FUS-30 DAMAGE/REPAIR
Post by Wayne G. O'Shea » Sat Feb 18, 2012 12:17 am
Thought I would let everyone know that I have posted 3 pictures to the
Rebel-Fuselage "file".
Many builders in the past few years have asked if there was any positive
proof for the need to reinforce the FUS-30, from in front of the tail spring
attach bulkhead to the fin tailpost, as Bob and myself have been suggesting
to all the builders we've had the privilege to meet/greet over the past MANY
years. I have uploaded the pictures so you don't have to take our word for
it anymore!! Two recent aircraft through my shop have allowed me to get some
shots.
One picture shows a buckled FUS-30. The reinforcement shown in the picture
that was installed by the builder(s) was useless, as it was installed
between the spring attach bulkhead (SAB) and the TS-1's. It did not overlap
the tail post or the SAB at all, so didn't offer any additional strength to
the area.
Another picture shows a cracked FUS-30. This seems to have been caused by a
loosely held tail spring rocking back and forth with a one sided fork Maule
tailwheel. These Maule tailwheels do cause some extra twisting motion on the
tailspring due to the one sided fork, so try to avoid their usage if you
can. If it's a deal you can't refuse, make sure the Tspring is tight and you
have done the FUS-30 doubler.
Third picture shows the cracked FUS-30 repaired with the suggested FUS-30
doubler to prevent the cracking or buckling, that should be built into EVERY
new fuselage that you guys and gals are putting together.
Post by Walter Klatt » Sat Feb 18, 2012 12:17 am
Wayne, curious to know if you have seem this problem on float planes as
well. This is one fix I still haven't applied, but intend to, and just
wondering how urgent it is if on floats. I check mine all the time, and so
far have not seen any deformation in the area. I have the other tail post
fix applied.
Sent: October 21, 2001 11:36 AM
Subject: FUS-30 DAMAGE/REPAIR
tail spring
suggesting
the past MANY
to get some
shots.
not overlap
strength to
the area.
caused by a
fork Maule
motion on the
tight and you
into EVERY
** To unsubscribe, send e-mail to list-server@dcsol.com
with **
** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by
itself **
** Archives located at
http://rebel:builder@www.dcsol.com:81/default.htm **
Walter, shouldn't be a problem unless you flare at a REALLY intense angle
(and bang the tail), or buy a "beta" capable prop and back into a boat
house!!! Strictly a tailwheel "load" associated problem. The SB on the
tailpost to FUS-31 however (that you say you have complied with) is strictly
(90% anyhow) an air load created problem, as it happened to Howard's while
strictly being flown on floats.
Sent: Sunday, October 21, 2001 3:19 PM
Subject: RE: FUS-30 DAMAGE/REPAIR
fix applied.
tail spring
suggesting
the past MANY
for
to get some
shots.
not overlap
strength to
the area.
caused by a
fork Maule
motion on the
tight and you
FUS-30
into EVERY
with **
itself **
Jason Beall
Post by Jason Beall » Sat Feb 18, 2012 12:17 am
3 pictures to the
Where do i navigate to to see these pics?
web address?
-Jason
Jason Beall
Super Rebel No. 131
Aberdeen, Scotland, UK
super_rebel131@yahoo.com
Do You Yahoo!?
Make a great connection at Yahoo! Personals.
http://personals.yahoo.com
LisaFly99
Post by LisaFly99 » Sat Feb 18, 2012 12:17 am
In a message dated 10/22/01 3:15:56 AM Central Daylight Time, super_rebel131@yahoo.com writes:
3 pictures to the
web address?
JASON
Maddog! BBS - Home Page
Just inter name- rebel
password- builder
universal to get in.
Phil&Lisa Smith
#460R
N414D
Mike Davis
Post by Mike Davis » Sat Feb 18, 2012 12:17 am
Everyone please notice that at the bottom of each message the server
automatically adds 4 lines of text. The third line is a hyperlink to the
archives, including the username and password to make it automatic.
Clicking on this link will load the main page from where you can select
"mail" to access the message archives, or "files" to access the file
libraries.
web address?
-Jason
Post by Mike Kimball » Sat Feb 18, 2012 12:17 am
Probably not enough history to know if this is a problem for the Super
Rebel. Anybody think a similar mod should be done for an SR?
SR#044
Sent: Sunday, October 21, 2001 10:36 AM
shots.
the area.
Mike, the SR tailspring is totally different so no need for a doubler as
shown in the FUS-30 pictures. The SR uses a "rod" style tailspring that does
not push up against the fin tailpost. Would suspect the SR tailcone is
strong enough, as designed by MAM, but only rough field usage will tell.
After all the SR was designed for higher HP/weights. Remember the original
Rebel design was for a 80 H.P. Rotax 912 and a gross of 1200 pounds. Now
that we have 150/180 hp and a gross of 1650, a "few" things need to be
beefed up from the original design!!
Sent: Monday, October 22, 2001 3:09 PM
SR#044
spring
suggesting
MANY
some
shots.
overlap
the area.
Maule
you
EVERY
Post by Mike Kimball » Sat Feb 18, 2012 12:21 am
Thanks Wayne.
Sent: Monday, October 22, 2001 1:12 PM
Subject: Re: FUS-30 DAMAGE/REPAIR
SR#044
spring
suggesting
MANY
some
shots.
overlap
the area.
Maule
you
EVERY
Charles Skorupa
Post by Charles Skorupa » Sat Feb 18, 2012 12:21 am
The Elite uses the same rod tailspring as the Super Rebel so Wayne's words
probably apply to it as well, for you Elite builders.
- Chuck Skorupa -
Rebel elite S/N #500
Sent: Monday, October 22, 2001 2:11 PM
does
SR#044
spring
suggesting
MANY
for
some
shots.
overlap
the area.
by
Maule
you
FUS-30
EVERY
