No Title
No Title
Received: from MMoreho699@aol.com
by imo20.mx.aol.com (IMOv14_b1.1) id WOPKa26007;
Tue, 2 Jun 1998 14:31:55 -0400 (EDT)
Message-ID: <21f04374.3574451c@aol.com>
Date: Tue, 2 Jun 1998 14:31:55 EDT
To: murtech@murphyair.com, murphy-rebel@dcsol.com
Mime-Version: 1.0
Subject: Fuselage Root Rib Placement
Content-type: multipart/mixed;
boundary="part0_896812315_boundary"
X-Mailer: AOL 3.0 for Mac sub 78
Content-ID: <0_896812315@inet_out.mail.aol.com.1>
Hello!
Confused regarding placement of Fuselage Root Ribs onto Bulkhead F and the
gusset for the Upright. From 03/14/95 Ch. 13 steps 209-210, Figs 82-83: I
don't understand how it's supposed to go. For fig 82a, the lower flange for
the root rib hits the upright when I try it. For 82b, I don't know what
flange
it's supposed to rest on. For me, flanges also hit each other.
Please see the attached JPEG and I'll send another so it won't be
compressed.
If you can't view it, let me know so I can make changes.
also, the flange that needs to be flattened on the root rib is the top one
on
the curved portion right?
Dan
Mime-Version: 1.0
Hello!
flange
compressed.
on
Dan
No Title
Received: from nidlink.com (pm9-43.nidlink.com [206.96.73.98])
by enaila.nidlink.com (8.8.5/8.8.5) with ESMTP id SAA21295
for <murphy-rebel@dcsol.com>; Sat, 14 Nov 1998 18:45:51 -0800 (PST)
Message-ID: <364E40FE.D84EEE34@nidlink.com>
Date: Sat, 14 Nov 1998 18:48:30 -0800
X-Mailer: Mozilla 4.04 [en] (Win95; I)
MIME-Version: 1.0
Subject: Re:
References: <001101be0f57$53ea7bc0$2a640a80@tim>
Content-Type: text/plain; charset=x-user-defined
Tim Carter wrote:
What I did was copy the gear exactly to Chrome moly tube. Doubled and all.
Then instead of drilling and wrapping the bungees around a bolt I took 1"
tube,
welded large washers on the ends and welded these to the leg. Then I took a
smaller tube and welded an angle brace back from the washer end back to the
leg. The slide tube inside then could extend much farther into the leg. I
took it all the way to the bottom of the leg. It took quite a bit of
polishing
to make the parts slide well after welding to the outside of the tube but
now I
have a full length doubler. Since I was the cause of the "Cable AD" I opted
replace it with a solid 3\8" bolt. That would take some time to explain but
have a long 3\8" bolt that slides through an internal washer. At max
extension
it encounters a stop. The gear is naturally heavier, but I won't spend my
winters rebuilding because of it breaking. If you want more send me a
private
mail and I will fax you a drawing or something.
Dave Bangle #42
MIME-Version: 1.0
Subject: Re:
Tim Carter wrote:
Tim,Dave:
Do you have details of your changes to the bungee gear? Specs, drawings,
etc...? I plan to use the bungee gear and would be interested in your
improvements to it.
Tim C
#438R
tube,
polishing
now I
extension
private
Dave Bangle #42
No Title
Received: from tim - 153.34.164.197 by email.msn.com with Microsoft SMTPSVC;
Mon, 30 Nov 1998 12:04:36 -0800
Reply-To: <tlcarter@msn.com>
To: "'Rebel Builder's Group List'" <murphy-rebel@dcsol.com>
Subject:
Date: Mon, 30 Nov 1998 11:50:26 -0800
Message-ID: <001101be1c9a$c3161c20$c9e2b7cf@tim>
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3 (Normal)
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
Importance: Normal
Return-Path: tlcarter@email.msn.com
Joel:
SealPak (which is what came with my kit) makes two grades of 'Proseal'. One
is spatula-grade, thicker than peanut butter, and one is brushable-grade,
like honey.
I believe they are designated B2 for the spatula-grade and A2 for the
brushable-grade, with the "2" representing a 2 hour cure.
I have used both...the thick for the primary seal, and the thin for the
topcoat over rivet heads, etc.
I believe the thin will work better for you with no wavy lines in the skin.
SealPak:
316-942-6211
TimC
#438R
P.S.
My tanks are all sealed up with plugs while in storage, and they go 'whoosh'
when I open them after sitting thru some changes in barometric pressure...I
hope that means no leaks!!
Sent: Monday, November 30, 1998 9:15 AM
To: Murphy Rebel
Subject: Re: .Re: strengthening cabin/firewall
To: (Murphy Rebel) <murphy-rebel@dcsol.com>
Date: Sunday, November 29, 1998 3:30 PM
Dave,
Did you thin the proseal at all? I've found that the stuff is so thick that
if you are not careful, you can get a little waivyness in the rivet line
because it don't squeeze out so good.
Joel
Subject:
MIME-Version: 1.0
Importance: Normal
Joel:
like honey.
SealPak:
316-942-6211
TimC
#438R
P.S.
To: Murphy Rebel
sells as aWhile Bob Patterson is a strong believer in the Stits epoxy that Murphy
riveted wetbonding agent, I have taken many parts that were put together wet and
guysas suggested by a lot of guys. All parts just fell apart. While a lot of
fusalagemay groan when they read this, consider Pro Seal. I Pro Sealed my entire
Dave,
Joel
No Title
Received: from 486dx2-80 (unverified [205.182.69.166]) by merlin.netexp.net
(Rockliffe SMTPRA 2.1.4) with SMTP id <B0004487323@merlin.netexp.net> for
Mon, 30 Nov 1998 16:23:06 -0500
Subject: Re:
Date: Mon, 30 Nov 1998 16:33:06 -0500
Message-ID: <005901be1ca9$046792e0$LocalHost@486dx2-80>
MIME-Version: 1.0
X-Priority: 3
X-Mailer: Microsoft Outlook Express 4.71.1712.3
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.2106.4
To: 'Rebel Builder's Group List' <murphy-rebel@dcsol.com>
Date: Monday, November 30, 1998 2:54 PM
Acetone to thin the thick stuff...
Joel
Subject: Re:
MIME-Version: 1.0
X-Priority: 3
OneJoel:
Thanks for the tip Tim. When I need it a little thinner, I've used MEK oris spatula-grade, thicker than peanut butter, and one is brushable-grade,
like honey.
Joel
No Title
Received: from dial119.Block1.Seattle.freei.net
(dial119.Block1.Seattle.freei.net [209.162.144.119])
by mail.wa.freei.net (8.9.1/8.9.1) with SMTP id QAA24871
for <murphy-rebel@dcsol.com>; Sat, 26 Dec 1998 16:38:02 -0800 (PST)
(envelope-from baileyca@wa.freei.net)
Received: by dial119.Block1.Seattle.freei.net with Microsoft Mail
id <01BE30EE.44EEC140@dial119.Block1.Seattle.freei.net>; Sat, 26 Dec 1998
16:39:12 -0800
Message-ID: <01BE30EE.44EEC140@dial119.Block1.Seattle.freei.net>
To: "'murphy-rebel@dcsol.com'" <murphy-rebel@dcsol.com>
Subject: RE: Elevator ;Rudder TIPS /nut plates
Date: Sat, 26 Dec 1998 16:33:29 -0800
MIME-Version: 1.0
Hi Johannes and all,
The attached picture is Rev Nut and tool and 4 Nut Plates (one floating type
and 3 others)
Chuck R176
Sent: Saturday, December 26, 1998 2:10 PM
Subject: Re: Elevator ;Rudder TIPS /nut plates
Hi Johannes
Nut Plates are the same as "ANCHOR NUT" which are shipped with the kit
under
the part number "F5000-3" or MS21059-3.
The MS number is the common part number used.
The -3 is the size .. 3/16 bolt or -4 for 1/4 inch bolt ,,,,
-8 for a screw size of 8-32
Hope this helps.
Jim JimsRebel@aol.com
16:39:12 -0800
MIME-Version: 1.0
and 3 others)
Chuck R176
Hi Johannes
under
Hope this helps.
No Title
Wray is correct... once you unzip them you will want to click on the
"index.htm" file. This will display all the messages sorted by thread with
the option to sort by date, author, or subject... it's just like you're
viewing it online. The only thing you'll lose by viewing the files
downloaded is the ability to search. But it will certainly be faster!
At 10:43 AM 9/7/00 -0400, you wrote:
The Flying Rebels List is for the discussion between
builders and owners of complete/flying Murphy Rebel
aircraft. Archives located at:
*-----------------------------------------------------------------------------------*Drew if you don't want to read them while online here
http://www.dcsol.com/murphy-rebel/lists/ by just clicking on the
appropriate date,
(easiest way) then download them and unzip them. I believe they are all
in the html
format and you should be able to read them with what ever surfer you use
(Netscape etc.)
Drew and Jan wrote:
*-----------------------------------------------------------------------------------*Hi all I'm new to this list and would prefer to just lurk and catch up on
the archives but I haven't been able to open them. I'm using adobe acrobat
and keep getting an error message no pdf% . can anyone help me? am I using
the wrong reader?
Thanks Drew Dalgleish
Rebel C-FYHO
Click here for Free Video!!
*-----------------------------------------------------------------------------------*The Flying Rebels List is for the discussion between
Wray Thompson ...Rebel 306 ...home page http://webhome.idirect.com/~wrayt/
My ICQ number is 29764664
No Title
the wrong reader?
Rebel C-FYHO
the wrong reader?
Rebel C-FYHO
No Title
http://www.dcsol.com/murphy-rebel/lists/ by just clicking on the appropriate date,
(easiest way) then download them and unzip them. I believe they are all in the html
format and you should be able to read them with what ever surfer you use (Netscape etc.)
Drew and Jan wrote:
--Hi all I'm new to this list and would prefer to just lurk and catch up on
the wrong reader?
Rebel C-FYHO
No Title
* M E R R Y C H R I S T M A S *
* AND *
* A H A P P Y N E W Y E A R *
* TO *
* ALL THE REBEL BUILDERS !!! *
* From Bob & Anna Patterson *
Our Best Wishes for a Happy Holiday, and a fun-filled summer in the
coming New Year !!
Hope to see you at the next Rebel Builders Meeting on January 14th.
Contributors' page at:
Visit the book store at:
* AND *
* TO *
coming New Year !!
No Title
Received: from bureau6.utcc.utoronto.ca ([128.100.132.16])
by dcsol.com (wcSMTP v5.4.449.1)
with SMTP id 37322171; Mon, 12 Mar 2001 07:32:26 -0900
Received: from jnb.sgs.utoronto.ca ([128.100.184.154] HELO 65309486.sgs.utoronto.ca ident: NO-IDENT-SERVICE [port 1304]) by bureau6.utcc.utoronto.ca with SMTP id <464522-26566>; Mon, 12 Mar 2001 11:32:09 -0500
Reply-To: donald.cormack@utoronto.ca
Subject: Re: chamfered landing gear legs for SR2500
In-Reply-To: <3AACC738.49025EBB@sympatico.ca>
Message-ID: <SIMEON.10103121104.G@65309486.sgs.utoronto.ca>
Date: Mon, 12 Mar 2001 11:31:04 -0500 (Eastern Standard Time)
Priority: NORMAL
X-Mailer: Simeon for Win32 Version 4.1.5 Build (43)
X-Authentication: none
MIME-Version: 1.0
Content-Type: TEXT/PLAIN; CHARSET=US-ASCII
Peter & Monica: I will be very interested to see your chamfered landing gear.
You may just have a sale! See you next Sunday in Brampton.
Don
Donald E. Cormack
Vice Dean,
School of Graduate Studies, and
Professor of Chemical Engineering
65 St. George Street
University of Toronto
Toronto, Canada M5S 2Z9
Tel: (416)978-2384 FAX: (416)978-1649
Priority: NORMAL
MIME-Version: 1.0
Don
Donald E. Cormack
Vice Dean,
No Title
unsubscribe murphy-rebel
No Title
Mark,
The air intake was one of the more time consuming parts of our project. I
looked at a lot of different "real" airplanes to get ideas on how to build an
air intake system. The big problem with the SR is the lack of distance
between whatever air box you use and the fiberglass cowl - the short distance
does not give you much room to work in. Here's what I ended up doing:
On the engine/carburetor:
I ended up borrowing several used air boxes from a local salvage yard. It
looks like these were off old Cessna 180's/185's. I took the one with the
most functioning parts and then rebuilt the carb heat flapper and added hose
attachment flanges for two carb heat hoses. I cut the end off of the air box
to shorten it and to get rid of the 90 degree flange on the end. On this
shortened end I riveted sections of rubber sheet that extend out past the
inlet end of the air box about 2 inches on all four sides.
On the fiberglass cowl:
I bought a bracket air filter and housing and riveted this to the inside of
the cowl after cutting out an opening in the air intake part of the cowl. I
might be able to find the part # if you are interested. It was the largest
air filter that would fit in the cowl opening.
Assembly:
When I put on my lower cowl the aluminum Bracket air filter housing slides up
against the front of the air box on the carburetor. The rubber around the
opening of the air box slides around the outside of the Bracket filter
housing. The aluminum Bracket air filter housing does not touch the air box
as this would be a constant vibration wear point. My theory on the rubber on
the end of the air box is that the high pressure in the lower cowl as well as
the air box vacuum would hold the rubber tight enough around the air box to
seal everything up. The only safety check I need to make is when I put on my
lower cowl I check to make sure the rubber is on the outside of the Bracket
housing and that it did not slip into the housing.
I may have photos if you're interested.
Chris Gill, SR#025
Sent: Wednesday, November 21, 2001 4:07 PM
To: gill@gci.net
Subject: air intake
chris, glad to see ur up and flying, mark kohut sr 2500 #016 here in chicago
have a few ?'s i'm about ready to install my engine io-540 converted to 0-540
with a fixed pitch prop what did u do for an air intake system any pointers in
this matter will be appreciated , look for your reply and great job hope to
have first flite come late spring early summer. mark
Assembly:
Chris Gill, SR#025
To: gill@gci.net
Subject: air intake
No Title
In a message dated 11/21/01 11:30:59 PM Central Standard Time, cgill@dcsol.com writes:
Where you located in the Chitown area?
Phil&Lisa Smith
R460
N414D
MARKsr 2500 #016 here in chicago
Phil&Lisa Smith
R460
N414D
No Title
