5S 2Z9
Tel: (416)978-2384 FAX: (416)978-1649
donald.cormack@utoronto.ca
Joel Jacobs
fus-27 flange
observation.
The biggest warp is right at the first few inches from the front - the part
just above where it's cut out to fit around the top carrythrough/gusset. If
I lay the rib on the table, the very front of the rib where the flange
starts is contacting the table but just 2" back it's about 1/2" off the
table. When I flattened the flange that front section just curled right
down. I think I'm going to need to do something before I'll be able to
start drilling and clecoing. I think it'll look alright if I put a few
flutes in it. I'll lay out where the rivets will be and do it between them.
Joel
Rebel 416
fus-27 flange
Post by Bob Patterson » Sat Feb 18, 2012 12:21 am
Hi Joel !
Fluting is probably a lot easier ! Just be sure to flute
BETWEEN the rivet holes !!! ;-)
The shrinker-stretcher is useful for the corner wraps between
the aft cabin and the fuse, and is essential for building the floats,
if you go that route ...
....bobp
----------------------------orig.-----------------------------------------
At 10:40 AM 11/5/01 -0500, you wrote:
Hi Folks,
Joel
Joel Jacobs
fus-27 flange
Subject: Re: RE: fus-27 flange
going
and for
Yeah, I've about come to that conclusion. I'll spend an evening and try to
make a pair of fluting pliers. I'm thinking a pair of vise grips and three
pieces of 3/16" drill rod should do it - two on the bottom jaw and one
between them on the top jaw. I'm just trying to invision the correct
angles.
Joel
P.S. If any of you folks have a set and a digital camera I would sure
appreciate it if you could email me direct a picture of the business end...
Thanks!
Joel Jacobs
fus-27 flange
Hi Joel !
Ok.
....bobp
Well I don't plan on floats. Not many seaplane bases around here! I think
I'll try hammer and dolly on the corner wraps because the shrinker would not
leave a very nice finish on the outside of the plane. I have four extra to
experiment with since I upgraded the thickness.
Joel
Drew and Jan
fus-27 flange
Post by Drew and Jan » Sat Feb 18, 2012 12:21 am
Joel my fluting pliers are made from a set of regular slip joint pliers. I
just unbolted them and ground matching curves in each jaw then bolted them
back together again.
P.S. If you're near centralia ont you can come over and use my shrinker
strecher
going
and for
angles.
Joel
Thanks!
Murray & Carol
fus-27 flange
Post by Murray & Carol » Sat Feb 18, 2012 12:21 am
Hi Joel:
Went to the House of Tools and bought a pair of flutting pliers. This did a
good job. I took a pair of flat nosed pliers and flattened the area where
each rivet goes so the rib and skin are tight together. Don't fully crimp
first time around as you can go back and crimp some more if not enough the
first time.The only trickey area is right at the front where the flange is
the narrowest and the curve the sharpest. Takes a little Quirking here.
You'll see when you get there.
GOOD LUCK
Murray Cherkas
REBEL 505
Rebflyer
fus-27 flange
Post by Rebflyer » Sat Feb 18, 2012 12:21 am
Joel,
In my opinion? BY THE SHRINKER!(Any reason to by a tool is a good reason) Keep at it, It's worth it Curt N97MR
klehman
fus-27 flange
Post by klehman » Sat Feb 18, 2012 12:21 am
My Shrinker chews up the metal enough that that I prefer the fluting
pliers for most things. Maybe I'm paranoid about cracks developing. But
hey, I agree, another tool can't be a bad thing! Of course my wife isn't
quite so sure....
Rebflyer@aol.com wrote:
Joel,
